[petsc-users] issues with sparse direct solvers
Hong hzhang at mcs.anl.gov
Tue Aug 25 11:24:41 CDT 2015
Gideon:
-mat_mumps_icntl_4 <0>: ICNTL(4): level of printing (0 to 4) (None)
This is for algorithmic diagnosis, not for regular runs. Use default '0'
for it.
Hong
On Tue, Aug 25, 2015 at 9:06 AM, Gideon Simpson <gideon.simpson at gmail.com>
wrote:
> Regarding the MUMPS issue, I’m not sure if this is useful, but when I run
> with the mumps flags  -mat_mumps_icntl_4 4, to see the progress, it hangs
> at this point:
>  ... Structural symmetry (in percent)=   75
>  Density: NBdense, Average, Median   =    2    9    7
>  Ordering based on METIS
> -gideon
> > On Aug 22, 2015, at 5:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> On Aug 22, 2015, at 4:04 PM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
> >> I’m having issues with both SuperLU dist and MUMPS, as compiled by
> PETsc, in the following sense:
> >> 1.  For large enough systems, which seems to vary depending on which
> computer I’m on, MUMPS seems to just die and never start, when it’s used as
> the linear solver within a SNES.    There’s no error message, it just sits
> there and doesn’t do anything.
> >  You will need to use a debugger to figure out where it is "hanging"; we
> haven't heard reports about this.
> >> 2.  When running with SuperLU dist, I got the following error, with no
> further information:
> >  The last release of SuperLU_DIST had some pretty nasty bugs, memory
> corruption that caused crashes etc. We think they are now fixed if you use
> the maint branch of the PETSc repository and --download-superlu_dist  If
> you stick with the PETSc release and SuperLU_Dist you are using you will
> keep seeing these crashes
> >   Barry
> >> [3]PETSC ERROR:
> >> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> >> [3]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> >> [3]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> >> [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS X to find memory corruption errors
> >> [3]PETSC ERROR: likely location of problem given in stack below
> >> [3]PETSC ERROR: ---------------------  Stack Frames
> >> [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> >> [3]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >> [3]PETSC ERROR:       is given.
> >> [3]PETSC ERROR: [3] SuperLU_DIST:pdgssvx line 161
> /home/simpson/software/petsc-3.5.4/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
> >> [3]PETSC ERROR: [3] MatSolve_SuperLU_DIST line 121
> >> [3]PETSC ERROR: [3] MatSolve line 3104
> /home/simpson/software/petsc-3.5.4/src/mat/interface/matrix.c
> >> [3]PETSC ERROR: [3] PCApply_LU line 194
> /home/simpson/software/petsc-3.5.4/src/ksp/pc/impls/factor/lu/lu.c
> >> [3]PETSC ERROR: [3] KSP_PCApplyBAorAB line 258
> /home/simpson/software/petsc-3.5.4/include/petsc-private/kspimpl.h
> >> [3]PETSC ERROR: --------------------- Error Message
> >> [3]PETSC ERROR: Signal received
> >> [3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> >> [3]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
> >> [3]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
> proteusi01 by simpson Sat Aug 22 17:01:41 2015
> >> [3]PETSC ERROR: Configure options
> --with-mpi-dir=/mnt/HA/opt/openmpi/intel/64/1.8.1-mlnx-ofed
> --with-blas-lib=/mnt/HA/opt/blas/gcc/64/20110419/libblas.a
> --with-lapack-lib=/liblapack.a --download-suitesparse=yes
> --download-superlu=yes --download-superlu_dist=yes --download-mumps=yes
> --download-metis=yes --download-parmetis=yes --download-scalapack=yes
> >> [3]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> >> MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD
> >> with errorcode 59.
> >> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> >> You may or may not see output from other processes, depending on
> >> exactly when Open MPI kills them.
> >> [proteusi01:14037] 1 more process has sent help message
> help-mpi-api.txt / mpi-abort
> >> [proteusi01:14037] Set MCA parameter "orte_base_help_aggregate" to 0 to
> see all help / error messages
> >> [6]PETSC ERROR:
> >> [6]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> batch system) has told this process to end
> >> [6]PETSC ERROR: Try option -start_in_debugger or
> >> [6]PETSC ERROR: or see
> >> [6]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> >> [6]PETSC ERROR: likely location of problem given in stack below
> >> [6]PETSC ERROR: ---------------------  Stack Frames
> >> [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> >> [6]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >> [6]PETSC ERROR:       is given.
> >> [6]PETSC ERROR: [6] SuperLU_DIST:pdgssvx line 161
> >> [6]PETSC ERROR: [6] MatSolve_SuperLU_DIST line 121
> >> [6]PETSC ERROR: [6] MatSolve line 3104
> >> [6]PETSC ERROR: [6] PCApply_LU line 194
> >> [6]PETSC ERROR: [6] KSP_PCApplyBAorAB line 258
> >> [6]PETSC ERROR: --------------------- Error Message
> >> [6]PETSC ERROR: Signal received
> >> [6]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> >> [6]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
> >> [6]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
> >> [6]PETSC ERROR: Configure options
> >> [6]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> >> [7]PETSC ERROR:
> >> [7]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> >> [7]PETSC ERROR: Try option -start_in_debugger or
> >> [7]PETSC ERROR: or see
> >> [7]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> >> [7]PETSC ERROR: likely location of problem given in stack below
> >> [7]PETSC ERROR: ---------------------  Stack Frames
> >> [7]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> >> [7]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >> [7]PETSC ERROR:       is given.
> >> [7]PETSC ERROR: [7] SuperLU_DIST:pdgssvx line 161
> >> [7]PETSC ERROR: [7] MatSolve_SuperLU_DIST line 121
> >> [7]PETSC ERROR: [7] MatSolve line 3104
> >> [7]PETSC ERROR: [7] PCApply_LU line 194
> >> [7]PETSC ERROR: [7] KSP_PCApplyBAorAB line 258
> >> [7]PETSC ERROR: --------------------- Error Message
> >> [7]PETSC ERROR: Signal received
> >> [7]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> >> [7]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
> >> [7]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
> >> [7]PETSC ERROR: Configure options
> >> [7]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> >> [0]PETSC ERROR:
> >> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> >> [0]PETSC ERROR: Try option -start_in_debugger or
> >> [0]PETSC ERROR: or see
> >> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> >> [0]PETSC ERROR: likely location of problem given in stack below
> >> [0]PETSC ERROR: ---------------------  Stack Frames
> >> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> >> [0]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >> [0]PETSC ERROR:       is given.
> >> [0]PETSC ERROR: [0] SuperLU_DIST:pdgssvx line 161
> >> [0]PETSC ERROR: [0] MatSolve_SuperLU_DIST line 121
> >> [0]PETSC ERROR: [0] MatSolve line 3104
> >> [0]PETSC ERROR: [0] PCApply_LU line 194
> >> [0]PETSC ERROR: [0] KSP_PCApplyBAorAB line 258
> >> [0]PETSC ERROR: --------------------- Error Message
> >> [0]PETSC ERROR: Signal received
> >> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> >> [0]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
> >> [0]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
> >> [0]PETSC ERROR: Configure options
> >> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> >> [1]PETSC ERROR:
> >> [1]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> >> [1]PETSC ERROR: Try option -start_in_debugger or
> >> [1]PETSC ERROR: or see
> >> [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> >> [1]PETSC ERROR: likely location of problem given in stack below
> >> [1]PETSC ERROR: ---------------------  Stack Frames
> >> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> >> [1]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >> [1]PETSC ERROR:       is given.
> >> [1]PETSC ERROR: [1] SuperLU_DIST:pdgssvx line 161
> >> [1]PETSC ERROR: [1] MatSolve_SuperLU_DIST line 121
> >> [1]PETSC ERROR: [1] MatSolve line 3104
> >> [1]PETSC ERROR: [1] PCApply_LU line 194
> >> [1]PETSC ERROR: [1] KSP_PCApplyBAorAB line 258
> >> [1]PETSC ERROR: --------------------- Error Message
> >> [1]PETSC ERROR: Signal received
> >> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> >> [1]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
> >> [1]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
> >> [1]PETSC ERROR: Configure options
> >> [1]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> >> [2]PETSC ERROR:
> >> [2]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> >> [2]PETSC ERROR: Try option -start_in_debugger or
> >> [2]PETSC ERROR: or see
> >> [2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> >> [2]PETSC ERROR: likely location of problem given in stack below
> >> [2]PETSC ERROR: ---------------------  Stack Frames
> >> [2]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> >> [2]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >> [2]PETSC ERROR:       is given.
> >> [2]PETSC ERROR: [2] SuperLU_DIST:pdgssvx line 161
> >> [2]PETSC ERROR: [2] MatSolve_SuperLU_DIST line 121
> >> [2]PETSC ERROR: [2] MatSolve line 3104
> >> [2]PETSC ERROR: [2] PCApply_LU line 194
> >> [2]PETSC ERROR: [2] KSP_PCApplyBAorAB line 258
> >> [2]PETSC ERROR: --------------------- Error Message
> >> [2]PETSC ERROR: Signal received
> >> [2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> >> [2]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
> >> [2]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
> >> [2]PETSC ERROR: Configure options
> >> [2]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> >> [4]PETSC ERROR:
> >> [4]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> >> [4]PETSC ERROR: Try option -start_in_debugger or
> >> [4]PETSC ERROR: or see
> >> [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> >> [4]PETSC ERROR: likely location of problem given in stack below
> >> [4]PETSC ERROR: ---------------------  Stack Frames
> >> [4]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> >> [4]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >> [4]PETSC ERROR:       is given.
> >> [4]PETSC ERROR: [4] SuperLU_DIST:pdgssvx line 161
> >> [4]PETSC ERROR: [4] MatSolve_SuperLU_DIST line 121
> >> [4]PETSC ERROR: [4] MatSolve line 3104
> >> [4]PETSC ERROR: [4] PCApply_LU line 194
> >> [4]PETSC ERROR: [4] KSP_PCApplyBAorAB line 258
> >> [4]PETSC ERROR: --------------------- Error Message
> >> [4]PETSC ERROR: Signal received
> >> [4]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> >> [4]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
> >> [4]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
> >> [4]PETSC ERROR: Configure options
> >> [4]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> >> [5]PETSC ERROR:
> >> [5]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> >> [5]PETSC ERROR: Try option -start_in_debugger or
> >> [5]PETSC ERROR: or see
> >> [5]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> >> [5]PETSC ERROR: likely location of problem given in stack below
> >> [5]PETSC ERROR: ---------------------  Stack Frames
> >> [5]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> >> [5]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >> [5]PETSC ERROR:       is given.
> >> [5]PETSC ERROR: [5] SuperLU_DIST:pdgssvx line 161
> >> [5]PETSC ERROR: [5] MatSolve_SuperLU_DIST line 121
> >> [5]PETSC ERROR: [5] MatSolve line 3104
> >> [5]PETSC ERROR: [5] PCApply_LU line 194
> >> [5]PETSC ERROR: [5] KSP_PCApplyBAorAB line 258
> >> [5]PETSC ERROR: --------------------- Error Message
> >> [5]PETSC ERROR: Signal received
> >> [5]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> >> [5]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
> >> [5]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
> >> [5]PETSC ERROR: Configure options
> >> [5]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> >> -gideon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150825/12a2081d/attachment-0001.html>
