[petsc-users] GMRES -> PCMG -> PCASM pre- post- smoother
Aulisa, Eugenio eugenio.aulisa at ttu.edu
Fri Aug 21 19:38:27 CDT 2015
Thanks Barry.
Yes that was my problem now if I run with the same down and up
number of iterations I see the in -ksp_view output
that smoother up is the same as smoother down.
I think I figure it out how to set up different smoothers
up and down but use the same ASM Preconditioner,
which is more or less what Lorenzo suggested.
Thanks again
Eugenio
Sent: Thursday, August 20, 2015 11:54 PM
To: Aulisa, Eugenio
Cc: PETSc list
Subject: Re: [petsc-users] GMRES -> PCMG -> PCASM pre- post- smoother
Ahhh,
void AsmPetscLinearEquationSolver::MGsolve ( const bool ksp_clean , const unsigned &npre, const unsigned &npost ) {
  if ( ksp_clean ) {
    PetscMatrix* KKp = static_cast< PetscMatrix* > ( _KK );
    Mat KK = KKp->mat();
    KSPSetOperators ( _ksp, KK, _Pmat );
    KSPSetTolerances ( _ksp, _rtol, _abstol, _dtol, _maxits );
    KSPSetFromOptions ( _ksp );
    PC pcMG;
    KSPGetPC(_ksp, &pcMG);
    PCMGSetNumberSmoothDown(pcMG, npre);
    PCMGSetNumberSmoothUp(pcMG, npost);
PetscErrorCode  PCMGSetNumberSmoothDown(PC pc,PetscInt n)
  PC_MG          *mg        = (PC_MG*)pc->data;
  PC_MG_Levels   **mglevels = mg->levels;
  PetscErrorCode ierr;
  PetscInt       i,levels;
  PetscFunctionBegin;
  PetscValidHeaderSpecific(pc,PC_CLASSID,1);
  if (!mglevels) SETERRQ(PetscObjectComm((PetscObject)pc),PETSC_ERR_ARG_WRONGSTATE,"Must set MG levels before calling");
  PetscValidLogicalCollectiveInt(pc,n,2);
  levels = mglevels[0]->levels;
  for (i=1; i<levels; i++) {
    /* make sure smoother up and down are different */
    ierr = PCMGGetSmootherUp(pc,i,NULL);CHKERRQ(ierr);
    ierr = KSPSetTolerances(mglevels[i]->smoothd,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT,n);CHKERRQ(ierr);
    mg->default_smoothd = n;
  PetscFunctionReturn(0);
PetscErrorCode  PCMGGetSmootherUp(PC pc,PetscInt l,KSP *ksp)
  const char     *prefix;
  MPI_Comm       comm;
  PetscFunctionBegin;
     This is called only if user wants a different pre-smoother from post.
     Thus we check if a different one has already been allocated,
     if not we allocate it.
  if (!l) SETERRQ(PetscObjectComm((PetscObject)pc),PETSC_ERR_ARG_OUTOFRANGE,"There is no such thing as a up smoother on the coarse grid");
  if (mglevels[l]->smoothu == mglevels[l]->smoothd) {
    KSPType     ksptype;
    PCType      pctype;
    PC          ipc;
    PetscReal   rtol,abstol,dtol;
    PetscInt    maxits;
    KSPNormType normtype;
    ierr = PetscObjectGetComm((PetscObject)mglevels[l]->smoothd,&comm);CHKERRQ(ierr);
    ierr = KSPGetOptionsPrefix(mglevels[l]->smoothd,&prefix);CHKERRQ(ierr);
    ierr = KSPGetTolerances(mglevels[l]->smoothd,&rtol,&abstol,&dtol,&maxits);CHKERRQ(ierr);
    ierr = KSPGetType(mglevels[l]->smoothd,&ksptype);CHKERRQ(ierr);
    ierr = KSPGetNormType(mglevels[l]->smoothd,&normtype);CHKERRQ(ierr);
    ierr = KSPGetPC(mglevels[l]->smoothd,&ipc);CHKERRQ(ierr);
    ierr = PCGetType(ipc,&pctype);CHKERRQ(ierr);
    ierr = KSPCreate(comm,&mglevels[l]->smoothu);CHKERRQ(ierr);
    ierr = KSPSetErrorIfNotConverged(mglevels[l]->smoothu,pc->erroriffailure);CHKERRQ(ierr);
    ierr = PetscObjectIncrementTabLevel((PetscObject)mglevels[l]->smoothu,(PetscObject)pc,mglevels[0]->levels-l);CHKERRQ(ierr);
    ierr = KSPSetOptionsPrefix(mglevels[l]->smoothu,prefix);CHKERRQ(ierr);
    ierr = KSPSetTolerances(mglevels[l]->smoothu,rtol,abstol,dtol,maxits);CHKERRQ(ierr);
    ierr = KSPSetType(mglevels[l]->smoothu,ksptype);CHKERRQ(ierr);
    ierr = KSPSetNormType(mglevels[l]->smoothu,normtype);CHKERRQ(ierr);
    ierr = KSPSetConvergenceTest(mglevels[l]->smoothu,KSPConvergedSkip,NULL,NULL);CHKERRQ(ierr);
    ierr = KSPGetPC(mglevels[l]->smoothu,&ipc);CHKERRQ(ierr);
    ierr = PCSetType(ipc,pctype);CHKERRQ(ierr);
    ierr = PetscLogObjectParent((PetscObject)pc,(PetscObject)mglevels[l]->smoothu);CHKERRQ(ierr);
  if (ksp) *ksp = mglevels[l]->smoothu;
  As soon as you set both the up and down number of iterations it causes a duplication of the current smoother with some options preserved but others not (we don't have a KSPDuplicate() that duplicates everything).
  So if you are fine with the number of pre and post smooths the same just don't set both
  if you want them to be different you can share the same PC between the two (which has the overlapping matrices in it) but you cannot share the same KSP. I can tell you how to do that but suggest it is simpler just to have the same number of  pre and post smooths
  Barry
> On Aug 20, 2015, at 6:51 AM, Aulisa, Eugenio <eugenio.aulisa at ttu.edu> wrote:
> Hi Barry,
> Thanks for your answer.
> I run my applications with no command line, and I do not think I changed any PETSC_OPTIONS,
> at least not voluntarily.
> For the source it is available on
> https://github.com/NumPDEClassTTU/femus
> but it is part of a much larger library and
> I do not think any of you want to install and run it
> just to find what I messed up.
> In any case, if you just want to look at the source  code
> where I set up the level smoother  it is in
> https://github.com/NumPDEClassTTU/femus/blob/master/src/algebra/AsmPetscLinearEquationSolver.cpp
> line 400
> void AsmPetscLinearEquationSolver::MGsetLevels (
>    LinearEquationSolver *LinSolver, const unsigned &level, const unsigned &levelMax,
>    const vector <unsigned> &variable_to_be_solved, SparseMatrix* PP, SparseMatrix* RR ){
> Be aware, that even if it seams that this takes care of the coarse level it is not.
> The coarse level smoother is set some where else.
> Thanks,
> Eugenio
> From: Barry Smith [bsmith at mcs.anl.gov]
> Sent: Thursday, August 20, 2015 2:37 AM
> To: Aulisa, Eugenio
> Cc: petsc-users at mcs.anl.gov
>   What you describe is not the expected behavior. I expected exactly the result that you expected.
> Do you perhaps have some PETSc options around that may be changing the post-smoother? On the command line or in the file petscrc or in the environmental variable PETSC_OPTIONS?  Can you send us some code that we could run that reproduces the problem?
>  Barry
>> On Aug 19, 2015, at 9:26 PM, Aulisa, Eugenio <eugenio.aulisa at ttu.edu> wrote:
>> Hi,
>> I am solving an iteration of
>> where I build my particular ASM domain decomposition.
>> In setting the PCMG I would like at each level
>> to use the same pre- and post-smoother
>> and for this reason I am using
>> PCMGGetSmoother ( pcMG, level , &subksp );
>> to extract and set at each level the ksp object.
>> In setting PCASM then I use
>> KSPGetPC ( subksp, &subpc );
>> PCSetType ( subpc, PCASM );
>> and then set my own decomposition
>> PCASMSetLocalSubdomains(subpc,_is_loc_idx.size(),&_is_ovl[0],&_is_loc[0]);
>> Now everything compiles, and runs with no memory leakage,
>> but I do not get the expected convergence.
>> When I checked the output of -ksp_view, I saw something that puzzled me:
>> at each level >0, while in the MG pre-smoother the ASM domain decomposition
>> is the one that I set, for example with 4 processes  I get
>> Down solver (pre-smoother) on level 2 -------------------------------
>>   KSP Object:    (level-2)     4 MPI processes
>>     type: gmres
>>       GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>>       GMRES: happy breakdown tolerance 1e-30
>>     maximum iterations=1
>>     using preconditioner applied to right hand side for initial guess
>>     tolerances:  relative=1e-12, absolute=1e-20, divergence=1e+50
>>     left preconditioning
>>     using nonzero initial guess
>>     using NONE norm type for convergence test
>>   PC Object:    (level-2)     4 MPI processes
>>     type: asm
>>       Additive Schwarz: total subdomain blocks = 198, amount of overlap = 0
>>       Additive Schwarz: restriction/interpolation type - RESTRICT
>>       [0] number of local blocks = 52
>>       [1] number of local blocks = 48
>>       [2] number of local blocks = 48
>>       [3] number of local blocks = 50
>>       Local solve info for each block is in the following KSP and PC objects:
>> in the post-smoother I have the default ASM  decomposition with overlapping 1:
>> Up solver (post-smoother) on level 2 -------------------------------
>>     type: gmres
>>     maximum iterations=2
>>     type: asm
>>       Additive Schwarz: total subdomain blocks = 4, amount of overlap = 1
>>       Local solve is same for all blocks, in the following KSP and PC objects:
>>     KSP Object:      (level-2sub_)       1 MPI processes
>>       type: preonly
>>       maximum iterations=10000, initial guess is zero
>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>> So it seams that by using
>> I was capable  to set both the pre- and post- smoothers to be PCASM
>> but everything I did after that applied only to the
>> pre-smoother, while the post-smoother got the default PCASM options.
>> I know that I can use
>> PCMGGetSmootherDown and PCMGGetSmootherUp, but that would
>> probably double the memory allocation and the computational time in the ASM.
>> Is there any way I can just use PCMGGetSmoother
>> and use the same PCASM in the pre- and post- smoother?
>> I hope I was clear enough.
>> Thanks a lot for your help,
>> Eugenio
