[petsc-users] SuperLU MPI-problem
Xiaoye S. Li xsli at lbl.gov
Tue Aug 11 18:49:05 CDT 2015
​It's hard to say. For 3D problems, you may get a fill factor about 30x-50x
(can be larger or smaller depending on problem.)   The time may be in
seconds, or minutes at most.
Sherry
On Tue, Aug 11, 2015 at 7:31 AM, Mahir.Ulker-Kaustell at tyrens.se <
Mahir.Ulker-Kaustell at tyrens.se> wrote:
> Yes! Doing:
> $PETSC_DIR/$PETSC_ARCH/bin/mpiexec
> instead of
> mpiexec
> makes the program run as expected.
> Thank you all for your patience and encouragement.
> Sherry: I have noticed that you have been involved in some publications
> related to my current work, i.e. wave propagation in elastic solids. What
> computation time would you expect using SuperLU to solve one linear system
> with say 800000 degrees of freedom and 4-8 processes (on a single node)
> with a finite element discretization?
> Mahir
> -----Original Message-----
> From: Satish Balay [mailto:balay at mcs.anl.gov]
> Sent: den 7 augusti 2015 18:09
> To: Ülker-Kaustell, Mahir
> Cc: Hong; PETSc users list
> Subject: Re: [petsc-users] SuperLU MPI-problem
> This usually happens if you use the wrong MPIEXEC
> i.e use the mpiexec from the MPI you built PETSc with.
> Satish
> On Fri, 7 Aug 2015, Mahir.Ulker-Kaustell at tyrens.se wrote:
> > Hong,
> > Running example 2 with the command line given below gives me two
> uniprocessor runs!?
> > $ mpiexec -n 2 ./ex2 -pc_type lu -pc_factor_mat_solver_package
> superlu_dist -ksp_view
> > KSP Object: 1 MPI processes
> >   type: gmres
> >     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> >     GMRES: happy breakdown tolerance 1e-30
> >   maximum iterations=10000, initial guess is zero
> >   tolerances:  relative=0.000138889, absolute=1e-50, divergence=10000
> >   left preconditioning
> >   using PRECONDITIONED norm type for convergence test
> > PC Object: 1 MPI processes
> >   type: lu
> >     LU: out-of-place factorization
> >     tolerance for zero pivot 2.22045e-14
> >     matrix ordering: nd
> >     factor fill ratio given 0, needed 0
> >       Factored matrix follows:
> >         Mat Object:         1 MPI processes
> >           type: seqaij
> >           rows=56, cols=56
> >           package used to perform factorization: superlu_dist
> >           total: nonzeros=0, allocated nonzeros=0
> >           total number of mallocs used during MatSetValues calls =0
> >             SuperLU_DIST run parameters:
> >               Process grid nprow 1 x npcol 1
> >               Equilibrate matrix TRUE
> >               Matrix input mode 0
> >               Replace tiny pivots TRUE
> >               Use iterative refinement FALSE
> >               Processors in row 1 col partition 1
> >               Row permutation LargeDiag
> >               Column permutation METIS_AT_PLUS_A
> >               Parallel symbolic factorization FALSE
> >               Repeated factorization SamePattern_SameRowPerm
> >   linear system matrix = precond matrix:
> >     type: seqaij
> >     rows=56, cols=56
> >     total: nonzeros=250, allocated nonzeros=280
> >       not using I-node routines
> > Norm of error 5.21214e-15 iterations 1
> >   type: gmres
> >   type: lu
> >     matrix ordering: nd
> >           type: seqaij
> >           rows=56, cols=56
> >               Matrix input mode 0
> >     type: seqaij
> >     rows=56, cols=56
> > Mahir
> > From: Hong [mailto:hzhang at mcs.anl.gov]
> > Sent: den 6 augusti 2015 16:36
> > Cc: Hong; Xiaoye S. Li; PETSc users list
> > Mahir:
> > I have been using PETSC_COMM_WORLD.
> > What do you get by running a petsc example, e.g.,
> > petsc/src/ksp/ksp/examples/tutorials
> > KSP Object: 2 MPI processes
> >   type: gmres
> > Hong
> > From: Hong [mailto:hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>]
> > Sent: den 5 augusti 2015 17:11
> > Mahir:
> > As you noticed, you ran the code in serial mode, not parallel.
> > Check your code on input communicator, e.g., what input communicator do
> you use in
> > KSPCreate(comm,&ksp)?
> > I have added error flag to superlu_dist interface (released version).
> When user uses '-mat_superlu_dist_parsymbfact'
> > in serial mode, this option is ignored with a warning.
> > Hong
> > Hong,
> > If I set parsymbfact:
> > $ mpiexec -n 2 ./solve -ksp_type preonly -pc_type lu
> -pc_factor_mat_solver_package superlu_dist -mat_superlu_dist_matinput
> DISTRIBUTED -mat_superlu_dist_parsymbfact -ksp_view
> > Invalid ISPEC at line 484 in file get_perm_c.c
> > Primary job  terminated normally, but 1 process returned
> > a non-zero exit code.. Per user-direction, the job has been aborted.
> > mpiexec detected that one or more processes exited with non-zero status,
> thus causing
> > the job to be terminated. The first process to do so was:
> >   Process name: [[63679,1],0]
> >   Exit code:    255
> > Since the program does not finish the call to KSPSolve(), we do not get
> any information about the KSP from –ksp_view.
> > If I do not set it, I get a serial run even if I specify –n 2:
> -pc_factor_mat_solver_package superlu_dist -ksp_view
> >   type: preonly
> >   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
> >   using NONE norm type for convergence test
> >   type: lu
> >     matrix ordering: nd
> >           type: seqaij
> >           rows=954, cols=954
> >               Matrix input mode 0
> >     type: seqaij
> >     rows=954, cols=954
> >     total: nonzeros=34223, allocated nonzeros=34223
> >       using I-node routines: found 668 nodes, limit used is 5
> > I am running PETSc via Cygwin on a windows machine.
> > When I installed PETSc the tests with different numbers of processes ran
> well.
> > Mahir
> > Sent: den 3 augusti 2015 19:06
> > Mahir,
> > I have not used …parsymbfact in sequential runs or set matinput=GLOBAL
> for parallel runs.
> > If I use 2 processors, the program runs if I use
> –mat_superlu_dist_parsymbfact=1:
> GLOBAL -mat_superlu_dist_parsymbfact=1
> > The incorrect option  '-mat_superlu_dist_parsymbfact=1' is not taken, so
> your code runs well without parsymbfact.
> > Please run it with '-ksp_view' and see what
> > 'SuperLU_DIST run parameters:' are being used, e.g.
> > petsc/src/ksp/ksp/examples/tutorials (maint)
> superlu_dist -mat_superlu_dist_parsymbfact=1 -ksp_view
> >               Process grid nprow 2 x npcol 1
> >               Matrix input mode 1
> >               Processors in row 2 col partition 1
> > I do not understand why your code uses matrix input mode = global.
> > Hong
> > Sent: den 3 augusti 2015 16:46
> > To: Xiaoye S. Li
> > Cc: Ülker-Kaustell, Mahir; Hong; PETSc users list
> > Mahir,
> > Sherry found the culprit. I can reproduce it:
> superlu_dist -mat_superlu_dist_matinput GLOBAL -mat_superlu_dist_parsymbfact
> > PETSc-superlu_dist interface sets matinput=DISTRIBUTED as default when
> using more than one processes.
> > Did you either use '-mat_superlu_dist_parsymbfact' for sequential run or
> set matinput=GLOBAL for parallel run?
> > I'll add an error flag for these use cases.
> > Hong
> > On Mon, Aug 3, 2015 at 9:17 AM, Xiaoye S. Li <xsli at lbl.gov<mailto:
> xsli at lbl.gov>> wrote:
> > I think I know the problem.   Since zdistribute.c is called, I guess you
> are using the global (replicated) matrix input interface,
> pzgssvx_ABglobal().  This interface does not allow you to use parallel
> symbolic factorization (since matrix is centralized).
> > That's why you get the following error:
> > You need to use distributed matrix input interface pzgssvx() (without
> ABglobal)
> > Sherry
> > On Mon, Aug 3, 2015 at 5:02 AM, Mahir.Ulker-Kaustell at tyrens.se<mailto:
> Mahir.Ulker-Kaustell at tyrens.se> <Mahir.Ulker-Kaustell at tyrens.se<mailto:
> Mahir.Ulker-Kaustell at tyrens.se>> wrote:
> > Hong and Sherry,
> > I have rebuilt PETSc with SuperLU 4.1. Unfortunately, the problem
> remains:
> > If I use -mat_superlu_dist_parsymbfact, the program crashes with:
> > If I use -mat_superlu_dist_parsymbfact=1 or leave this flag out, the
> program crashes with:  Calloc fails for SPA dense[]. at line 438 in file
> zdistribute.c
> > Mahir
> > Sent: den 30 juli 2015 02:58
> > Cc: Xiaoye Li; PETSc users list
> > Subject: Fwd: [petsc-users] SuperLU MPI-problem
> > Mahir,
> > Sherry fixed several bugs in superlu_dist-v4.1.
> > The current petsc-release interfaces with superlu_dist-v4.0.
> > We do not know whether the reported issue (attached below) has been
> resolved or not. If not, can you test it with the latest superlu_dist-v4.1?
> > Here is how to do it:
> > 1. download superlu_dist v4.1
> > 2. remove existing PETSC_ARCH directory, then configure petsc with
> > '--download-superlu_dist=superlu_dist_4.1.tar.gz'
> > 3. build petsc
> > Let us know if the issue remains.
> > Hong
> > ---------- Forwarded message ----------
> > From: Xiaoye S. Li <xsli at lbl.gov<mailto:xsli at lbl.gov>>
> > Date: Wed, Jul 29, 2015 at 2:24 PM
> > To: Hong Zhang <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>>
> > Hong,
> > I am cleaning the mailbox, and saw this unresolved issue.  I am not sure
> whether the new fix to parallel symbolic factorization solves the problem.
> What bothers be is that he is getting the following error:
> > This has nothing to do with my bug fix.
> > ​  Shall we ask him to try the new version, or try to get him matrix?
> > Sherry
> > From: Mahir.Ulker-Kaustell at tyrens.se<mailto:
> > Date: Wed, Jul 22, 2015 at 1:32 PM
> > Subject: RE: [petsc-users] SuperLU MPI-problem
> > To: Hong <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>>, "Xiaoye S.
> Li" <xsli at lbl.gov<mailto:xsli at lbl.gov>>
> > Cc: petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov
> > The 1000 was just a conservative guess. The number of non-zeros per row
> is in the tens in general but certain constraints lead to non-diagonal
> streaks in the sparsity-pattern.
> > Is it the reordering of the matrix that is killing me here? How can I
> set options.ColPerm?
> > If i use -mat_superlu_dist_parsymbfact the program crashes with
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
> batch system) has told this process to end
> > [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS X to find memory corruption errors
> > [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
> and run
> > [0]PETSC ERROR: to get more information on the crash.
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Signal received
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.6.0, Jun, 09, 2015
> > [0]PETSC ERROR: ./solve on a cygwin-complex-nodebug named CZC5202SM2 by
> muk Wed Jul 22 21:59:23 2015
> > [0]PETSC ERROR: Configure options PETSC_DIR=/packages/petsc-3.6.0
> PETSC_ARCH=cygwin-complex-nodebug --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --with-debugging=0 --with-fortran-kernels=1
> --with-scalar-type=complex --download-fblaspack --download-mpich
> --download-scalapack --download-mumps --download-metis --download-parmetis
> --download-superlu --download-superlu_dist --download-fftw
> > [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> > application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> > [unset]: aborting job:
> > [0]PETSC ERROR:
> > If i use -mat_superlu_dist_parsymbfact=1 the program crashes (somewhat
> later) with
> > Malloc fails for Lnzval_bc_ptr[*][] at line 626 in file zdistribute.c
> > col block 3006 -------------------------------------------------------
> > col block 1924 [0]PETSC ERROR:
> and run
> muk Wed Jul 22 21:59:58 2015
> > [0]PETSC ERROR:
> > /Mahir
> > Sent: den 22 juli 2015 21:34
> > To: Xiaoye S. Li
> > Cc: Ülker-Kaustell, Mahir; petsc-users
> > In Petsc/superlu_dist interface, we set default
> > options.ParSymbFact = NO;
> > When user raises the flag "-mat_superlu_dist_parsymbfact",
> > we set
> >     options.ParSymbFact = YES;
> >     options.ColPerm     = PARMETIS;   /* in v2.2, PARMETIS is forced for
> ParSymbFact regardless of user ordering setting */
> > We do not change anything else.
> > Hong
> > On Wed, Jul 22, 2015 at 2:19 PM, Xiaoye S. Li <xsli at lbl.gov<mailto:
> > I am trying to understand your problem. You said you are solving Naviers
> equation (elastodynamics) in the frequency domain, using finite element
> discretization.  I wonder why you have about 1000 nonzeros per row.
> Usually in many PDE discretized matrices, the number of nonzeros per row is
> in the tens (even for 3D problems), not in the thousands.   So, your matrix
> is quite a bit denser than many sparse matrices we deal with.
> > The number of nonzeros in the L and U factors is much more than that in
> original matrix A -- typically we see 10-20x fill ratio for 2D, or can be
> as bad as 50-100x fill ratio for 3D.  But since your matrix starts much
> denser (i.e., the underlying graph has many connections), it may not lend
> to any good ordering strategy to preserve sparsity of L and U; that is, the
> L and U fill ratio may be large.
> > I don't understand why you get the following error when you use
> > ‘-mat_superlu_dist_parsymbfact’.
> > Perhaps Hong Zhang knows; she built the SuperLU_DIST interface for PETSc.
> > ​Hong -- in order to use parallel symbolic factorization, is it
> sufficient to specify only
> > ​ ?  (the default is to use  sequential symbolic factorization.)
> > Sherry
> > On Wed, Jul 22, 2015 at 9:11 AM, Mahir.Ulker-Kaustell at tyrens.se<mailto:
> > Thank you for your reply.
> > As you have probably figured out already, I am not a computational
> scientist. I am a researcher in civil engineering (railways for high-speed
> traffic), trying to produce some, from my perspective, fairly large
> parametric studies based on finite element discretizations.
> > I am working in a Windows-environment and have installed PETSc through
> Cygwin.
> > Apparently, there is no support for Valgrind in this OS.
> > If I have understood you correct, the memory issues are related to
> superLU and given my background, there is not much I can do. Is this
> correct?
> > Best regards,
> > Mahir
> > ______________________________________________
> > Mahir Ülker-Kaustell, Kompetenssamordnare, Brokonstruktör, Tekn. Dr,
> Tyréns AB
> > 010 452 30 82, Mahir.Ulker-Kaustell at tyrens.se<mailto:
> > From: Barry Smith [mailto:bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>]
> > Sent: den 22 juli 2015 02:57
> > Cc: Xiaoye S. Li; petsc-users
> >    Run the program under valgrind
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind . When I use
> the option -mat_superlu_dist_parsymbfact I get many scary memory problems
> some involving for example ddist_psymbtonum (pdsymbfact_distdata.c:1332)
> >    Note that I consider it unacceptable for running programs to EVER use
> uninitialized values; until these are all cleaned up I won't trust any runs
> like this.
> >   Barry
> > ==42050== Conditional jump or move depends on uninitialised value(s)
> > ==42050==    at 0x10274C436: MPI_Allgatherv (allgatherv.c:1053)
> > ==42050==    by 0x101557F60: get_perm_c_parmetis
> (get_perm_c_parmetis.c:285)
> > ==42050==    by 0x101501192: pdgssvx (pdgssvx.c:934)
> > ==42050==    by 0x1009CFE7A: MatLUFactorNumeric_SuperLU_DIST
> (superlu_dist.c:414)
> > ==42050==    by 0x10046CC5C: MatLUFactorNumeric (matrix.c:2946)
> > ==42050==    by 0x100F09F2C: PCSetUp_LU (lu.c:152)
> > ==42050==    by 0x100FF9036: PCSetUp (precon.c:982)
> > ==42050==    by 0x1010F54EB: KSPSetUp (itfunc.c:332)
> > ==42050==    by 0x1010F7985: KSPSolve (itfunc.c:546)
> > ==42050==    by 0x10125541E: SNESSolve_NEWTONLS (ls.c:233)
> > ==42050==    by 0x1011C49B7: SNESSolve (snes.c:3906)
> > ==42050==    by 0x100001B3C: main (in ./ex19)
> > ==42050==  Uninitialised value was created by a stack allocation
> > ==42050==    at 0x10155751B: get_perm_c_parmetis
> (get_perm_c_parmetis.c:96)
> > ==42050==
> > ==42050==    at 0x102851C61: MPIR_Allgatherv_intra (allgatherv.c:651)
> > ==42050==    by 0x102853EC7: MPIR_Allgatherv (allgatherv.c:903)
> > ==42050==    by 0x102853F84: MPIR_Allgatherv_impl (allgatherv.c:944)
> > ==42050==    by 0x10274CA41: MPI_Allgatherv (allgatherv.c:1107)
> > ==42050==
> > ==42049== Syscall param writev(vector[...]) points to uninitialised
> byte(s)
> > ==42049==    at 0x102DA1C3A: writev (in
> /usr/lib/system/libsystem_kernel.dylib)
> > ==42049==    by 0x10296A0DC: MPL_large_writev (mplsock.c:32)
> > ==42049==    by 0x10295F6AD: MPIDU_Sock_writev (sock_immed.i:610)
> > ==42049==    by 0x102943FCA: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==42049==    by 0x102934361: MPIDI_CH3_EagerContigIsend
> (ch3u_eager.c:556)
> > ==42049==    by 0x102939531: MPID_Isend (mpid_isend.c:138)
> > ==42049==    by 0x10277656E: MPI_Isend (isend.c:125)
> > ==42049==    by 0x102088B66: libparmetis__gkMPI_Isend (gkmpi.c:63)
> > ==42049==    by 0x10208140F: libparmetis__CommInterfaceData (comm.c:298)
> > ==42049==    by 0x1020A8758: libparmetis__CompactGraph (ometis.c:553)
> > ==42049==    by 0x1020A77BB: libparmetis__MultilevelOrder (ometis.c:225)
> > ==42049==    by 0x1020A7493: ParMETIS_V32_NodeND (ometis.c:151)
> > ==42049==    by 0x1020A6AFB: ParMETIS_V3_NodeND (ometis.c:34)
> > ==42049==    by 0x101557CFC: get_perm_c_parmetis
> (get_perm_c_parmetis.c:241)
> > ==42049==    by 0x101501192: pdgssvx (pdgssvx.c:934)
> > ==42049==    by 0x1009CFE7A: MatLUFactorNumeric_SuperLU_DIST
> > ==42049==    by 0x10046CC5C: MatLUFactorNumeric (matrix.c:2946)
> > ==42049==    by 0x100F09F2C: PCSetUp_LU (lu.c:152)
> > ==42049==    by 0x100FF9036: PCSetUp (precon.c:982)
> > ==42048== Syscall param writev(vector[...]) points to uninitialised
> byte(s)
> > ==42049==    by 0x1010F54EB: KSPSetUp (itfunc.c:332)
> > ==42049==  Address 0x105edff70 is 1,424 bytes inside a block of size
> 752,720 alloc'd
> > ==42049==    at 0x1000183B1: malloc (vg_replace_malloc.c:303)
> > ==42049==    by 0x1020EB90C: gk_malloc (memory.c:147)
> > ==42049==    by 0x1020EAA28: gk_mcoreCreate (mcore.c:28)
> > ==42048==    at 0x102DA1C3A: writev (in
> > ==42048==    by 0x10296A0DC: MPL_large_writev (mplsock.c:32)
> > ==42049==    by 0x1020BA5CF: libparmetis__AllocateWSpace (wspace.c:23)
> > ==42049==    by 0x1020A6E84: ParMETIS_V32_NodeND (ometis.c:98)
> > ==42048==    by 0x10295F6AD: MPIDU_Sock_writev (sock_immed.i:610)
> > ==42048==    by 0x102943FCA: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==42048==    by 0x102934361: MPIDI_CH3_EagerContigIsend
> (ch3u_eager.c:556)
> > ==42048==    by 0x102939531: MPID_Isend (mpid_isend.c:138)
> > ==42048==    by 0x10277656E: MPI_Isend (isend.c:125)
> > ==42048==    by 0x102088B66: libparmetis__gkMPI_Isend (gkmpi.c:63)
> > ==42048==    by 0x10208140F: libparmetis__CommInterfaceData (comm.c:298)
> > ==42049==    by 0x1010F7985: KSPSolve (itfunc.c:546)
> > ==42049==    by 0x10125541E: SNESSolve_NEWTONLS (ls.c:233)
> > ==42048==    by 0x1020A8758: libparmetis__CompactGraph (ometis.c:553)
> > ==42048==    by 0x1020A77BB: libparmetis__MultilevelOrder (ometis.c:225)
> > ==42048==    by 0x1020A7493: ParMETIS_V32_NodeND (ometis.c:151)
> > ==42049==    by 0x1011C49B7: SNESSolve (snes.c:3906)
> > ==42049==    by 0x100001B3C: main (in ./ex19)
> > ==42049==  Uninitialised value was created by a heap allocation
> > ==42048==    by 0x1020A6AFB: ParMETIS_V3_NodeND (ometis.c:34)
> > ==42048==    by 0x101557CFC: get_perm_c_parmetis
> > ==42048==    by 0x101501192: pdgssvx (pdgssvx.c:934)
> > ==42048==    by 0x1009CFE7A: MatLUFactorNumeric_SuperLU_DIST
> > ==42049==    by 0x10211C50B: libmetis__imalloc (gklib.c:24)
> > ==42049==    by 0x1020A8566: libparmetis__CompactGraph (ometis.c:519)
> > ==42048==    by 0x10046CC5C: MatLUFactorNumeric (matrix.c:2946)
> > ==42048==    by 0x100F09F2C: PCSetUp_LU (lu.c:152)
> > ==42048==    by 0x100FF9036: PCSetUp (precon.c:982)
> > ==42048==    by 0x1010F54EB: KSPSetUp (itfunc.c:332)
> > ==42048==  Address 0x10597a860 is 1,408 bytes inside a block of size
> 752,720 alloc'd
> > ==42049==
> > ==42048==    at 0x1000183B1: malloc (vg_replace_malloc.c:303)
> > ==42048==    by 0x1020EB90C: gk_malloc (memory.c:147)
> > ==42048==    by 0x1020EAA28: gk_mcoreCreate (mcore.c:28)
> > ==42048==    by 0x1020BA5CF: libparmetis__AllocateWSpace (wspace.c:23)
> > ==42048==    by 0x1020A6E84: ParMETIS_V32_NodeND (ometis.c:98)
> > ==42048==    by 0x1010F7985: KSPSolve (itfunc.c:546)
> > ==42048==    by 0x10125541E: SNESSolve_NEWTONLS (ls.c:233)
> > ==42048==    by 0x1011C49B7: SNESSolve (snes.c:3906)
> > ==42048==    by 0x100001B3C: main (in ./ex19)
> > ==42048==  Uninitialised value was created by a heap allocation
> > ==42048==    by 0x10211C50B: libmetis__imalloc (gklib.c:24)
> > ==42048==    by 0x1020A8566: libparmetis__CompactGraph (ometis.c:519)
> > ==42048==
> > ==42048== Syscall param write(buf) points to uninitialised byte(s)
> > ==42048==    at 0x102DA1C22: write (in
> > ==42048==    by 0x10295F5BD: MPIDU_Sock_write (sock_immed.i:525)
> > ==42048==    by 0x102944839: MPIDI_CH3_iStartMsg (ch3_istartmsg.c:86)
> > ==42048==    by 0x102933B80: MPIDI_CH3_EagerContigShortSend
> (ch3u_eager.c:257)
> > ==42048==    by 0x10293ADBA: MPID_Send (mpid_send.c:130)
> > ==42048==    by 0x10277A1FA: MPI_Send (send.c:127)
> > ==42048==    by 0x10155802F: get_perm_c_parmetis
> (get_perm_c_parmetis.c:299)
> > ==42048==  Address 0x104810704 is on thread 1's stack
> > ==42048==  in frame #3, created by MPIDI_CH3_EagerContigShortSend
> (ch3u_eager.c:218)
> > ==42048==    by 0x10153B704: superlu_malloc_dist (memory.c:108)
> > ==42048==    by 0x101557AB9: get_perm_c_parmetis
> (get_perm_c_parmetis.c:185)
> > ==42048==
> > ==42050==    at 0x102744CB8: MPI_Alltoallv (alltoallv.c:480)
> > ==42050==    by 0x101510B3E: dist_symbLU (pdsymbfact_distdata.c:539)
> > ==42050==    by 0x10150A5C6: ddist_psymbtonum
> (pdsymbfact_distdata.c:1275)
> > ==42050==    by 0x1015018C2: pdgssvx (pdgssvx.c:1057)
> > ==42050==    at 0x10150E4C4: dist_symbLU (pdsymbfact_distdata.c:96)
> > ==42050==
> > ==42050==    at 0x102744E43: MPI_Alltoallv (alltoallv.c:490)
> > ==42050==
> > ==42050==    at 0x102744EBF: MPI_Alltoallv (alltoallv.c:497)
> > ==42050==
> > ==42050==    at 0x1027450B1: MPI_Alltoallv (alltoallv.c:512)
> > ==42050==
> > ==42050==    at 0x10283FB06: MPIR_Alltoallv_intra (alltoallv.c:92)
> > ==42050==    by 0x1028407B6: MPIR_Alltoallv (alltoallv.c:343)
> > ==42050==    by 0x102840884: MPIR_Alltoallv_impl (alltoallv.c:380)
> > ==42050==    by 0x10274541B: MPI_Alltoallv (alltoallv.c:531)
> > ==42050==
> > ==42050== Syscall param writev(vector[...]) points to uninitialised
> byte(s)
> > ==42050==    at 0x102DA1C3A: writev (in
> > ==42050==    by 0x10296A0DC: MPL_large_writev (mplsock.c:32)
> > ==42050==    by 0x10295F6AD: MPIDU_Sock_writev (sock_immed.i:610)
> > ==42050==    by 0x102943FCA: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==42050==    by 0x102934361: MPIDI_CH3_EagerContigIsend
> (ch3u_eager.c:556)
> > ==42050==    by 0x102939531: MPID_Isend (mpid_isend.c:138)
> > ==42050==    by 0x10277656E: MPI_Isend (isend.c:125)
> > ==42050==    by 0x101524C41: pdgstrf2_trsm (pdgstrf2.c:201)
> > ==42050==    by 0x10151ECBF: pdgstrf (pdgstrf.c:1082)
> > ==42050==    by 0x1015019A5: pdgssvx (pdgssvx.c:1069)
> > ==42050==  Address 0x1060144d0 is 1,168 bytes inside a block of size
> 131,072 alloc'd
> > ==42050==    at 0x1000183B1: malloc (vg_replace_malloc.c:303)
> > ==42050==    by 0x10153B704: superlu_malloc_dist (memory.c:108)
> > ==42050==    by 0x1014FD7AD: doubleMalloc_dist (dmemory.c:145)
> > ==42050==    by 0x10151DA7D: pdgstrf (pdgstrf.c:735)
> > ==42050==  Uninitialised value was created by a heap allocation
> > ==42050==
> > ==42048== Conditional jump or move depends on uninitialised value(s)
> > ==42048==    at 0x10151F141: pdgstrf (pdgstrf.c:1139)
> > ==42048==    by 0x1015019A5: pdgssvx (pdgssvx.c:1069)
> > ==42048==    by 0x10150ABE2: ddist_psymbtonum
> > ==42048==    by 0x1015018C2: pdgssvx (pdgssvx.c:1057)
> > ==42048==
> > ==42049== Conditional jump or move depends on uninitialised value(s)
> > ==42049==    at 0x10151F141: pdgstrf (pdgstrf.c:1139)
> > ==42049==    by 0x1015019A5: pdgssvx (pdgssvx.c:1069)
> > ==42049==    by 0x10153B704: superlu_malloc_dist (memory.c:108)
> > ==42049==    by 0x10150ABE2: ddist_psymbtonum
> > ==42049==    by 0x1015018C2: pdgssvx (pdgssvx.c:1057)
> > ==42049==
> > ==42048==    at 0x101520054: pdgstrf (pdgstrf.c:1429)
> > ==42049==    at 0x101520054: pdgstrf (pdgstrf.c:1429)
> > ==42048==
> > ==42049==
> > ==42050==    at 0x10151FDE6: pdgstrf (pdgstrf.c:1382)
> > ==42050==    by 0x10150B241: ddist_psymbtonum
> (pdsymbfact_distdata.c:1389)
> > ==42050==
> > > On Jul 20, 2015, at 12:03 PM, Mahir.Ulker-Kaustell at tyrens.se<mailto:
> > > Ok. So I have been creating the full factorization on each process.
> That gives me some hope!
> > > I followed your suggestion and tried to use the runtime option
> > > However, now the program crashes with:
> > > And so on…
> > > From the SuperLU manual; I should give the option either YES or NO,
> however -mat_superlu_dist_parsymbfact YES makes the program crash in the
> same way as above.
> > > Also I can’t find any reference to -mat_superlu_dist_parsymbfact in
> the PETSc documentation
> > > Mahir
> Tyréns AB
> > > From: Xiaoye S. Li [mailto:xsli at lbl.gov<mailto:xsli at lbl.gov>]
> > > Sent: den 20 juli 2015 18:12
> > > Cc: Hong; petsc-users
> > > The default SuperLU_DIST setting is to serial symbolic factorization.
> Therefore, what matters is how much memory do you have per MPI task?
> > > The code failed to malloc memory during redistribution of matrix A to
> {L\U} data struction (using result of serial symbolic factorization.)
> > > You can use parallel symbolic factorization, by runtime option:
> > > Sherry Li
> > > On Mon, Jul 20, 2015 at 8:59 AM, Mahir.Ulker-Kaustell at tyrens.se
> <mailto:Mahir.Ulker-Kaustell at tyrens.se> <Mahir.Ulker-Kaustell at tyrens.se
> <mailto:Mahir.Ulker-Kaustell at tyrens.se>> wrote:
> > > Hong:
> > > Previous experiences with this equation have shown that it is very
> difficult to solve it iteratively. Hence the use of a direct solver.
> > > The large test problem I am trying to solve has slightly less than
> 10^6 degrees of freedom. The matrices are derived from finite elements so
> they are sparse.
> > > The machine I am working on has 128GB ram. I have estimated the memory
> needed to less than 20GB, so if the solver needs twice or even three times
> as much, it should still work well. Or have I completely misunderstood
> something here?
> > > Mahir
> > > Sent: den 20 juli 2015 17:39
> > > Cc: petsc-users
> > > Mahir:
> > > Direct solvers consume large amount of memory. Suggest to try
> followings:
> > > 1. A sparse iterative solver if  [-omega^2M + K] is not too
> ill-conditioned. You may test it using the small matrix.
> > > 2. Incrementally increase your matrix sizes. Try different matrix
> orderings.
> > > Do you get memory crash in the 1st symbolic factorization?
> > > In your case, matrix data structure stays same when omega changes, so
> you only need to do one matrix symbolic factorization and reuse it.
> > > 3. Use a machine that gives larger memory.
> > > Hong
> > > Dear Petsc-Users,
> > > I am trying to use PETSc to solve a set of linear equations arising
> from Naviers equation (elastodynamics) in the frequency domain.
> > > The frequency dependency of the problem requires that the system
> > >                              [-omega^2M + K]u = F
> > > where M and K are constant, square, positive definite matrices (mass
> and stiffness respectively) is solved for each frequency omega of interest.
> > > K is a complex matrix, including material damping.
> > > I have written a PETSc program which solves this problem for a small
> (1000 degrees of freedom) test problem on one or several processors, but it
> keeps crashing when I try it on my full scale (in the order of 10^6 degrees
> of freedom) problem.
> > > The program crashes at KSPSetUp() and from what I can see in the error
> messages, it appears as if it consumes too much memory.
> > > I would guess that similar problems have occurred in this mail-list,
> so I am hoping that someone can push  me in the right direction…
> > > Mahir
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150811/69696ce0/attachment-0001.html>
