[petsc-users] zero pivot in LU factorization when using -fieldsplit_0_pc_type gamg in schur fieldsplit PC
Mon Dec 7 17:57:20 CST 2015
   It is getting a zero pivot when factoring the little dense diagonal blocks of the smoother matrix (to do SOR).
   What happens if you run with the additional option -mat_no_inode?
   Run with the additional option -start_in_debugger noxterm
In the debugger type
cont
when it crashes type
bt
then use
up
as many times as needed to get to the routine MatSOR() then type
call MatView(mat,0)
you should see that diagonal subblock from the 3rd row to 7th row is singular. Normally we would expect this from the operator
mu lap(u) unless the mu has zero entries?
What happens if you run -fieldsplit_0_pc_type sor ? Does it also give a zero factorization?
> On Dec 7, 2015, at 5:35 PM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> Hello,
> I'm revisiting my code for solving a system of eqs similar to Stokes to get better convergence for big jumps in viscosity (mu) and wanted to experiment with petsc's gamg:
> mu lap(u) + grad(p) = f1
>       div(u)                = f2
> Dirichlet boundary condition of zero velocity.
> The implementation is a finite difference with a staggered grid discretization.
> Using Schur FieldSplit PC type, and for constant viscosity, using hypre PC for A00 block had been serving well. Now when trying gamg, I get zero pivot error. From some of the past discussions in the archives of the mailing list, it seems I've to play around with ..._sub_pc_factor_shift_type but I could not figure out the exact set of options.
> Setting mu = 1 everywhere; Using the following options:
> -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_precondition self -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3 -fieldsplit_0_pc_type gamg
> I get an error.
> When I use -fieldsplit_0_pc_type lu , it converges in a single iteration so I guess it should mean that A00 is not singular.
> Below are the results of using:
> 1. -fieldsplit_0_pc_type hypre (converges)
> 2. -ksp_view -fieldsplit_0_pc_type lu (converges)
> 3. -fieldsplit_0_pc_type gamg (all error output)
> 1. ----------------------------------------
> With -fieldsplit_0_pc_type hypre
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 7
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 17
> Linear solve converged due to CONVERGED_RTOL iterations 2
> 2. --------------------------------------------
> With -fieldsplit_0_pc_type lu -ksp_view
> -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_precondition self -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3 -fieldsplit_0_pc_type lu -fieldsplit_1_ksp_rtol 1.0e-10 -fieldsplit_1_ksp_converged_reason -ksp_converged_reason -ksp_view
>   Linear fieldsplit_0_ solve converged due to CONVERGED_ATOL iterations 0
>   Linear fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 1
>   Linear fieldsplit_1_ solve converged due to CONVERGED_RTOL iterations 22
> Linear solve converged due to CONVERGED_RTOL iterations 1
> KSP Object: 1 MPI processes
>   type: gmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, blocksize = 4, factorization FULL
>     Preconditioner for the Schur complement formed from S itself
>     Split info:
>     Split number 0 Fields  0, 1, 2
>     Split number 1 Fields  3
>     KSP solver for A00 block
>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>         type: gmres
>       PC Object:      (fieldsplit_0_)       1 MPI processes
>         type: lu
>           LU: out-of-place factorization
>           tolerance for zero pivot 2.22045e-14
>           matrix ordering: nd
>           factor fill ratio given 5, needed 20.772
>             Factored matrix follows:
>               Mat Object:               1 MPI processes
>                 type: seqaij
>                 rows=54243, cols=54243, bs=3
>                 package used to perform factorization: petsc
>                 total: nonzeros=8.41718e+07, allocated nonzeros=8.41718e+07
>                 total number of mallocs used during MatSetValues calls =0
>                   using I-node routines: found 17801 nodes, limit used is 5
>         linear system matrix = precond matrix:
>         Mat Object:        (fieldsplit_0_)         1 MPI processes
>           type: seqaij
>           total: nonzeros=4.05217e+06, allocated nonzeros=4.05217e+06
>             using I-node routines: found 18081 nodes, limit used is 5
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>         type: gmres
>         tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
>       PC Object:      (fieldsplit_1_)       1 MPI processes
>         type: none
>         Mat Object:        (fieldsplit_1_)         1 MPI processes
>           type: schurcomplement
>           rows=18081, cols=18081
>             has attached null space
>             Schur complement A11 - A10 inv(A00) A01
>             A11
>                 type: seqaij
>                 total: nonzeros=450241, allocated nonzeros=450241
>                   not using I-node routines
>             A10
>                 type: seqaij
>                 rows=18081, cols=54243
>                 total: nonzeros=1.35072e+06, allocated nonzeros=1.35072e+06
>             KSP of A00
>                 type: gmres
>                 type: lu
>                   matrix ordering: nd
>                         type: seqaij
>                   type: seqaij
>             A01
>                 type: seqaij
>                 rows=54243, cols=18081, rbs=3, cbs = 1
>     type: seqaij
>     rows=72324, cols=72324, bs=4
>     total: nonzeros=7.20386e+06, allocated nonzeros=7.20386e+06
> 3. ----------------------------------------
> when using gamg: -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_schur_precondition self -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3 -fieldsplit_0_pc_type gamg -fieldsplit_0_ksp_converged_reason -fieldsplit_1_ksp_converged_reason -ksp_converged_reason -ksp_view
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Zero pivot in LU factorization: http://www.mcs.anl.gov/petsc/documentation/faq.html#zeropivot
> [0]PETSC ERROR: Zero pivot, row 3
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
> [0]PETSC ERROR: /user/bkhanal/home/works/AdLemModel/build/src/AdLemMain on a arch-linux2-cxx-debug named delorme by bkhanal Mon Dec  7 23:13:00 2015
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --with-clanguage=cxx --download-fblaslapack --download-scalapack --download-mpich --download-superlu_dist --download-mumps --download-hypre --download-metis --download-parmetis
> [0]PETSC ERROR: #1 PetscKernel_A_gets_inverse_A_5() line 48 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/impls/baij/seq/dgefa5.c
> [0]PETSC ERROR: #2 MatSOR_SeqAIJ_Inode() line 2808 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
> [0]PETSC ERROR: #3 MatSOR() line 3697 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: #4 PCApply_SOR() line 37 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/sor/sor.c
> [0]PETSC ERROR: #5 PCApply() line 483 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #6 KSP_PCApply() line 242 in /home/bkhanal/Documents/softwares/petsc-3.6.3/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #7 KSPInitialResidual() line 63 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: #8 KSPSolve_GMRES() line 235 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: #9 KSPSolve() line 604 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #10 KSPSolve_Chebyshev() line 381 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/impls/cheby/cheby.c
> [0]PETSC ERROR: #11 KSPSolve() line 604 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #12 PCMGMCycle_Private() line 19 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #13 PCMGMCycle_Private() line 48 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #14 PCApply_MG() line 340 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #15 PCApply() line 483 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #16 KSP_PCApply() line 242 in /home/bkhanal/Documents/softwares/petsc-3.6.3/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #17 KSPInitialResidual() line 63 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: #18 KSPSolve_GMRES() line 235 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: #19 KSPSolve() line 604 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #20 MatMult_SchurComplement() line 105 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/utils/schurm.c
> [0]PETSC ERROR: #21 MatNullSpaceTest() line 431 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/interface/matnull.c
>  WARNING: not a valid pressure null space
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR:  Vec is locked read only, argument # 1
> [0]PETSC ERROR: #22 VecSet() line 573 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/vec/vec/interface/rvector.c
> [0]PETSC ERROR: #23 MatMultTranspose_SeqAIJ() line 1263 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/impls/aij/seq/aij.c
> [0]PETSC ERROR: #24 MatMultTranspose() line 2282 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: #25 MatRestrict() line 7829 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: #26 PCMGMCycle_Private() line 44 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #27 PCApply_MG() line 340 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #28 PCApply() line 483 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #29 KSP_PCApply() line 242 in /home/bkhanal/Documents/softwares/petsc-3.6.3/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #30 KSPInitialResidual() line 63 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: #31 KSPSolve_GMRES() line 235 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: #32 KSPSolve() line 604 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #33 PCApply_FieldSplit_Schur() line 898 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: #34 PCApply() line 483 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #35 KSP_PCApply() line 242 in /home/bkhanal/Documents/softwares/petsc-3.6.3/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #36 KSPInitialResidual() line 63 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: #37 KSPSolve_GMRES() line 235 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: #38 KSPSolve() line 604 in /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #39 solveModel() line 313 in /home/bkhanal/works/AdLemModel/src/PetscAdLemTaras3D.cxx
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] getSolVelocityAt line 137 /home/bkhanal/works/AdLemModel/src/PetscAdLem3D.cxx
> [0]PETSC ERROR: [0] VecSet line 568 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/vec/vec/interface/rvector.c
> [0]PETSC ERROR: [0] MatMultTranspose_SeqAIJ line 1262 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/impls/aij/seq/aij.c
> [0]PETSC ERROR: [0] MatMultTranspose line 2263 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] MatRestrict line 7817 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] PCMGMCycle_Private line 17 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: [0] PCApply_MG line 325 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: [0] PCApply line 463 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: [0] KSP_PCApply line 240 /home/bkhanal/Documents/softwares/petsc-3.6.3/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: [0] KSPInitialResidual line 44 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: [0] KSPSolve_GMRES line 225 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: [0] KSPSolve line 510 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] PCApply_FieldSplit_Schur line 848 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: [0] PetscKernel_A_gets_inverse_A_5 line 25 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/impls/baij/seq/dgefa5.c
> [0]PETSC ERROR: [0] MatSOR_SeqAIJ_Inode line 2764 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/impls/aij/seq/inode.c
> [0]PETSC ERROR: [0] MatSOR line 3678 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] PCApply_SOR line 35 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/pc/impls/sor/sor.c
> [0]PETSC ERROR: [0] KSPSolve_Chebyshev line 358 /home/bkhanal/Documents/softwares/petsc-3.6.3/src/ksp/ksp/impls/cheby/cheby.c
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: #40 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> [unset]: aborting job:
