[petsc-users] Petsc Draw to pixmap
Wed Dec 2 15:45:00 CST 2015
   Sean,
   I have never been able to build from that source either.
   I used homebrew to install it and its worked for several years.
   I also tried to see if one could pull the image from the X pixel map and it looked like a huge project (the pixmap stuff is not as trivial as one would think it would be) so I gave up on that and started using afterimage (which essentially does all the for you).
   Barry
> On Dec 2, 2015, at 3:39 PM, Sean Dettrick <sdettrick at trialphaenergy.com> wrote:
> Hi,
> I’d like to have petsc draw output to a pixmap, but have been unable to install afterstep on my Mac.  Direct download of the tar files from http://www.afterstep.org/afterimage/getcode.php failed, as did cvs checkout.  It seems the target sites may not exist at present.
> Is there another way to install afterstep?
> Alternatively, is there a way to manually redirect the X11 output using something like XCreatePixmap?
> Thanks!
> Sean Dettrick
