[petsc-users] Increasing nodes doesn't decrease memory per node.
Fri Aug 28 18:14:40 CDT 2015
  It is using a SeqAIJ matrix, not a parallel matrix. Increasing the number of cores won't affect the size of a sequential matrix since it must be stored entirely on one process.  Perhaps you need to use parallel matrices?
[1]PETSC ERROR: #4 MatDuplicate_SeqAIJ() line 4103 in /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/mat/impls/aij/seq/aij.c
[1]PETSC ERROR: #5 MatDuplicate() line 4252 in /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/mat/interface/matrix.c
> On Aug 28, 2015, at 4:13 PM, Hank Lamm <hanklammiv at gmail.com> wrote:
> Hi All,
> I am having a problem running Petsc3.6 and Slepc3.6 on Stampede.  My code should be a simple eigenvalue solver, but when I attempt to solve large problems (8488x8488 matrices) I get errors:
> --------------------- Error Message --------------------------------------------------------------
> [1]Total space allocated 1736835920 bytes
> [1]PETSC ERROR: Out of memory. This could be due to allocating
> [1]PETSC ERROR: too large an object or bleeding by not properly
> [1]PETSC ERROR: destroying unneeded objects.
> [1]PETSC ERROR: Memory allocated 1736835920 Memory used by process 1769742336
> [1]PETSC ERROR: [0]PETSC ERROR: Memory requested 864587796
> [1]PETSC ERROR: [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [1]PETSC ERROR: #8 STSetUp() line 305 in /work/03324/hlammiv/slepc-3.6.0/src/sys/classes/st/interface/stsolve.c
> [1]PETSC ERROR: [0]PETSC ERROR: #1 MatDuplicateNoCreate_SeqAIJ() line 4030 in /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/mat/impls/aij/seq/aij.c
> [1]PETSC ERROR: #2 PetscTrMallocDefault() line 188 in /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/sys/memory/mtr.c
> [1]PETSC ERROR: #6 STMatMAXPY_Private() line 379 in /work/03324/hlammiv/slepc-3.6.0/src/sys/classes/st/interface/stsolve.c
> [1]PETSC ERROR: #7 STSetUp_Sinvert() line 131 in /work/03324/hlammiv/slepc-3.6.0/src/sys/classes/st/impls/sinvert/sinvert.c
> [1]PETSC ERROR: #9 EPSSliceGetInertia() line 295 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/ks-slice.c
> [1]PETSC ERROR: #10 EPSSetUp_KrylovSchur_Slice() line 425 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/ks-slice.c
> [1]PETSC ERROR: #11 EPSSetUp_KrylovSchur() line 89 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/krylovschur.c
> [1]PETSC ERROR: #12 EPSSetUp() line 121 in /work/03324/hlammiv/slepc-3.6.0/src/eps/interface/epssetup.c
> [1]PETSC ERROR: #13 EPSSliceGetEPS() line 267 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/ks-slice.c
> [1]PETSC ERROR: #14 EPSSetUp_KrylovSchur_Slice() line 368 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/ks-slice.c
> [1]PETSC ERROR: #15 EPSSetUp_KrylovSchur() line 89 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/krylovschur.c
> [1]PETSC ERROR: #16 EPSSetUp() line 121 in /work/03324/hlammiv/slepc-3.6.0/src/eps/interface/epssetup.c
> [1]PETSC ERROR: #17 EPSSolve() line 88 in /work/03324/hlammiv/slepc-3.6.0/src/eps/interface/epssolve.c
> [1]PETSC ERROR: #18 eigensolver() line 64 in /work/03324/hlammiv/TMSWIFT/src/solver.cpp
> [1]Current space PetscMalloc()ed 1.73683e+09, max space PetscMalloced() 1.73684e+09
> [1]Current process memory 1.76979e+09 max process memory 1.76979e+09
> The curious thing about this error, is that it seems that if I increase the number of nodes, from 32 to 64 to 128, the amount of memory per node doesn't decrease.  I have used valgrind and it doesn't seem to a memory leak.
> The relevant code piece is:
> void eigensolver(PetscErrorCode ierr, params *params, Mat &H, int argc, char **argv)
>     EPS        eps;             /* eigenproblem solver context */
>       EPSType        type;
>       ST             st;
>     KSP            ksp;
>       PC             pc;
>     PetscReal    tol,error;
>     PetscReal    lower,upper;
>       //PetscInt       nev=dim,maxit,its;
>       PetscInt           nev,maxit,its,nconv;
>       Vec                xr,xi;
>       PetscScalar       kr,ki;
>     PetscReal     re,im;
>       PetscViewer        viewer;
>     PetscInt rank;
>     PetscInt size;
>     std::string eig_file_n;
>     std::ofstream eig_file;
>     char ofile[100];
>         MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>         MPI_Comm_size(PETSC_COMM_WORLD,&size);
>       ierr = PetscPrintf(PETSC_COMM_WORLD,"---Beginning Eigenvalue Solver---\n");CHKERRV(ierr);
>      ierr = EPSCreate(PETSC_COMM_WORLD,&eps);CHKERRV(ierr);
>         eig_file_n.append(params->ofile_n);
>         eig_file_n.append("_eval");
>         eig_file.open(eig_file_n.c_str(),std::ofstream::trunc);
>     //Set operators. In this case, it is a standard eigenvalue problem
>     ierr = EPSSetOperators(eps,H,NULL);CHKERRV(ierr);
>     ierr = EPSSetProblemType(eps,EPS_HEP);CHKERRV(ierr);
>     ierr = EPSSetType(eps,EPSKRYLOVSCHUR);CHKERRV(ierr);
>       ierr = EPSGetST(eps,&st);CHKERRV(ierr);
>       ierr = STSetType(st,STSINVERT);CHKERRV(ierr);
>       ierr = STGetKSP(st,&ksp);CHKERRV(ierr);
>       ierr = KSPSetType(ksp,KSPPREONLY);CHKERRV(ierr);
>       ierr = KSPGetPC(ksp,&pc);CHKERRV(ierr);
>       ierr = PCSetType(pc,PCCHOLESKY);CHKERRV(ierr);
>     ierr = EPSKrylovSchurSetPartitions(eps,size);CHKERRV(ierr);
>     for(PetscInt i=0;i<params->nf;i++){
>     lower=std::pow(2.0*params->m[i]-params->m[i]*params->alpha*params->alpha,2.0);
>     upper=4.0*params->m[i]*params->m[i];
>     ierr = EPSSetInterval(eps,lower,upper);
>     ierr = EPSSetWhichEigenpairs(eps,EPS_ALL);
>         //Set solver parameters at runtime
>       ierr = EPSSetFromOptions(eps);CHKERRV(ierr);
> //     ierr = EPSSetWhichEigenpairs(eps,EPS_SMALLEST_REAL);
>     ierr = MatCreateVecs(H,NULL,&xr);CHKERRV(ierr);
>     ierr = MatCreateVecs(H,NULL,&xi);CHKERRV(ierr);
>        ierr = EPSSolve(eps);CHKERRV(ierr);
>        ierr = EPSGetIterationNumber(eps,&its);CHKERRV(ierr);
>       ierr = PetscPrintf(PETSC_COMM_WORLD," Number of iterations of the method: %D\n",its);CHKERRV(ierr);
>        //Optional: Get some information from the solver and display it
>       ierr = EPSGetType(eps,&type);CHKERRV(ierr);
>       ierr = PetscPrintf(PETSC_COMM_WORLD," Solution method: %s\n\n",type);CHKERRV(ierr);
>       ierr = EPSGetDimensions(eps,&nev,NULL,NULL);CHKERRV(ierr);
>       ierr = PetscPrintf(PETSC_COMM_WORLD," Number of requested eigenvalues: %D\n",nev);CHKERRV(ierr);
>       ierr = EPSGetTolerances(eps,&tol,&maxit);CHKERRV(ierr);
>       ierr = PetscPrintf(PETSC_COMM_WORLD," Stopping condition: tol=%.4g, maxit=%D\n",tol,maxit);CHKERRV(ierr);
>     ierr = EPSGetConverged(eps,&nconv);CHKERRV(ierr);
>       ierr = PetscPrintf(PETSC_COMM_WORLD," Number of converged eigenpairs: %D\n\n",nconv);CHKERRV(ierr);
>     strcpy(ofile,params->ofile_n);
>           strcat(ofile,"_evecr");
>         ierr = PetscViewerASCIIOpen(PETSC_COMM_WORLD,ofile,&viewer);CHKERRV(ierr);
>     if (nconv>0)
>                  "           k          ||Ax-kx||/||kx||\n"
>                  "   ----------------- ------------------\n");CHKERRV(ierr);
>         for (PetscInt i=0;i<nconv;i++)
>             //Get converged eigenpairs: i-th eigenvalue is stored in kr (real part) and ki (imaginary part)
>                   ierr = EPSGetEigenpair(eps,i,&kr,&ki,xr,xi);CHKERRV(ierr);
>                  //Compute the relative error associated to each eigenpair
>                  ierr = EPSComputeError(eps,i,EPS_ERROR_RELATIVE,&error);CHKERRV(ierr);
>             #if defined(PETSC_USE_COMPLEX)
>                       re = PetscRealPart(kr);
>                       im = PetscImaginaryPart(kr);
>             #else
>                       re = kr;
>                       im = ki;
>             #endif
>                   if (im!=0.0)
>                 ierr = PetscPrintf(PETSC_COMM_WORLD," %9f%+9f j %12g\n",re,im,error);CHKERRV(ierr);
>                 if(rank==0) eig_file << re << " " << im << " " << error << std::endl;
>             } else
>                     ierr = PetscPrintf(PETSC_COMM_WORLD,"   %12f       %12g\n",re,error);CHKERRV(ierr);
>                 if(rank==0) eig_file << re << " " << 0 << " " << error << std::endl;
>                         ierr = VecView(xr,viewer);CHKERRV(ierr);
>             ierr = PetscPrintf(PETSC_COMM_WORLD,"\n");CHKERRV(ierr);
>     eig_file.close();
>     ierr = EPSDestroy(&eps);CHKERRV(ierr);
>     ierr = PetscViewerDestroy(&viewer);CHKERRV(ierr);
>     ierr = VecDestroy(&xr);CHKERRV(ierr);
>     ierr = VecDestroy(&xi);CHKERRV(ierr);
>       ierr = PetscPrintf(PETSC_COMM_WORLD,"---Finishing Eigenvalue Solver---\n");CHKERRV(ierr);
> Thanks,
> Hank
