[petsc-users] superlu_dist output
Gideon Simpson gideon.simpson at gmail.com
Mon Aug 17 15:18:49 CDT 2015
This is the macports version.  For me, this appears when running a problem with a linear solver with the flags
-pc_factor_mat_solver_package superlu_dist -pc_type lu
Nothing else is required.  The answer it gives is correct, I’d just like to suppress the output.
-gideon
> On Aug 17, 2015, at 4:14 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> How can we reproduce this? Is this using debian pkg install of petsc,
> superlu_dist? [which versions?]
> balay at es^/scratch/balay/petsc/src/ksp/ksp/examples/tutorials(maint=) $ $PETSC_DIR/bin/petscmpiexec -n 2 ./ex2 -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package superlu_dist
> Norm of error 1.87427e-15 iterations 1
> You can try installing our latest version using
> --download-superlu_dist and see if you still have this issue.
> Satish
> Satish
> On Mon, 17 Aug 2015, Gideon Simpson wrote:
>> Is there a way to suppress this kind of output when running with superlu_dist?
>> .. equilibrated? *equed = B
>> .. LDPERM job 5	 time: 0.00
>> .. anorm 3.541231e+01
>> .. Use METIS ordering on A'+A
>> .. symbfact(): relax   10, maxsuper   60, fill    4
>> 	No of supers 73
>> 	Size of G(L) 991
>> 	Size of G(U) 722
>> 	int 4, short 2, float 4, double 8
>> 	SYMBfact (MB):	L\U 0.02	total 0.03	expansions 0
>> .. # L blocks 228	# U blocks 211
>> MPI tag upper bound = 536870911
>> === using DAG ===
>> * init: 1.779720e-04 seconds
>> .. thresh = s_eps 0.000000e+00 * anorm 3.541231e+01 = 0.000000e+00
>> .. Buffer size: Lsub 30	Lval 200	Usub 35	Uval 120	LDA 20
>> 	NUMfact (MB) all PEs:	L\U	0.10	all	0.12
>> 	All space (MB):		total	0.32	Avg	0.32	Max	0.32
>> 	Number of tiny pivots:          0
>> .. DiagScale = 3
>> .. DiagScale = 3
>> .. DiagScale = 3
>> .. anorm 3.378641e+01
>> -gideon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150817/1ee8306a/attachment.html>
