[petsc-users] SNESSetFunction
Reza Yaghmaie reza.yaghmaie2 at gmail.com
Tue Aug 18 19:25:42 CDT 2015
Thank you very much for the insight. It helped.
I am trying to solve the system using *snes *routines. Let's say the I
execute the below command in Fortran
call *SNESSolve*(snes,PETSC_NULL_OBJECT,xvec,ierr)
In the residual calculation and Jacobian update routines I need to finalize
the vectors and matrix assemblies using the commands as following otherwise
*SNESSolve* will crash:
call *VecAssemblyBegin *(FVEC, ierr)
call *VecAssemblyEnd   *(FVEC, ierr)
        call *MatAssemblyBegin*(jac_prec,MAT_FINAL_ASSEMBLY,ierr)
        call *MatAssemblyEnd*(jac_prec,MAT_FINAL_ASSEMBLY,ierr)
I face the issue that my debugger crashes at the locations of theses final
vector and matrix assemblies. It worked for the sequential version of the
code but for the parallel version it stops there. I am sure all processors
in the mpi framework reach to these pointers simultaneously. Any insights?
Reza
On Mon, Aug 17, 2015 at 2:25 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Reza,
>     See src/snes/examples/tutorials/ex5f90.F for how this may be easily
> done using a Fortran user defined type
>   Barry
> > On Aug 17, 2015, at 12:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Mon, Aug 17, 2015 at 11:46 AM, Reza Yaghmaie <
> reza.yaghmaie2 at gmail.com> wrote:
> > Hi,
> > I have problems with passing variables through  SNESSetFunction in my
> code. basically I have the following subroutines in the main body of the
> Fortran code. Could you provide some insight on how to transfer variables
> into the residual calculation routine (FormFunction1)?
> > Extra arguments to your FormFunction are meant to be passed in a
> context, through the context variable.
> > This is difficult in Fortran, but you can use a PetscObject as a
> container. You can attach other
> > PetscObjects using PetscObjectCompose() in Fortran.
> >    Matt
> > Thanks,
> > Reza
> > main code
> >       SNES      snes
> >       Vec          xvec,rvec
> >       external   FormFunction1
> >       real*8
>  variable1(10),variable2(20,20),variable3(30),variable4(40,40)
> >       call SNESSetFunction(snes,rvec,FormFunction1,
> >      &                PETSC_NULL_OBJECT,
> >      &                variable1,variable2,variable3,variable4,
> >      &                ierr)
> >       end
> >       subroutine FormFunction1(snes,XVEC,FVEC,
> >      &                dummy,
> >      &                varable1,varable2,varable3,varable4,
> >      &                ierr)
> >       SNES                      snes
> >       Vec                         XVEC,FVEC
> >       PetscFortranAddr    dummy
> >       real*8
> >       return
> >       end
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150818/0b5f1972/attachment.html>
