[petsc-users] checking jacobian
Gideon Simpson gideon.simpson at gmail.com
Tue Aug 11 22:40:12 CDT 2015
Barry’s comment resolved my issue.
-gideon
> On Aug 11, 2015, at 5:40 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  You also have to KEEP the -snes_check_jacobian option
>  Barry
>> On Aug 11, 2015, at 1:09 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>> I don’t see it listed in -help, but I do get
>> ./blowup -xmax 50 -nx 1000 -snes_check_jacobian
>>      Testing hand-coded Jacobian, if the ratio is O(1.e-8), the hand-coded Jacobian is probably correct.
>>      Run with -snes_check_jacobian_view [viewer][:filename][:format] to show difference of hand-coded and finite difference Jacobian.
>>    63386.1 = ||J - Jfd||//J|| 63386.1  = ||J - Jfd||
>> -gideon
>>> On Aug 11, 2015, at 2:07 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Tue, Aug 11, 2015 at 1:04 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>>> Macports installation of 3.5.3.
>>> Use -help to find the option name. Maybe its -snes_test.
>>>  Thanks,
>>>    Matt
>>> -gideon
>>>> On Aug 11, 2015, at 2:03 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Tue, Aug 11, 2015 at 12:51 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>>>> #End of PETSc Option Table entries
>>>> There is one unused database option. It is:
>>>> Option left: name:-snes_check_jacobian_view (no value)
>>>> This is the option for the newest release. What are you using?
>>>>   Matt
>>>> -gideon
>>>>> On Aug 11, 2015, at 1:50 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>>> On Tue, Aug 11, 2015 at 12:49 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>>>>> Maybe it’s a quirk of the macports installation of petsc, but nothing seems to be getting generated.
>>>>> Run with -options_left. Is it reading the option?
>>>>>  Matt
>>>>> -gideon
>>>>>> On Aug 11, 2015, at 1:40 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>>>> Gideon Simpson <gideon.simpson at gmail.com> writes:
>>>>>>> I’m a bit confused by the following options:
>>>>>>> What flags do I pass it to get some output to diagnose my Jacobian error?
>>>>>> Nothing to display ASCII to the screen.  You might use
>>>>>> "binary:thematrix" if you want to read it in with Python or MATLAB, for
>>>>>> example.
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>> -- Norbert Wiener
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150811/d259d36f/attachment.html>
