[petsc-users] SLEPc fails with POWER ITERATION method
Xujun Zhao xzhao99 at gmail.com
Fri Aug 7 12:05:47 CDT 2015
Hi Jose,
Thank you for your answer. The problem now is solved with setting
EPS_LARGEST_MAGNITUDE.
Xujun
On Fri, Aug 7, 2015 at 11:53 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> The power method only works with which=EPS_LARGEST_MAGNITUDE (or
> which=EPS_TARGET_MAGNITUDE if doing shift-and-invert). The rationale is
> that the power iteration converges to the dominant eigenvalue (the one with
> largest absolute value).
> Jose
> > El 7/8/2015, a las 18:21, Xujun Zhao <xzhao99 at gmail.com> escribió:
> > Hi all,
> > I am solving the max eigenvalue of a Shell matrix using SLEPc. the Shell
> operation is set MATOP_MULT with user-defined function u = M*f. It works
> with the Krylov-Schur and Arnoldi method, but fails when I use Power
> Iteration method and several others. This is strange, because some of those
> are supposed to work with any type of problem.
> > I also wrote a power iteration algorithm by myself, and it works well
> and obtains the same results with that from Krylov_Schur. I am curious why
> this doesn't work is SLEPc. The following are my code and error messages:
> >   ierr = MatSetFromOptions(M);      CHKERRQ(ierr);
> >   ierr =
> MatShellSetOperation(M,MATOP_MULT,(void(*)())_MatMult_Stokes);CHKERRQ(ierr);
> >   ierr = PetscPrintf(PETSC_COMM_WORLD,"\n");
> >   printf("--->test: n = %d, N = %d, rank = %d\n",n, N, (int)rank);
> >    Create the eigensolver and set various options
> >   ierr = EPSCreate(PETSC_COMM_WORLD,&eps);  CHKERRQ(ierr);
> >   ierr = EPSSetOperators(eps,M,NULL);       CHKERRQ(ierr);
> >   ierr = EPSSetProblemType(eps,EPS_HEP);   CHKERRQ(ierr);
> >   // EPSKRYLOVSCHUR(Default)/EPSARNOLDI/
> >   // does NOT work: EPSPOWER/EPSLANCZOS/EPSSUBSPACE
> >   ierr = EPSSetType(eps,EPSPOWER);          CHKERRQ(ierr);
> >   /*  Select portion of spectrum */
> >   if(option=="smallest")  // LOBPCG for smallest eigenvalue problem!
> >   { ierr = EPSSetWhichEigenpairs(eps,EPS_SMALLEST_REAL);CHKERRQ(ierr);  }
> >   else if(option=="largest")
> >   { ierr = EPSSetWhichEigenpairs(eps,EPS_LARGEST_REAL); CHKERRQ(ierr);  }
> >   else
> >   { ierr = EPSSetFromOptions(eps);  CHKERRQ(ierr);  }
> >   // end if-else
> >   // Set the tolerance and maximum iteration
> >   ierr = EPSSetTolerances(eps,  tol,  maxits);  CHKERRQ(ierr);
> >   ierr = PetscPrintf(PETSC_COMM_WORLD,"EPS tol = %f, maxits =
> %d\n",tol,maxits);CHKERRQ(ierr);
> >    Solve the eigensystem and get the solution
> >   ierr = PetscPrintf(PETSC_COMM_WORLD,"EPS solve starts
> ...\n");CHKERRQ(ierr);
> >   ierr = EPSSolve(eps);CHKERRQ(ierr);
> > EPS tol = 0.000001, maxits = 100
> > EPS solve starts ...
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Wrong value of eps->which
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
> > [0]PETSC ERROR: ./example-opt on a arch-darwin-c-opt named
> mcswl121.mcs.anl.gov by xzhao Fri Aug  7 10:31:38 2015
> > [0]PETSC ERROR: Configure options --with-cc=gcc-4.9 --with-cxx=g++-4.9
> --with-fc=gfortran-4.9 --with-cxx-dialect=C++11 --download-mpich
> --download-fblaslapack --download-scalapack --download-mumps
> --download-superlu_dist --download-hypre --download-ml --download-parmetis
> --download-metis --download-triangle --download-chaco --download-elemental
> --with-debugging=0
> > [0]PETSC ERROR: #1 EPSSetUp_Power() line 64 in
> /Users/xzhao/software/slepc/slepc-3.5.4/src/eps/impls/power/power.c
> > [0]PETSC ERROR: #2 EPSSetUp() line 120 in
> /Users/xzhao/software/slepc/slepc-3.5.4/src/eps/interface/epssetup.c
> > [0]PETSC ERROR: #3 EPSSolve() line 88 in
> /Users/xzhao/software/slepc/slepc-3.5.4/src/eps/interface/epssolve.c
> > [0]PETSC ERROR: #4 compute_eigenvalue() line 318 in brownian_system.C
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150807/b3d9b9bb/attachment.html>
