[petsc-users] Increasing nodes doesn't decrease memory per node.
Hank Lamm hanklammiv at gmail.com
Mon Aug 31 14:50:48 CDT 2015
If I use MatView to check the type of my matrix, it replies mpiaij, not
seqaij.  Am I correct in understanding your comments to mean that the
reason for the error that when I do the spectrum slicing, it is creating
seqaij for each processor?
On Sat, Aug 29, 2015 at 12:55 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> You are doing a spectrum slicing run (EPSSetInterval) with “size”
> partitions (EPSKrylovSchurSetPartitions), so every single process will be
> in charge of computing a subinterval. Each subcommunicator needs a
> redundant copy of the matrix, and in this case this copy is SeqAIJ since
> subcommunicators consist in just one process. You will probably need to
> share this memory across a set of processes and use MUMPS for the
> factorization. Try setting e.g. size/8 partitions.
> Jose
> > El 29/8/2015, a las 1:14, Barry Smith <bsmith at mcs.anl.gov> escribió:
> >  It is using a SeqAIJ matrix, not a parallel matrix. Increasing the
> number of cores won't affect the size of a sequential matrix since it must
> be stored entirely on one process.  Perhaps you need to use parallel
> matrices?
> > [1]PETSC ERROR: #4 MatDuplicate_SeqAIJ() line 4103 in
> /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/mat/impls/aij/seq/aij.c
> > [1]PETSC ERROR: #5 MatDuplicate() line 4252 in
> /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/mat/interface/matrix.c
> >> On Aug 28, 2015, at 4:13 PM, Hank Lamm <hanklammiv at gmail.com> wrote:
> >> Hi All,
> >> I am having a problem running Petsc3.6 and Slepc3.6 on Stampede.  My
> code should be a simple eigenvalue solver, but when I attempt to solve
> large problems (8488x8488 matrices) I get errors:
> >> --------------------- Error Message
> >> [1]Total space allocated 1736835920 bytes
> >> [1]PETSC ERROR: Out of memory. This could be due to allocating
> >> [1]PETSC ERROR: too large an object or bleeding by not properly
> >> [1]PETSC ERROR: destroying unneeded objects.
> >> [1]PETSC ERROR: Memory allocated 1736835920 Memory used by process
> 1769742336
> >> [1]PETSC ERROR: [0]PETSC ERROR: Memory requested 864587796
> >> [1]PETSC ERROR: [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> >> [1]PETSC ERROR: #8 STSetUp() line 305 in
> /work/03324/hlammiv/slepc-3.6.0/src/sys/classes/st/interface/stsolve.c
> >> [1]PETSC ERROR: [0]PETSC ERROR: #1 MatDuplicateNoCreate_SeqAIJ() line
> 4030 in
> >> [1]PETSC ERROR: #2 PetscTrMallocDefault() line 188 in
> /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/sys/memory/mtr.c
> >> [1]PETSC ERROR: #6 STMatMAXPY_Private() line 379 in
> >> [1]PETSC ERROR: #7 STSetUp_Sinvert() line 131 in
> /work/03324/hlammiv/slepc-3.6.0/src/sys/classes/st/impls/sinvert/sinvert.c
> >> [1]PETSC ERROR: #9 EPSSliceGetInertia() line 295 in
> /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/ks-slice.c
> >> [1]PETSC ERROR: #10 EPSSetUp_KrylovSchur_Slice() line 425 in
> >> [1]PETSC ERROR: #11 EPSSetUp_KrylovSchur() line 89 in
> /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/krylovschur.c
> >> [1]PETSC ERROR: #12 EPSSetUp() line 121 in
> /work/03324/hlammiv/slepc-3.6.0/src/eps/interface/epssetup.c
> >> [1]PETSC ERROR: #13 EPSSliceGetEPS() line 267 in
> >> [1]PETSC ERROR: #14 EPSSetUp_KrylovSchur_Slice() line 368 in
> >> [1]PETSC ERROR: #15 EPSSetUp_KrylovSchur() line 89 in
> >> [1]PETSC ERROR: #16 EPSSetUp() line 121 in
> >> [1]PETSC ERROR: #17 EPSSolve() line 88 in
> /work/03324/hlammiv/slepc-3.6.0/src/eps/interface/epssolve.c
> >> [1]PETSC ERROR: #18 eigensolver() line 64 in
> /work/03324/hlammiv/TMSWIFT/src/solver.cpp
> >> [1]Current space PetscMalloc()ed 1.73683e+09, max space PetscMalloced()
> 1.73684e+09
> >> [1]Current process memory 1.76979e+09 max process memory 1.76979e+09
> >> The curious thing about this error, is that it seems that if I increase
> the number of nodes, from 32 to 64 to 128, the amount of memory per node
> doesn't decrease.  I have used valgrind and it doesn't seem to a memory
> leak.
> >> The relevant code piece is:
> >> void eigensolver(PetscErrorCode ierr, params *params, Mat &H, int argc,
> char **argv)
> >>    EPS        eps;             /* eigenproblem solver context */
> >>      EPSType        type;
> >>      ST             st;
> >>    KSP            ksp;
> >>      PC             pc;
> >>    PetscReal    tol,error;
> >>    PetscReal    lower,upper;
> >>      //PetscInt       nev=dim,maxit,its;
> >>      PetscInt           nev,maxit,its,nconv;
> >>      Vec                xr,xi;
> >>      PetscScalar       kr,ki;
> >>    PetscReal     re,im;
> >>      PetscViewer        viewer;
> >>    PetscInt rank;
> >>    PetscInt size;
> >>    std::string eig_file_n;
> >>    std::ofstream eig_file;
> >>    char ofile[100];
> >>        MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
> >>        MPI_Comm_size(PETSC_COMM_WORLD,&size);
> >>      ierr = PetscPrintf(PETSC_COMM_WORLD,"---Beginning Eigenvalue
> Solver---\n");CHKERRV(ierr);
> >>     ierr = EPSCreate(PETSC_COMM_WORLD,&eps);CHKERRV(ierr);
> >>        eig_file_n.append(params->ofile_n);
> >>        eig_file_n.append("_eval");
> >>        eig_file.open(eig_file_n.c_str(),std::ofstream::trunc);
> >>    //Set operators. In this case, it is a standard eigenvalue problem
> >>    ierr = EPSSetOperators(eps,H,NULL);CHKERRV(ierr);
> >>    ierr = EPSSetProblemType(eps,EPS_HEP);CHKERRV(ierr);
> >>    ierr = EPSSetType(eps,EPSKRYLOVSCHUR);CHKERRV(ierr);
> >>      ierr = EPSGetST(eps,&st);CHKERRV(ierr);
> >>      ierr = STSetType(st,STSINVERT);CHKERRV(ierr);
> >>      ierr = STGetKSP(st,&ksp);CHKERRV(ierr);
> >>      ierr = KSPSetType(ksp,KSPPREONLY);CHKERRV(ierr);
> >>      ierr = KSPGetPC(ksp,&pc);CHKERRV(ierr);
> >>      ierr = PCSetType(pc,PCCHOLESKY);CHKERRV(ierr);
> >>    ierr = EPSKrylovSchurSetPartitions(eps,size);CHKERRV(ierr);
> >>    for(PetscInt i=0;i<params->nf;i++){
> lower=std::pow(2.0*params->m[i]-params->m[i]*params->alpha*params->alpha,2.0);
> >>    upper=4.0*params->m[i]*params->m[i];
> >>    ierr = EPSSetInterval(eps,lower,upper);
> >>    ierr = EPSSetWhichEigenpairs(eps,EPS_ALL);
> >>        //Set solver parameters at runtime
> >>      ierr = EPSSetFromOptions(eps);CHKERRV(ierr);
> >> //     ierr = EPSSetWhichEigenpairs(eps,EPS_SMALLEST_REAL);
> >>    ierr = MatCreateVecs(H,NULL,&xr);CHKERRV(ierr);
> >>    ierr = MatCreateVecs(H,NULL,&xi);CHKERRV(ierr);
> >>       ierr = EPSSolve(eps);CHKERRV(ierr);
> >>       ierr = EPSGetIterationNumber(eps,&its);CHKERRV(ierr);
> >>      ierr = PetscPrintf(PETSC_COMM_WORLD," Number of iterations of the
> method: %D\n",its);CHKERRV(ierr);
> >>       //Optional: Get some information from the solver and display it
> >>      ierr = EPSGetType(eps,&type);CHKERRV(ierr);
> >>      ierr = PetscPrintf(PETSC_COMM_WORLD," Solution method:
> %s\n\n",type);CHKERRV(ierr);
> >>      ierr = EPSGetDimensions(eps,&nev,NULL,NULL);CHKERRV(ierr);
> >>      ierr = PetscPrintf(PETSC_COMM_WORLD," Number of requested
> eigenvalues: %D\n",nev);CHKERRV(ierr);
> >>      ierr = EPSGetTolerances(eps,&tol,&maxit);CHKERRV(ierr);
> >>      ierr = PetscPrintf(PETSC_COMM_WORLD," Stopping condition:
> tol=%.4g, maxit=%D\n",tol,maxit);CHKERRV(ierr);
> >>    ierr = EPSGetConverged(eps,&nconv);CHKERRV(ierr);
> >>      ierr = PetscPrintf(PETSC_COMM_WORLD," Number of converged
> eigenpairs: %D\n\n",nconv);CHKERRV(ierr);
> >>    strcpy(ofile,params->ofile_n);
> >>          strcat(ofile,"_evecr");
> >>        ierr =
> PetscViewerASCIIOpen(PETSC_COMM_WORLD,ofile,&viewer);CHKERRV(ierr);
> >>    if (nconv>0)
> >>                 "           k          ||Ax-kx||/||kx||\n"
> ------------------\n");CHKERRV(ierr);
> >>        for (PetscInt i=0;i<nconv;i++)
> >>            //Get converged eigenpairs: i-th eigenvalue is stored in kr
> (real part) and ki (imaginary part)
> >>                  ierr =
> EPSGetEigenpair(eps,i,&kr,&ki,xr,xi);CHKERRV(ierr);
> >>                 //Compute the relative error associated to each
> eigenpair
> >>                 ierr =
> EPSComputeError(eps,i,EPS_ERROR_RELATIVE,&error);CHKERRV(ierr);
> >>            #if defined(PETSC_USE_COMPLEX)
> >>                      re = PetscRealPart(kr);
> >>                      im = PetscImaginaryPart(kr);
> >>            #else
> >>                      re = kr;
> >>                      im = ki;
> >>            #endif
> >>                  if (im!=0.0)
> >>                ierr = PetscPrintf(PETSC_COMM_WORLD," %9f%+9f j
> %12g\n",re,im,error);CHKERRV(ierr);
> >>                if(rank==0) eig_file << re << " " << im << " " << error
> << std::endl;
> >>            } else
> >>                    ierr = PetscPrintf(PETSC_COMM_WORLD,"   %12f
>  %12g\n",re,error);CHKERRV(ierr);
> >>                if(rank==0) eig_file << re << " " << 0 << " " << error
> << std::endl;
> >>                        ierr = VecView(xr,viewer);CHKERRV(ierr);
> >>            ierr = PetscPrintf(PETSC_COMM_WORLD,"\n");CHKERRV(ierr);
> >>    eig_file.close();
> >>    ierr = EPSDestroy(&eps);CHKERRV(ierr);
> >>    ierr = PetscViewerDestroy(&viewer);CHKERRV(ierr);
> >>    ierr = VecDestroy(&xr);CHKERRV(ierr);
> >>    ierr = VecDestroy(&xi);CHKERRV(ierr);
> >>      ierr = PetscPrintf(PETSC_COMM_WORLD,"---Finishing Eigenvalue
> >> Thanks,
> >> Hank
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150831/12079b6b/attachment.html>
