[petsc-users] DMPlex: Ghost points after DMRefine
Morten Nobel-Jørgensen mono at mek.dtu.dk
Tue Dec 1 10:51:10 CST 2015
I found a solution to my problem by using the global section instead. I still don’t quite understand what my problem ISLocalToGlobalMapping was.
> Yes, that is the solution I use.
Thanks – good to hear that I’m on the right track :)
> I think I ignore nonlocal indices in the l2g mapping rather than making them negative. This can of course be changed.
Ok
- Morten
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151201/e32cd5dd/attachment.html>
