[petsc-users] Output newton step
Alex Lindsay adlinds3 at ncsu.edu
Tue Dec 1 13:22:54 CST 2015
Thanks Barry that helps a lot. It looks like the defaults for me (PetSc
3.6.0 release) are stdout for -ksp_view_solution and draw for
-snes_monitor_solution_update. I don't see any binary files generated
with the defaults.
On 11/30/2015 05:56 PM, Barry Smith wrote:
>> On Nov 30, 2015, at 2:19 PM, Alex Lindsay <adlinds3 at ncsu.edu> wrote:
>> Is there an option for outputting the Newton step after my linear solve?
>> Alex
>     Do you want the solution of the linear system before the line search (line search may shrink the vector) use -ksp_view_solution or the actual update selected by Newton -snes_monitor_solution_update
>     If you use the master branch of PETSc then both of these flags take the option
>      [ascii or binary or draw][:filename][:viewer format]
>    allowing printing as ascii, binary or drawing the solution in a window (Drawing only works for DMDA 1d or 2d).
>     Barry
>    For the release version of PETSc it saves the vectors in a binary file called binaryoutput
