[petsc-users] pcfieldsplit for a composite dm with multiple subfields
Gideon Simpson gideon.simpson at gmail.com
Thu Aug 27 22:56:05 CDT 2015
Ok, it seems to work with that switch, however, when I try to use DM sequence, I get errors like:
      0 SNES Function norm 5.067205249874e-03
      1 SNES Function norm 7.983917252341e-08
      2 SNES Function norm 7.291012540201e-11
    0 SNES Function norm 2.228951406196e+02
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: New nonzero at (0,3) caused a malloc
Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.5.3, unknown
[0]PETSC ERROR: ./blowup_batch2 on a arch-macports named gs_air by gideon Thu Aug 27 23:53:19 2015
[0]PETSC ERROR: Configure options --prefix=/opt/local --prefix=/opt/local/lib/petsc --with-valgrind=0 --with-shared-libraries --with-debugging=0 --with-c2html-dir=/opt/local --with-x=0 --with-blas-lapack-lib=/System/Library/Frameworks/Accelerate.framework/Versions/Current/Accelerate --with-hwloc-dir=/opt/local --with-suitesparse-dir=/opt/local --with-superlu-dir=/opt/local --with-metis-dir=/opt/local --with-parmetis-dir=/opt/local --with-scalapack-dir=/opt/local --with-mumps-dir=/opt/local --with-superlu_dist-dir=/opt/local CC=/opt/local/bin/mpicc-mpich-mp CXX=/opt/local/bin/mpicxx-mpich-mp FC=/opt/local/bin/mpif90-mpich-mp F77=/opt/local/bin/mpif90-mpich-mp F90=/opt/local/bin/mpif90-mpich-mp COPTFLAGS=-Os CXXOPTFLAGS=-Os FOPTFLAGS=-Os LDFLAGS="-L/opt/local/lib -Wl,-headerpad_max_install_names" CPPFLAGS=-I/opt/local/include CFLAGS="-Os -arch x86_64" CXXFLAGS=-Os FFLAGS=-Os FCFLAGS=-Os F90FLAGS=-Os PETSC_ARCH=arch-macports --with-mpiexec=mpiexec-mpich-mp
[0]PETSC ERROR: #1 MatSetValues_SeqAIJ() line 487 in /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.3/src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: #2 MatSetValues() line 1135 in /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.3/src/mat/interface/matrix.c
[0]PETSC ERROR: New nonzero at (1,4) caused a malloc
[0]PETSC ERROR: #3 MatSetValues_SeqAIJ() line 487 in /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.3/src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: #4 MatSetValues() line 1135 in /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.3/src/mat/interface/matrix.c
And in my main program, I did set
    MatSetOption(J, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE);
for the Jacobian.
-gideon
> On Aug 27, 2015, at 11:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Aug 27, 2015, at 10:15 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>> That’s correct, I am not using the SNESGetDM.  I suppose I could.  Keep in mind that I’m trying to solve, simultaneously, for the scalar parameters and the vector field.  I guess what I am unclear about is how DMRefine is to know that the unknown associated with the scalar parameters can never be coarsened out, but must be retained at all iterations.
>    Nothing ever gets coarsened in grid sequencing, it only gets refined.
>    The reason it knows not to "refine" the scalars is because the scalars are created with DMRedundant and the DMRedundant object knows that refinement means "leave as is, since there is no grid" while the DMDA knows it is a grid and knows how to refine itself. So when it "interpolates" the DMRedundant variables it just copies them (or multiples them by the matrix 1 which is just a copy).
>> Here is my form function.  I can send more code if needed.
>  Just change the user->packer that you use to be the DM obtained with SNESGetDM()
>> /* Form the system of equations for computing a blowup solution*/
>> PetscErrorCode form_function(SNES snes, Vec U, Vec F, void *ctx){
>> blowup_ctx *user = (blowup_ctx *) ctx;
>> PetscInt i;
>> PetscScalar dx, dx2, xmax,x;
>> PetscScalar u, v, f,g, ux, vx, uxx, vxx, fx,gx, fxx, gxx;
>> DMDALocalInfo info;
>> Vec p_vec, Q_vec, Fp_vec, FQ_vec;
>> PetscScalar *p_array, *Fp_array;
>> Q *Qvals, *FQvals;
>> PetscScalar Q2sig, W2sig;
>> PetscScalar a,a2, b, u0, sigma;
>> dx = user->dx; dx2 = dx *dx;
>> xmax = user->xmax;
>> sigma = user->sigma;
>> /* PetscPrintf(PETSC_COMM_SELF, " dx = %g, sigma = %g\n", dx, sigma);  */
>> /* Extract raw arrays */
>> DMCompositeGetLocalVectors(user->packer, &p_vec, &Q_vec);
>> DMCompositeGetLocalVectors(user->packer, &Fp_vec, &FQ_vec);
>> DMCompositeScatter(user->packer, U, p_vec, Q_vec);
>> /* VecView(Q_vec, 	PETSC_VIEWER_STDOUT_SELF); */
>> VecGetArray(p_vec,&p_array);
>> VecGetArray(Fp_vec,&Fp_array);
>> DMDAVecGetArray(user->Q_dm, Q_vec, &Qvals);
>> DMDAVecGetArray(user->Q_dm, FQ_vec, &FQvals);
>> DMDAGetLocalInfo(user->Q_dm, &info);
>> a = p_array[0]; a2 = a*a;
>> b = p_array[1];
>> u0 = p_array[2];
>> /* Set boundary conditions at the origin*/
>> if(info.xs ==0){
>>   set_origin_bcs(u0, Qvals);
>> /* Set boundray conditions in the far field */
>> if(info.xs+ info.xm == info.mx){
>>   set_farfield_bcs(xmax,sigma, a,  b,  dx, Qvals,info.mx);
>> /* Solve auxiliary equations */
>> if(info.xs ==0){
>>   uxx = (2 * Qvals[0].u-2 * u0)/dx2;
>>   vxx = (Qvals[0].v + Qvals[0].g)/dx2;
>>   vx = (Qvals[0].v - Qvals[0].g)/(2*dx);
>>   Fp_array[0] = Qvals[0].u - Qvals[0].f;
>>   Fp_array[1] = -vxx - (1/a) * (.5/sigma) * u0;
>>   Fp_array[2] = -uxx + (1/a2) * u0
>>     + (1/a) * (-b * vx + PetscPowScalar(u0 * u0, sigma) * vx);
>> /* Solve equations in the bulk */
>> for(i=info.xs; i < info.xs + info.xm;i++){
>>   u = Qvals[i].u;
>>   v = Qvals[i].v;
>>   f = Qvals[i].f;
>>   g = Qvals[i].g;
>>   x = (i+1) * dx;
>>   Q2sig = PetscPowScalar(u*u + v*v,sigma);
>>   W2sig= PetscPowScalar(f*f + g*g, sigma);
>>   ux = (Qvals[i+1].u-Qvals[i-1].u)/(2*dx);
>>   vx = (Qvals[i+1].v-Qvals[i-1].v)/(2*dx);
>>   fx = (Qvals[i+1].f-Qvals[i-1].f)/(2*dx);
>>   gx = (Qvals[i+1].g-Qvals[i-1].g)/(2*dx);
>>   uxx = (Qvals[i+1].u+Qvals[i-1].u - 2 *u)/(dx2);
>>   vxx = (Qvals[i+1].v+Qvals[i-1].v- 2 *v)/(dx2);
>>   fxx = (Qvals[i+1].f+Qvals[i-1].f -2*f)/(dx2);
>>   gxx = (Qvals[i+1].g+Qvals[i-1].g -2*g)/(dx2);
>>   FQvals[i].u = -uxx +1/a2 * u
>>     + 1/a *(.5/sigma* v +x * vx- b* vx +Q2sig* vx);
>>   FQvals[i].v = -vxx +1/a2 * v
>>     - 1/a *(.5/sigma * u +x * ux- b* ux +Q2sig* ux);
>>   FQvals[i].f = -fxx +1/a2 * f
>>     + 1/a *(.5/sigma * g +x * gx+ b* gx -W2sig* gx);
>>   FQvals[i].g =-gxx +1/a2 * g
>>     - 1/a *(.5/sigma * f +x * fx+ b* fx -W2sig* fx);
>> /* Restore raw arrays */
>> VecRestoreArray(p_vec, &p_array);
>> VecRestoreArray(Fp_vec, &Fp_array);
>> DMDAVecRestoreArray(user->Q_dm, Q_vec, &Qvals);
>> DMDAVecRestoreArray(user->Q_dm, FQ_vec, &FQvals);
>> DMCompositeGather(user->packer,F,INSERT_VALUES, Fp_vec, FQ_vec);
>> DMCompositeRestoreLocalVectors(user->packer, &p_vec, &Q_vec);
>> DMCompositeRestoreLocalVectors(user->packer, &Fp_vec, &FQ_vec);
>> return 0;
>> Here is the form function:
>> -gideon
>>> On Aug 27, 2015, at 11:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Can you send the code, that will be the easiest way to find the problem.
>>> My guess is that you have hardwired in your function/Jacobian computation the use of the original DM for computations instead of using the current DM (with refinement there will be a new DM on the second level different than your original DM). So what you need to do in writing your FormFunction and FormJacobian is to call SNESGetDM() to get the current DM and then use DMComputeGet... to access the individual DMDA and DMRedundent for the parts. I notice you have this user.Q_dm I bet inside your form functions you use this DM? You have to remove this logic.
>>> Barry
>>>> On Aug 27, 2015, at 9:42 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>>>> I have it set up as:
>>>>  DMCompositeCreate(PETSC_COMM_WORLD, &user.packer);
>>>>  DMRedundantCreate(PETSC_COMM_WORLD, 0, 3, &user.p_dm);
>>>>  DMCompositeAddDM(user.packer,user.p_dm);
>>>>  DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_GHOSTED,
>>>> 		 nx, 4, 1, NULL, &user.Q_dm);
>>>>  DMCompositeAddDM(user.packer,user.Q_dm);
>>>>  DMCreateGlobalVector(user.packer,&U);
>>>> where the user.packer structure has
>>>> DM packer;
>>>> DM p_dm, Q_dm;
>>>> Q_dm holds the field variables and p_dm holds the scalar values (the nonlinear eigenvalues).
>>>> Here are some of the errors that are generated:
>>>> [0]PETSC ERROR: ./blowup_batch2 on a arch-macports named gs_air by gideon Thu Aug 27 22:40:54 2015
>>>> [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 530 in /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.3/src/mat/impls/aij/mpi/mpiaij.c
>>>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>>> [1]PETSC ERROR: Argument out of range
>>>> [1]PETSC ERROR: Inserting a new nonzero (40003, 0) into matrix
>>>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>>>> [1]PETSC ERROR: Petsc Release Version 3.5.3, unknown
>>>> [1]PETSC ERROR: ./blowup_batch2 on a arch-macports named gs_air by gideon Thu Aug 27 22:40:54 2015
>>>> [1]PETSC ERROR: Configure options --prefix=/opt/local --prefix=/opt/local/lib/petsc --with-valgrind=0 --with-shared-libraries --with-debugging=0 --with-c2html-dir=/opt/local --with-x=0 --with-blas-lapack-lib=/System/Library/Frameworks/Accelerate.framework/Versions/Current/Accelerate --with-hwloc-dir=/opt/local --with-suitesparse-dir=/opt/local --with-superlu-dir=/opt/local --with-metis-dir=/opt/local --with-parmetis-dir=/opt/local --with-scalapack-dir=/opt/local --with-mumps-dir=/opt/local --with-superlu_dist-dir=/opt/local CC=/opt/local/bin/mpicc-mpich-mp CXX=/opt/local/bin/mpicxx-mpich-mp FC=/opt/local/bin/mpif90-mpich-mp F77=/opt/local/bin/mpif90-mpich-mp F90=/opt/local/bin/mpif90-mpich-mp COPTFLAGS=-Os CXXOPTFLAGS=-Os FOPTFLAGS=-Os LDFLAGS="-L/opt/local/lib -Wl,-headerpad_max_install_names" CPPFLAGS=-I/opt/local/include CFLAGS="-Os -arch x86_64" CXXFLAGS=-Os FFLAGS=-Os FCFLAGS=-Os F90FLAGS=-Os PETSC_ARCH=arch-macports --with-mpiexec=mpiexec-mpich-mp
>>>> [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 561 in /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.3/src/mat/impls/aij/mpi/mpiaij.c
>>>> [1]PETSC ERROR: #2 MatSetValues() line 1135 in /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.3/src/mat/interface/matrix.c
>>>> -gideon
>>>>> On Aug 27, 2015, at 10:37 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>> We need the full error message.
>>>>> But are you using a DMDA for the scalars?  You should not be, you should be using a DMRedundant for the scalars.
>>>>> Barry
>>>>> Though you should not get this error even if you are using a DMDA there.
>>>>>> On Aug 27, 2015, at 9:32 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>>>>>> I’m getting the following errors:
>>>>>> Could this have to do with me using the DMComposite with one da holding the scalar parameters and the other holding the field variables?
>>>>>> -gideon
>>>>>>> On Aug 27, 2015, at 10:15 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>> On Thu, Aug 27, 2015 at 9:11 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>>>>>>> HI Barry,
>>>>>>> Nope, I’m not doing any grid sequencing. Clearly that makes a lot of sense, to solve on a spatially coarse mesh for the field variables, interpolate onto the finer mesh, and then solve again.  I’m not entirely clear on the practical implementation
>>>>>>> SNES should do this automatically using -snes_grid_sequence <k>.  If this does not work, complain. Loudly.
>>>>>>> Matt
>>>>>>> -gideon
>>>>>>>> On Aug 27, 2015, at 10:02 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>>>> Gideon,
>>>>>>>> Are you using grid sequencing? Simply solve on a coarse grid, interpolate u1 and u2 to a once refined version of the grid and use that plus the mu lam as initial guess for the next level. Repeat to as fine a grid as you want. You can use DMRefine() and DMGetInterpolation() to get the interpolation needed to interpolate from the coarse to finer mesh.
>>>>>>>> Then and only then you can use multigrid (with or without fieldsplit) to solve the linear problems for finer meshes. Once you have the grid sequencing working we can help you with this.
>>>>>>>> Barry
>>>>>>>>> On Aug 27, 2015, at 7:00 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>>>>>>>>> I’m working on a problem which, morally, can be posed as a system of coupled semi linear elliptic PDEs together with unknown nonlinear eigenvalue parameters, loosely, of the form
>>>>>>>>> -\Delta u_1 + f(u_1, u_2) = lam * u1 - mu * du2/dx
>>>>>>>>> -\Delta u_2 + g(u_1, u_2) = lam * u2 + mu * du1/dx
>>>>>>>>> Currently, I have it set up with a DMComposite with two sub da’s, one for the parameters (lam, mu), and one for the vector field (u_1, u_2) on the mesh.  I have had success in solving this as a fully coupled system with SNES + sparse direct solvers (MUMPS, SuperLU).
>>>>>>>>> Lately, I am finding that, when the mesh resolution gets fine enough (i.e.  10^6-10^8 lattice points), my SNES gets stuck with the function norm = O(10^{-4}),  eventually returning reason -6 (failed line search).
>>>>>>>>> Perhaps there is another way around the above problem, but one thing I was thinking of trying would be to get away from direct solvers, and I was hoping to use field split for this.  However, it’s a bit beyond what I’ve seen examples for because it has 2 types of variables: scalar parameters which appear globally in the system and vector valued field variables.  Any suggestions on how to get started?
>>>>>>>>> -gideon
>>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150827/57e38a88/attachment-0001.html>
