[petsc-users] Petsc Draw to pixmap
Sean Dettrick sdettrick at trialphaenergy.com
Thu Dec 3 02:06:38 CST 2015
No, it is my fault, when I was unable to download from afterstep.org<http://afterstep.org> earlier I didn’t realize that it was probably my work firewall blocking me.  Thus sending me on a wild goose chase with macports and home-brew and github version, which didn’t compile.
But now I’ve tried to follow your advice, and have a new problem.
I installed Afterimage from your suggested site, with suggested X lib flags:
   ./configure --x-includes=/opt/X11/include -x-libraries=/opt/X11/lib
   make
   make install
No errors.  Then re-configured and built petsc:
   export PETSC_DIR=/Users/sdettrick/libs/petsc-3.6.1
   export PETSC_ARCH=mac-gcc-hdf5-mpich-afterimage
  ./configure --with-afterimage --download-hdf5 --download-mpich --PETSC_ARCH=mac-gcc-hdf5-mpich-afterimage --PETSC_DIR=/Users/sdettrick/libs/petsc-3.6.1
   make PETSC_DIR=/Users/sdettrick/libs/petsc-3.6.1 PETSC_ARCH=mac-gcc-hdf5-mpich-afterimage all
No errors.  Then try to run an example with image output:
   cd src/dm/examples/tutorials/
   make ex5
   ./ex5
   ./ex5 -draw_save test.png
The example generates the error you mentioned, which it didn’t before installing afterimage:
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  1 (X_CreateWindow)
  Value in failed request:  0x40
  Serial number of failed request:  7
  Current serial number in output stream:  14
Browsing through configure.log, it seems that petsc is using the same X11 library.
Did I miss something?
Thanks!
Sean
On Dec 2, 2015, at 11:10 PM, Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
 I am such an idiot. No I did build it from source I forgot the comment in afterimage.py
 After image is available from http://www.afterstep.org/afterimage/getcode.php
#  It is used by the PetscDrawSetSave() routine to save X windows graphics to files
#  If installing on an Apple make sure to read the details on PetscDrawSetSave manual
#  page before installing
from that page I found
If X windows generates an error message about X_CreateWindow() failing then Afterimage was installed without X windows. Reinstall Afterimage using the
  ./configure flags --x-includes=/pathtoXincludes --x-libraries=/pathtoXlibraries   For example under Mac OS X Mountain Lion --x-includes=/opt/X11/include -x-libraries=/opt/X11/lib
Did you try all this stuff?
 Barry
On Dec 3, 2015, at 1:00 AM, Sean Dettrick <sdettrick at trialphaenergy.com<mailto:sdettrick at trialphaenergy.com>> wrote:
Hi Barry,
Thanks for the amazingly fast reply.  I installed home-brew but then was unable to find afterstep available as a package.  The closest thing I could find was asterm (after step terminal emulator.  Do you remember if you installed it from a canonical repo?
I did find afterstep on github, but had trouble installing it on the mac.
Meanwhile, a colleague has given me a python script, so I’ll probably use that instead for now.
Thanks again,
Sean
On Dec 2, 2015, at 1:45 PM, Barry Smith <bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>> wrote:
Sean,
I have never been able to build from that source either.
I used homebrew to install it and its worked for several years.
I also tried to see if one could pull the image from the X pixel map and it looked like a huge project (the pixmap stuff is not as trivial as one would think it would be) so I gave up on that and started using afterimage (which essentially does all the for you).
Barry
On Dec 2, 2015, at 3:39 PM, Sean Dettrick <sdettrick at trialphaenergy.com<mailto:sdettrick at trialphaenergy.com>> wrote:
I’d like to have petsc draw output to a pixmap, but have been unable to install afterstep on my Mac.  Direct download of the tar files from http://www.afterstep.org/afterimage/getcode.php failed, as did cvs checkout.  It seems the target sites may not exist at present.
Is there another way to install afterstep?
Alternatively, is there a way to manually redirect the X11 output using something like XCreatePixmap?
Thanks!
Sean Dettrick
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151203/f66b6eda/attachment.html>
