[petsc-users] SuperLU convergence problem (More test)
Danyang Su dsu at eos.ubc.ca
Sat Dec 5 18:11:18 CST 2015
Hi Hong,
I did more test today and finally found that the solution accuracy
depends on the initial (first) matrix quality. I modified the ex52f.F to
do the test. There are 6 matrices and right-hand-side vectors. All these
matrices and rhs are from my reactive transport simulation. Results will
be quite different depending on which one you use to do factorization.
Results will also be different if you run with different options. My
code is similar to the First or the Second test below. When the matrix
is well conditioned, it works fine. But if the initial matrix is well
conditioned, it likely to crash when the matrix become ill-conditioned.
Since most of my case are well conditioned so I didn't detect the
problem before. This case is a special one.
How can I avoid this problem? Shall I redo factorization? Can PETSc
automatically detect this prolbem or is there any option available to do
this?
All the data and test code (modified ex52f) can be found via the dropbox
link below.
_
__https://www.dropbox.com/s/4al1a60creogd8m/petsc-superlu-test.tar.gz?dl=0_
Summary of my test is shown below.
First, use the Matrix 1 to setup KSP solver and factorization, then
solve 168 to 172
mpiexec.hydra -n 1 ./ex52f -f0
/home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin/a_flow_check_1.bin
-rhs
/home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin/b_flow_check_1.bin
-loop_matrices flow_check -loop_folder
/home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin -pc_type lu
-pc_factor_mat_solver_package superlu_dist
Norm of error  3.8815E-11 iterations     1
  -->Test for matrix          168
Norm of error  4.2307E-01 iterations    32
  -->Test for matrix          169
Norm of error  3.0528E-01 iterations    32
  -->Test for matrix          170
Norm of error  3.1177E-01 iterations    32
  -->Test for matrix          171
Norm of error  3.2793E-01 iterations    32
  -->Test for matrix          172
Norm of error  3.1251E-01 iterations    31
Second, use the Matrix 1 to setup KSP solver and factorization using the
implemented SuperLU relative codes. I thought this will generate the
same results as the First test, but it actually not.
-rhs
/home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin -superlu_default
Norm of error  2.2632E-12 iterations     1
Norm of error  1.0817E+04 iterations     1
Norm of error  1.0786E+04 iterations     1
Norm of error  1.0792E+04 iterations     1
Third, use the Matrix 168 to setup KSP solver and factorization, then
solve 168 to 172
/home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin/a_flow_check_168.bin -rhs
/home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin/b_flow_check_168.bin -loop_matrices
Norm of error  9.5528E-10 iterations     1
Norm of error  9.4945E-10 iterations     1
Norm of error  6.4279E-10 iterations     1
Norm of error  7.4633E-10 iterations     1
Norm of error  7.4863E-10 iterations     1
Norm of error  8.9701E-10 iterations     1
Fourth, use the Matrix 168 to setup KSP solver and factorization using
the implemented SuperLU relative codes. I thought this will generate the
same results as the Third test, but it actually not.
Norm of error  3.7017E-11 iterations     1
Norm of error  3.6420E-11 iterations     1
Norm of error  3.7184E-11 iterations     1
Norm of error  3.6847E-11 iterations     1
Norm of error  3.7883E-11 iterations     1
Norm of error  3.8805E-11 iterations     1
Thanks very much,
Danyang
On 15-12-03 01:59 PM, Hong wrote:
> Danyang :
> Further testing a_flow_check_168.bin,
> ./ex10 -f0
> /Users/Hong/Downloads/matrix_and_rhs_bin/a_flow_check_168.bin -rhs
> /Users/Hong/Downloads/matrix_and_rhs_bin/x_flow_check_168.bin -pc_type
> lu -pc_factor_mat_solver_package superlu -ksp_monitor_true_residual
> -mat_superlu_conditionnumber
>   Recip. condition number = 1.610480e-12
>   0 KSP preconditioned resid norm 6.873340313547e+09 true resid norm
> 7.295020990196e+03 ||r(i)||/||b|| 1.000000000000e+00
>   1 KSP preconditioned resid norm 2.051833296449e-02 true resid norm
> 2.976859070118e-02 ||r(i)||/||b|| 4.080672384793e-06
> Number of iterations =   1
> Residual norm 0.0297686
> condition number of this matrix = 1/1.610480e-12 = 1.e+12,
> i.e., this matrix is ill-conditioned.
> Hong
>     Hi Hong,
>     The binary format of matrix, rhs and solution can be downloaded
>     via the link below.
>     https://www.dropbox.com/s/cl3gfi0s0kjlktf/matrix_and_rhs_bin.tar.gz?dl=0
>     Thanks,
>     Danyang
>     On 15-12-03 10:50 AM, Hong wrote:
>>     Danyang:
>>         To my surprising, solutions from SuperLU at timestep 29 seems
>>         not correct for the first 4 Newton iterations, but the
>>         solutions from iteration solver and MUMPS are correct.
>>         Please find all the matrices, rhs and solutions at timestep
>>         29 via the link below. The data is a bit large so that I just
>>         share it through Dropbox. A piece of matlab code to read
>>         these data and then computer the norm has also been attached.
>>         _https://www.dropbox.com/s/rr8ueysgflmxs7h/results-check.tar.gz?dl=0_
>>     Can you send us matrix in petsc binary format?
>>     e.g., call MatView(M, PETSC_VIEWER_BINARY_(PETSC_COMM_WORLD))
>>     or '-ksp_view_mat binary'
>>     Hong
>>         Below is a summary of the norm from the three solvers at
>>         timestep 29, newton iteration 1 to 5.
>>         Timestep 29
>>         Norm of residual seq 1.661321e-09, superlu 1.657103e+04,
>>         mumps 3.731225e-11
>>         Norm of residual seq 1.753079e-09, superlu 6.675467e+02,
>>         mumps 1.509919e-13
>>         Norm of residual seq 4.914971e-10, superlu 1.236362e-01,
>>         mumps 2.139303e-17
>>         Norm of residual seq 3.532769e-10, superlu 1.304670e-04,
>>         mumps 5.387000e-20
>>         Norm of residual seq 3.885629e-10, superlu 2.754876e-07,
>>         mumps 4.108675e-21
>>         Would anybody please check if SuperLU can solve these
>>         matrices? Another possibility is that something is wrong in
>>         my own code. But so far, I cannot find any problem in my code
>>         since the same code works fine if I using iterative solver or
>>         direct solver MUMPS. But for other cases I have tested,  all
>>         these solvers work fine.
>>         Please let me know if I did not write down the problem clearly.
>>         Thanks,
>>         Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151205/32334f93/attachment.html>
