[petsc-users] SuperLU convergence problem
Hong hzhang at mcs.anl.gov
Thu Dec 3 15:44:57 CST 2015
Danyang:
Using petsc/src/ksp/ksp/examples/tutorials/ex10.c,
I tested a_flow_check_168.bin
mpiexec -n 4 ./ex10 -f0
/Users/Hong/Downloads/matrix_and_rhs_bin/a_flow_check_168.bin -rhs
/Users/Hong/Downloads/matrix_and_rhs_bin/x_flow_check_168.bin -pc_type lu
-pc_factor_mat_solver_package superlu_dist
Number of iterations =   1
Residual norm 1.38302e-05
petsc (sequential) and mumps all give residual norm = 1.e-5.
For 169,
/Users/Hong/Downloads/matrix_and_rhs_bin/a_flow_check_169.bin -rhs
/Users/Hong/Downloads/matrix_and_rhs_bin/x_flow_check_169.bin -pc_type lu
Residual norm 6.83854e-10
For 170, 171, 172, I get
/Users/Hong/Downloads/matrix_and_rhs_bin/a_flow_check_172.bin -rhs
/Users/Hong/Downloads/matrix_and_rhs_bin/x_flow_check_172.bin -pc_type lu
  Residual norm < 1.e-12
Can you use this example test these matrices?
I use superlu_dist-v4.1.
Hong
Hi Hong,
> The binary format of matrix, rhs and solution can be downloaded via the
> link below.
> https://www.dropbox.com/s/cl3gfi0s0kjlktf/matrix_and_rhs_bin.tar.gz?dl=0
> Thanks,
> Danyang
> On 15-12-03 10:50 AM, Hong wrote:
> Danyang:
>> To my surprising, solutions from SuperLU at timestep 29 seems not correct
>> for the first 4 Newton iterations, but the solutions from iteration solver
>> and MUMPS are correct.
>> Please find all the matrices, rhs and solutions at timestep 29 via the
>> link below. The data is a bit large so that I just share it through
>> Dropbox. A piece of matlab code to read these data and then computer the
>> norm has also been attached.
>> *https://www.dropbox.com/s/rr8ueysgflmxs7h/results-check.tar.gz?dl=0
>> <https://www.dropbox.com/s/rr8ueysgflmxs7h/results-check.tar.gz?dl=0>*
> Can you send us matrix in petsc binary format?
> e.g., call MatView(M, PETSC_VIEWER_BINARY_(PETSC_COMM_WORLD))
> or '-ksp_view_mat binary'
> Hong
>> Below is a summary of the norm from the three solvers at timestep 29,
>> newton iteration 1 to 5.
>> Timestep 29
>> Norm of residual seq 1.661321e-09, superlu 1.657103e+04, mumps
>> 3.731225e-11
>> Norm of residual seq 1.753079e-09, superlu 6.675467e+02, mumps
>> 1.509919e-13
>> Norm of residual seq 4.914971e-10, superlu 1.236362e-01, mumps
>> 2.139303e-17
>> Norm of residual seq 3.532769e-10, superlu 1.304670e-04, mumps
>> 5.387000e-20
>> Norm of residual seq 3.885629e-10, superlu 2.754876e-07, mumps
>> 4.108675e-21
>> Would anybody please check if SuperLU can solve these matrices? Another
>> possibility is that something is wrong in my own code. But so far, I cannot
>> find any problem in my code since the same code works fine if I using
>> iterative solver or direct solver MUMPS. But for other cases I have
>> tested,  all these solvers work fine.
>> Please let me know if I did not write down the problem clearly.
>> Thanks,
>> Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151203/63eba366/attachment-0001.html>
