[petsc-users] MatCreateShell with VecCreateGhost
Tue Dec 1 19:00:46 CST 2015
  Sorry, I could not control myself.
  So long as you pass vectors created with VecCreateGhost() to KSPSolve() the vectors passed to the multiply inside the solver will also be ghosted vectors.
   Send all output messages etc if it doesn't work for you
  Barry
> On Dec 1, 2015, at 6:47 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Dec 1, 2015, at 5:18 PM, Bikash Kanungo <bikash at umich.edu> wrote:
>> Hi,
>> I want to implement a matrix-free KSP solve using user-defined MATOP_MULT and MATOP_MULT_TRANSPOSE. Each of these user-defined functions take in  Mat A, Vec x and Vec y as arguments and store A*x in y. To perform A*x in the user defined fashion, each processor requires access to some non-local nodes of x. So, is there a way I can create these two vectors (x and y) using VecCreateGhost?
>   Yes, use VecCreateGhost().
>   Barry
>> Thanks,
>> Bikash
>> Bikash S. Kanungo
>> PhD Student
>> Computational Materials Physics Group
>> Mechanical Engineering
>> University of Michigan
