[petsc-users] Integrating TAO into SNES and TS
Justin Chang jychang48 at gmail.com
Mon Aug 31 19:36:02 CDT 2015
Coming back to this,
Say I now want to ensure the DMP for advection-diffusion equations. The
linear operator is now asymmetric and non-self-adjoint (assuming I do
something like SUPG or finite volume), meaning I cannot simply solve this
problem without any manipulation (e.g. normalizing the equations) using
TAO's optimization solvers. Does this statement also hold true for SNESVI?
Justin
On Fri, Apr 3, 2015 at 7:38 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Apr 3, 2015, at 7:35 PM, Justin Chang <jchang27 at uh.edu> wrote:
> > I guess I will have to write my own code then :)
> > I am not all that familiar with Variational Inequalities at the moment,
> but if my Jacobian is symmetric and positive definite and I only have lower
> and upper bounds, doesn't the problem simply reduce to that of a convex
> optimization? That is, with SNES act as if it were Tao?
>   Yes, I think that is essentially correctly.
>   Barry
> > On Fri, Apr 3, 2015 at 6:35 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Justin,
> >    We haven't done anything with TS to handle variational inequalities.
> So you can either write your own backward Euler (outside of TS) that solves
> each time-step problem either as 1) an optimization problem using Tao or 2)
> as a variational inequality using SNES.
> >    More adventurously you could look at the TSTHETA code in TS (which is
> a general form that includes Euler, Backward Euler and Crank-Nicolson and
> see if you can add the constraints to the SNES problem that is solved; in
> theory this is straightforward but it would require understanding the
> current code (which Jed, of course, overwrote :-). I think you should do
> this.
> >   Barry
> > > On Apr 3, 2015, at 12:31 PM, Justin Chang <jchang27 at uh.edu> wrote:
> > > I am solving the following anisotropic transient diffusion equation
> subject to 0 bounds:
> > > du/dt = div[D*grad[u]] + f
> > > Where the dispersion tensor D(x) is symmetric and positive definite.
> This formulation violates the discrete maximum principles so one of the
> ways to ensure nonnegative concentrations is to employ convex optimization.
> I am following the procedures in Nakshatrala and Valocchi (2009) JCP and
> Nagarajan and Nakshatrala (2011) IJNMF.
> > > The Variational Inequality method works gives what I want for my
> transient case, but what if I want to implement the Tao methodology in TS?
> That is, what TS functions do I need to set up steps a) through e) for each
> time step (also the Jacobian remains the same for all time steps so I would
> only call this once). Normally I would just call TSSolve() and let the
> libraries and functions do everything, but I would like to incorporate
> TaoSolve into every time step.
> > > Thanks,
> > > Justin Chang
> > > PhD Candidate, Civil Engineering - Computational Sciences
> > > University of Houston, Department of Civil and Environmental
> Engineering
> > > Houston, TX 77004
> > > (512) 963-3262
> > > On Thu, Apr 2, 2015 at 6:53 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > >   An alternative approach is for you to solve it as a (non)linear
> variational inequality. See src/snes/examples/tutorials/ex9.c
> > >   How you should proceed depends on your long term goal. What problem
> do you really want to solve? Is it really a linear time dependent problem
> with 0 bounds on U? Can the problem always be represented as an
> optimization problem easily? What are  and what will be the properties of
> K? For example if K is positive definite then likely the bounds will remain
> try without explicitly providing the constraints.
> > >   Barry
> > > > On Apr 2, 2015, at 6:39 PM, Justin Chang <jchang27 at uh.edu> wrote:
> > > > Hi everyone,
> > > > I have a two part question regarding the integration of the
> following optimization problem
> > > > min 1/2 u^T*K*u + u^T*f
> > > > S.T. u >= 0
> > > > into SNES and TS
> > > > 1) For SNES, assuming I am working with a linear FE equation, I have
> the following algorithm/steps for solving my problem
> > > > a) Set an initial guess x
> > > > b) Obtain residual r and jacobian A through functions
> SNESComputeFunction() and SNESComputeJacobian() respectively
> > > > c) Form vector b = r - A*x
> > > > d) Set Hessian equal to A, gradient to A*x, objective function value
> to 1/2*x^T*A*x + x^T*b, and variable (lower) bounds to a zero vector
> > > > e) Call TaoSolve
> > > > This works well at the moment, but my question is there a more
> "efficient" way of doing this? Because with my current setup, I am making a
> rather bold assumption that my problem would converge in one SNES iteration
> without the bounded constraints and does not have any unexpected
> nonlinearities.
> > > > 2) How would I go about doing the above for time-stepping problems?
> At each time step, I want to solve a convex optimization subject to the
> lower bounds constraint. I plan on using backward euler and my resulting
> jacobian should still be compatible with the above optimization problem.
> > > > Thanks,
> > > > Justin Chang
> Engineering
> > > > Houston, TX 77004
> > > > (512) 963-3262
> > > Justin Chang
> Engineering
> > > Houston, TX 77004
> > > (512) 963-3262
> > Justin Chang
> > University of Houston, Department of Civil and Environmental Engineering
> > Houston, TX 77004
> > (512) 963-3262
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150831/a9446cd9/attachment-0001.html>
