[petsc-users] checking jacobian
Tue Aug 11 13:03:05 CDT 2015
On Tue, Aug 11, 2015 at 12:51 PM, Gideon Simpson <gideon.simpson at gmail.com>
wrote:
> #End of PETSc Option Table entries
> There is one unused database option. It is:
> Option left: name:-snes_check_jacobian_view (no value)
This is the option for the newest release. What are you using?
   Matt
> -gideon
> On Aug 11, 2015, at 1:50 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Aug 11, 2015 at 12:49 PM, Gideon Simpson <gideon.simpson at gmail.com
> > wrote:
>> Maybe it’s a quirk of the macports installation of petsc, but nothing
>> seems to be getting generated.
> Run with -options_left. Is it reading the option?
>   Matt
>> -gideon
>> On Aug 11, 2015, at 1:40 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Gideon Simpson <gideon.simpson at gmail.com> writes:
>> I’m a bit confused by the following options:
>> Run with -snes_check_jacobian_view [viewer][:filename][:format] to show
>> difference of hand-coded and finite difference Jacobian.
>> What flags do I pass it to get some output to diagnose my Jacobian error?
>> Nothing to display ASCII to the screen.  You might use
>> "binary:thematrix" if you want to read it in with Python or MATLAB, for
>> example.
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150811/5dbb8818/attachment.html>
