[petsc-users] Insert values into matrix using MatSetValuesStencil or MatSetValuesLocal
Tue Aug 25 10:31:09 CDT 2015
On Tue, Aug 25, 2015 at 10:19 AM, Wee Beng Tay <zonexo at gmail.com> wrote:
> Hi,
> So can I use multigrid directly if using matsetvalues stencil?
Do you mean, if you use MatSetStencil() then you statements will work no
matter what grid comes in to your residual function?
That is true.
     Matt
> Thanks
> Sent using CloudMagic
> <https://cloudmagic.com/k/d/mailapp?ct=pa&cv=7.2.9&pv=5.0.2>
> On Tue, Aug 25, 2015 at 10:11 AM, Matthew Knepley <knepley at gmail.com>
>> On Mon, Aug 24, 2015 at 6:21 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> On Mon, Aug 24, 2015 at 4:09 AM, Wee-Beng Tay <zonexo at gmail.com> wrote:
>>> Hi,
>>> I'm modifying my 3d fortran code from MPI along 1 direction (z) to MPI
>>> along 2 directions (y,z)
>>> Previously I was using MatSetValues with global indices. However, now
>>> I'm using DM and global indices is much more difficult.
>>> I come across MatSetValuesStencil or MatSetValuesLocal.
>>> So what's the difference bet the one since they both seem to work
>>> locally?
>> No. MatSetValuesLocal() takes local indices. MatSetValuesStencil() takes
>> global vertex numbers.
>> So MatSetValuesStencil() takes global vertex numbers. Do you mean the
>> natural or petsc ordering?
> There is no PETSc ordering for vertices, only the natural ordering.
> Thanks,
> Matt
>> Which is a simpler/better option?
>>> Is there an example in Fortran for MatSetValuesStencil?
>> Timothée Nicolas shows one in his reply.
>> Do I also need to use DMDAGetAO together with MatSetValuesStencil or
>>> MatSetValuesLocal?
>> No.
>> Thanks,
>> Matt
>>> Thanks!
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150825/34f65c5f/attachment.html>
