[petsc-users] SIGSEGV in Superlu_dist
Anthony Haas aph at email.arizona.edu
Mon Aug 10 15:50:50 CDT 2015
Hi Sherry,
I recently submitted a matrix for which I noticed that Superlu_dist was
hanging when running on 4 processors with parallel symbolic
factorization. I have been using the latest version of Superlu_dist and
the code is not hanging anymore. However, I noticed that when running
the same matrix (I have attached the matrix), the code crashes with the
following SIGSEGV when running on 10 procs (with or without parallel
symbolic factorization). It is probably overkill to run such a 'small'
matrix on 10 procs but I thought that it might still be useful to report
the problem?? See below for the error obtained when running with gdb and
also a code snippet to reproduce the error.
Anthony
1) ERROR in GDB
Program received signal SIGSEGV, Segmentation fault.
0x00007fe6ba609297 in MatLUFactorNumeric_SuperLU_DIST (F=0x1922b50,
     A=0x14a6a70, info=0x19099f8)
     at
/home/anthony/LIB/petsc-3.6.1/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:368
368           colA_start = rstart + ajj[0]; /* the smallest global col
index of A */
(gdb)
2) PORTION OF CODE TO REPRODUCE ERROR
     Subroutine HowBigLUCanBe(rank)
       IMPLICIT NONE
       integer(i4b),intent(in) :: rank
       integer(i4b)            :: i,ct
       real(dp)                :: begin,endd
       complex(dpc)            :: sigma
       PetscErrorCode ierr
       if (rank==0) call cpu_time(begin)
       if (rank==0) then
          write(*,*)
          write(*,*)'Testing How Big LU Can Be...'
          write(*,*)'============================'
          write(*,*)
       endif
       !sigma = (1.0d0,0.0d0)
       !call MatAXPY(A,-sigma,B,DIFFERENT_NONZERO_PATTERN,ierr) ! on
exit A = A-sigma*B
       !call MatView(A,PETSC_VIEWER_STDOUT_WORLD,ierr)
!.....Write Matrix to ASCII and Binary Format
       !call PetscViewerASCIIOpen(PETSC_COMM_WORLD,"Amat.m",viewer,ierr)
       !call MatView(DXX,viewer,ierr)
       !call PetscViewerDestroy(viewer,ierr)
       !call
PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Amat_binary.m",FILE_MODE_WRITE,viewer,ierr)
       !call MatView(A,viewer,ierr)
!...Load a Matrix in Binary Format
       call
PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Amat_binary.m",FILE_MODE_READ,viewer,ierr)
       call MatCreate(PETSC_COMM_WORLD,DLOAD,ierr)
       call MatSetType(DLOAD,MATAIJ,ierr)
       call MatLoad(DLOAD,viewer,ierr)
       !call MatView(DLOAD,PETSC_VIEWER_STDOUT_WORLD,ierr)
!.....Create Linear Solver Context
       call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
!.....Set operators. Here the matrix that defines the linear system also
serves as the preconditioning matrix.
       !call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
!aha commented and replaced by next line
       !call KSPSetOperators(ksp,A,A,ierr) ! remember: here A = A-sigma*B
       call KSPSetOperators(ksp,DLOAD,DLOAD,ierr) ! remember: here A =
A-sigma*B
!.....Set Relative and Absolute Tolerances and Uses Default for
Divergence Tol
       tol = 1.e-10
       call
KSPSetTolerances(ksp,tol,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr)
!.....Set the Direct (LU) Solver
       call KSPSetType(ksp,KSPPREONLY,ierr)
       call KSPGetPC(ksp,pc,ierr)
       call PCSetType(pc,PCLU,ierr)
       call PCFactorSetMatSolverPackage(pc,MATSOLVERSUPERLU_DIST,ierr) !
MATSOLVERSUPERLU_DIST MATSOLVERMUMPS
!.....Create Right-Hand-Side Vector
       !call MatCreateVecs(A,frhs,PETSC_NULL_OBJECT,ierr)
       !call MatCreateVecs(A,sol,PETSC_NULL_OBJECT,ierr)
       call MatCreateVecs(DLOAD,frhs,PETSC_NULL_OBJECT,ierr)
       call MatCreateVecs(DLOAD,sol,PETSC_NULL_OBJECT,ierr)
       call MatGetOwnershipRange(DLOAD,IstartA,IendA,ierr)!;CHKERRQ(ierr)
       allocate(xwork1(IendA-IstartA))
       allocate(loc(IendA-IstartA))
       ct=0
       do i=IstartA,IendA-1
          ct=ct+1
          loc(ct)=i
          xwork1(ct)=(1.0d0,0.0d0)
       enddo
       call VecSetValues(frhs,IendA-IstartA,loc,xwork1,INSERT_VALUES,ierr)
       call VecZeroEntries(sol,ierr)
       deallocate(xwork1,loc)
!.....Assemble Vectors
       call VecAssemblyBegin(frhs,ierr)
       call VecAssemblyEnd(frhs,ierr)
!.....Solve the Linear System
       call KSPSolve(ksp,frhs,sol,ierr)
       !call VecView(sol,PETSC_VIEWER_STDOUT_WORLD,ierr)
       if (rank==0) then
          call cpu_time(endd)
          write(*,*)
          print '("Total time for HowBigLUCanBe = ",f21.3,"
seconds.")',endd-begin
       endif
       call SlepcFinalize(ierr)
       STOP
     end Subroutine HowBigLUCanBe
Type: text/x-objcsrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150810/eecf73d6/attachment-0001.bin>
-matload_block_size 1
