[petsc-users] I am wondering if there is a way to implement SPMM
Cong Li solvercorleone at gmail.com
Thu Aug 6 20:08:25 CDT 2015
Hong,
>>A subspace with dense matrices as basis?
>>How large step_k and your matrices will be?
So far, I are not very sure how large it's gonna be in the future. But I
use less than 50 right now.
However, I hope it can be as large as possible.
Cong Li
On Fri, Aug 7, 2015 at 12:20 AM, Hong <hzhang at mcs.anl.gov> wrote:
> Cong:
>> Hong,
>> Sure.
>> I want to extend the Krylov subspace by step_k dimensions by using
>> monomial, which can be defined as
>> K={Km(1)m Km(2), ..., Km(step_k)}
>>   ={Km(1), AKm(1), AKm(2), ... , AKm(step_k-1)}
>>   ={R, AR, A^2R, ... A^(step_k-1)R}
> Hong
>> On Thu, Aug 6, 2015 at 12:23 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>> Cong,
>>> Can you write out math equations for mpk_monomial (),
>>> list input and output parameters.
>>> Note:
>>> 1. MatDuplicate() does not need to be followed by MatAssemblyBegin/End
>>> 2. MatMatMult(A,Km(stepIdx-1),MAT_REUSE_MATRIX,..) must be called after
>>>     MatMatMult(A,Km(stepIdx-1),MAT_INITIAL_MATRIX,..)
>>> Hong
>>> On Wed, Aug 5, 2015 at 8:56 PM, Cong Li <solvercorleone at gmail.com>
>>> wrote:
>>>> The entire source code files are attached.
>>>> Also I copy and paste the here in this email
>>>> thanks
>>>> program test
>>>>   implicit none
>>>> #include <finclude/petscsys.h>
>>>> #include <finclude/petscvec.h>
>>>> #include <finclude/petscmat.h>
>>>> #include <finclude/petscviewer.h>
>>>>   PetscViewer    :: view
>>>>   ! sparse matrix
>>>>   Mat            :: A
>>>>   ! distributed dense matrix of size n x m
>>>>   Mat            :: B, X, R, QDlt, AQDlt
>>>>   ! distributed dense matrix of size n x (m x k)
>>>>   Mat            :: Q, K, AQ_p, AQ
>>>>   ! local dense matrix (every process keep the identical copies), (m x
>>>> k) x (m x k)
>>>>   Mat            :: AConjPara, QtAQ, QtAQ_p, Dlt
>>>>   PetscInt       :: nDim, mDim, rhsNDim,rhsMDim,ierr, maxIter, iter,
>>>> step_k,bsize
>>>>   PetscInt       :: ownRowS,ownRowE
>>>>   PetscScalar, allocatable :: XInit(:,:)
>>>>   PetscInt       :: XInitI, XInitJ
>>>>   PetscScalar    :: v=1.0
>>>>   PetscBool      :: flg
>>>>   PetscMPIInt    :: size, rank
>>>>   character(128) ::  fin, rhsfin
>>>>   call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>>>   call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
>>>>   call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
>>>>   ! read binary matrix file
>>>>   call PetscOptionsGetString(PETSC_NULL_CHARACTER,'-f',fin,flg,ierr)
>>>>   call PetscOptionsGetString(PETSC_NULL_CHARACTER,'-r',rhsfin,flg,ierr)
>>>>   call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-i',maxIter,flg,ierr)
>>>>   call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-k',step_k,flg,ierr)
>>>>   call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-w',bsize,flg,ierr)
>>>>   call
>>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,fin,FILE_MODE_READ,view,ierr)
>>>>   call MatCreate(PETSC_COMM_WORLD,A,ierr)
>>>>   call MatSetType(A,MATAIJ,ierr)
>>>>   call MatLoad(A,view,ierr)
>>>>   call PetscViewerDestroy(view,ierr)
>>>>   ! for the time being, assume mDim == nDim is true
>>>>   call MatGetSize(A, nDim, mDim, ierr)
>>>>   if (rank == 0) then
>>>>     print*,'Mat Size = ', nDim, mDim
>>>>   end if
>>>>   call MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatGetOwnershipRange(A,ownRowS,ownRowE, ierr)
>>>>   ! create right-and-side matrix
>>>>   ! for the time being, choose row-wise decomposition
>>>>   ! for the time being, assume nDim%size = 0
>>>>   call MatCreateDense(PETSC_COMM_WORLD, (ownRowE - ownRowS), &
>>>>                       bsize, nDim, bsize,PETSC_NULL_SCALAR, B, ierr)
>>>>   call
>>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,rhsfin,FILE_MODE_READ,view, ierr)
>>>>   call MatLoad(B,view,ierr)
>>>>   call MatGetSize(B, rhsMDim, rhsNDim, ierr)
>>>>   if (rank == 0) then
>>>>     print*,'MRHS Size actually are:', rhsMDim, rhsNDim
>>>>     print*,'MRHS Size should be:', nDim, bsize
>>>>   end if
>>>>   call MatAssemblyBegin(B, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd(B, MAT_FINAL_ASSEMBLY, ierr)
>>>>   ! inintial value guses X
>>>>   allocate(XInit(nDim,bsize))
>>>>   do XInitI=1, nDim
>>>>     do XInitJ=1, bsize
>>>>       XInit(XInitI,XInitJ) = 1.0
>>>>     end do
>>>>   end do
>>>>                       bsize, nDim, bsize,XInit, X, ierr)
>>>>   call MatAssemblyBegin(X, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd  (X, MAT_FINAL_ASSEMBLY, ierr)
>>>>   !  B, X, R, QDlt, AQDlt
>>>>   call MatDuplicate(B, MAT_DO_NOT_COPY_VALUES, R, ierr)
>>>>   call MatAssemblyBegin(R, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd  (R, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatDuplicate(B, MAT_DO_NOT_COPY_VALUES, QDlt, ierr)
>>>>   call MatAssemblyBegin(QDlt, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd  (QDlt, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatDuplicate(B, MAT_DO_NOT_COPY_VALUES, AQDlt, ierr)
>>>>   call MatAssemblyBegin(AQDlt, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd  (AQDlt, MAT_FINAL_ASSEMBLY, ierr)
>>>> ! Q, K, AQ_p, AQ of size n x (m x k)
>>>>                       (bsize*step_k), nDim,
>>>> (bsize*step_k),PETSC_NULL_SCALAR, Q, ierr)
>>>>   call MatAssemblyBegin(Q, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd(Q, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatDuplicate(Q, MAT_DO_NOT_COPY_VALUES, K, ierr)
>>>>   call MatAssemblyBegin(K, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd(K, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatDuplicate(Q, MAT_DO_NOT_COPY_VALUES, AQ_p, ierr)
>>>>   call MatAssemblyBegin(AQ_p, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd(AQ_p, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatDuplicate(Q, MAT_DO_NOT_COPY_VALUES, AQ, ierr)
>>>>   call MatAssemblyBegin(AQ, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd(AQ, MAT_FINAL_ASSEMBLY, ierr)
>>>> ! QtAQ, QtAQ_p, Dlt of size (m x k) x (m x k)
>>>>   call MatCreateSeqDense(PETSC_COMM_SELF,(bsize*step_k),(bsize*step_k),&
>>>>                          PETSC_NULL_SCALAR, QtAQ, ierr)
>>>>   call MatAssemblyBegin(QtAQ, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd  (QtAQ, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatDuplicate(QtAQ, MAT_DO_NOT_COPY_VALUES, QtAQ_p    , ierr)
>>>>   call MatAssemblyBegin(QtAQ_p, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd  (QtAQ_p, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatDuplicate(QtAQ, MAT_DO_NOT_COPY_VALUES, Dlt       , ierr)
>>>>   call MatAssemblyBegin(Dlt, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd  (Dlt, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatDuplicate(QtAQ, MAT_DO_NOT_COPY_VALUES, AConjPara , ierr)
>>>>   call MatAssemblyBegin(AConjPara, MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd  (AConjPara, MAT_FINAL_ASSEMBLY, ierr)
>>>> ! calculation for R
>>>> ! call matrix powers kernel
>>>>   call mpk_monomial (K, A, R, step_k, rank,size)
>>>> ! destory matrices
>>>>   deallocate(XInit)
>>>>   call MatDestroy(B, ierr)
>>>>   call MatDestroy(X, ierr)
>>>>   call MatDestroy(R, ierr)
>>>>   call MatDestroy(QDlt, ierr)
>>>>   call MatDestroy(AQDlt, ierr)
>>>>   call MatDestroy(Q, ierr)
>>>>   call MatDestroy(K, ierr)
>>>>   call MatDestroy(AQ_p, ierr)
>>>>   call MatDestroy(AQ, ierr)
>>>>   call MatDestroy(QtAQ, ierr)
>>>>   call MatDestroy(QtAQ_p, ierr)
>>>>   call MatDestroy(Dlt, ierr)
>>>>   call PetscFinalize(ierr)
>>>>   stop
>>>> end program test
>>>> subroutine mpk_monomial (K, A, R, step_k, rank, sizeMPI)
>>>> implicit none
>>>> Mat            :: K, Km(step_k)
>>>> Mat            :: A, R
>>>> PetscMPIInt    :: sizeMPI, rank
>>>> PetscInt       :: nDim, bsize, step_k, local_RRow, local_RCol, genIdx
>>>> PetscInt       :: ierr
>>>> PetscInt       :: stepIdx, blockShift, localRsize
>>>>   PetscScalar    :: KArray(1), RArray(1), PetscScalarSize
>>>>   PetscOffset    :: KArrayOffset, RArrayOffset
>>>> call MatGetSize(R, nDim, bsize, ierr)
>>>>   if (rank == 0) then
>>>>    print*,'Mat Size = ', nDim, bsize
>>>>   end if
>>>>   call MatGetArray(K,KArray,KArrayOffset,ierr)
>>>>   call MatGetLocalSize(R,local_RRow,local_RCol)
>>>> !   print *, "local_RRow,local_RCol", local_RRow,local_RCol
>>>>   ! get arry from R to add values to K(1)
>>>>   call MatGetArray(R,RArray,RArrayOffset,ierr)
>>>>   call MatCreateDense(PETSC_COMM_WORLD,  PETSC_DECIDE, &
>>>>                         PETSC_DECIDE , nDim, bsize,KArray(KArrayOffset
>>>> + 1), Km(1), ierr)
>>>> !   call PetscMemmove(KArray(KArrayOffset + 1),RArray(RArrayOffset + 1)
>>>> !                  ,local_RRow * local_RCol *
>>>> STORAGE_SIZE(PetscScalarSize), ierr)
>>>>   localRsize = local_RRow * local_RCol
>>>>   do genIdx= 1, localRsize
>>>>     KArray(KArrayOffset + genIdx) = RArray(RArrayOffset + genIdx)
>>>>   end do
>>>>   call MatRestoreArray(R,RArray,RArrayOffset,ierr)
>>>>   call MatAssemblyBegin(Km(1), MAT_FINAL_ASSEMBLY, ierr)
>>>>   call MatAssemblyEnd  (Km(1), MAT_FINAL_ASSEMBLY, ierr)
>>>>   do stepIdx= 2, step_k
>>>>     blockShift = KArrayOffset + (stepIdx-1) * (local_RRow * local_RCol)
>>>> bsize,KArray(blockShift+1), Km(stepIdx), ierr)
>>>>     call MatAssemblyBegin(Km(stepIdx), MAT_FINAL_ASSEMBLY, ierr)
>>>>     call MatAssemblyEnd  (Km(stepIdx), MAT_FINAL_ASSEMBLY, ierr)
>>>>   end do
>>>>   call MatRestoreArray(K,KArray,KArrayOffset,ierr)
>>>> !   do stepIdx= 2, step_k
>>>>   do stepIdx= 2,2
>>>>     call
>>>> MatMatMult(A,Km(stepIdx-1),MAT_REUSE_MATRIX,PETSC_DEFAULT_INTEGER,Km(stepIdx),
>>>> ierr)
>>>> !     call
>>>> MatMatMult(A,Km(stepIdx-1),MAT_INITIAL_MATRIX,PETSC_DEFAULT_INTEGER,Km(stepIdx),
>>>> ierr)
>>>>   end do
>>>> !   call MatView(K,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>> end subroutine mpk_monomial
>>>> Cong Li
>>>> On Thu, Aug 6, 2015 at 3:30 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>    Send the entire code so that we can compile it and run it ourselves
>>>>> to see what is going wrong.
>>>>>   Barry
>>>>> > On Aug 5, 2015, at 4:42 AM, Cong Li <solvercorleone at gmail.com>
>>>>> wrote:
>>>>> > Hi
>>>>> > I tried the method you suggested. However, I got the error message.
>>>>> > My code and message are below.
>>>>> > K is the big matrix containing column matrices.
>>>>> > code:
>>>>> bsize,KArray(KArrayOffset + 1), Km(1), ierr)
>>>>> >   end do
>>>>> local_RCol)
>>>>> >   end do
>>>>> >     call
>>>>> ierr)
>>>>> >   end do
>>>>> > And I got the error message as below:
>>>>> > [0]PETSC ERROR:
>>>>> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>> Violation, probably memory access out of range
>>>>> > [0]PETSC ERROR: Try option -start_in_debugger or
>>>>> -on_error_attach_debugger
>>>>> > [0]PETSC ERROR: or see
>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC
>>>>> ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
>>>>> find memory corruption errors
>>>>> > [0]PETSC ERROR: configure using --with-debugging=yes, recompile,
>>>>> link, and run
>>>>> > [0]PETSC ERROR: to get more information on the crash.
>>>>> > [0]PETSC ERROR: --------------------- Error Message
>>>>> > [0]PETSC ERROR: Signal received!
>>>>> > [0]PETSC ERROR:
>>>>> > [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11
>>>>> 22:15:24 CDT 2013
>>>>> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> > [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>> > [0]PETSC ERROR: --------------------[1]PETSC ERROR:
>>>>> > [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>> > [0]PETSC ERROR: ./kmath.bcbcg on a arch-fuji named p01-024 by a03293
>>>>> Wed Aug  5 18:24:40 2015
>>>>> > [0]PETSC ERROR: Libraries linked from
>>>>> /volume1/home/ra000005/a03293/kmathlibbuild/petsc-3.3-p7/arch-fujitsu-sparc64fx-opt/lib
>>>>> > [0]PETSC ERROR: Configure run at Tue Jul 28 19:23:51 2015
>>>>> > [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768
>>>>> --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0
>>>>> --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8
>>>>> --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8
>>>>> --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8
>>>>> --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=8
>>>>> --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1
>>>>> --known-mpi-c-double-complex=1 --with-cc=mpifccpx --CFLAGS="-mt -Xg"
>>>>> --COPTFLAGS=-Kfast,openmp --with-cxx=mpiFCCpx --CXXFLAGS=-mt
>>>>> --CXXOPTFLAGS=-Kfast,openmp --with-fc=mpifrtpx --FFLAGS=-Kthreadsafe
>>>>> --FOPTFLAGS=-Kfast,openmp --with-blas-lapack-lib="-SCALAPACK -SSL2"
>>>>> --with-x=0 --with-c++-support --with-batch=1 --with-info=1
>>>>> --with-debugging=0 --known-mpi-shared-libraries=0 --with-valgrind=0
>>>>> > [0]PETSC ERROR:
>>>>> > [0]PETSC ERROR: User provided function() line 0 in unknown directory
>>>>> unknown file
>>>>> > [mpi::mpi-api::mpi-abort]
>>>>> > MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>>>> > with errorcode 59.
>>>>> > NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>>> > You may or may not see output from other processes, depending on
>>>>> > exactly when Open MPI kills them.
>>>>> > [p01-024:26516]
>>>>> /opt/FJSVtclang/GM-1.2.0-18/lib64/libmpi.so.0(orte_errmgr_base_error_abort+0x84)
>>>>> [0xffffffff0091f684]
>>>>> > [p01-024:26516]
>>>>> /opt/FJSVtclang/GM-1.2.0-18/lib64/libmpi.so.0(ompi_mpi_abort+0x51c)
>>>>> [0xffffffff006c389c]
>>>>> > [p01-024:26516]
>>>>> /opt/FJSVtclang/GM-1.2.0-18/lib64/libmpi.so.0(MPI_Abort+0x6c)
>>>>> [0xffffffff006db3ac]
>>>>> > [p01-024:26516]
>>>>> /opt/FJSVtclang/GM-1.2.0-18/lib64/libtrtmet_c.so.1(MPI_Abort+0x2c)
>>>>> [0xffffffff00281bf0]
>>>>> > [p01-024:26516] ./kmath.bcbcg [0x1bf620]
>>>>> > [p01-024:26516] ./kmath.bcbcg [0x1bf20c]
>>>>> > [p01-024:26516] /lib64/libc.so.6(killpg+0x48) [0xffffffff02d52600]
>>>>> > [p01-024:26516] [(nil)]
>>>>> > [p01-024:26516] ./kmath.bcbcg [0x1a2054]
>>>>> > [p01-024:26516] ./kmath.bcbcg [0x1064f8]
>>>>> > [p01-024:26516] ./kmath.bcbcg(MAIN__+0x9dc) [0x105d1c]
>>>>> > [p01-024:26516] ./kmath.bcbcg(main+0xec) [0x8a329c]
>>>>> > [p01-024:26516] /lib64/libc.so.6(__libc_start_main+0x194)
>>>>> [0xffffffff02d3b81c]
>>>>> > [p01-024:26516] ./kmath.bcbcg [0x1051ec]
>>>>> > [0]PETSC ERROR:
>>>>> > [0]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or
>>>>> the batch system) has told this process to end
>>>>> link, and run
>>>>> > [0]PETSC ERROR:
>>>>> 22:15:24 CDT 2013
>>>>> > [0]PETSC ERROR:
>>>>> > [0]PETSC ERROR:
>>>>> unknown file
>>>>> > [ERR.] PLE 0019 plexec One of MPI processes was
>>>>> aborted.(rank=0)(nid=0x020a0028)(CODE=1938,793745140674134016,15104)
>>>>> > However, if I change from
>>>>> > call
>>>>> ierr)
>>>>> > to
>>>>> > call MatMatMult(A,Km(stepIdx-1),
>>>>> MAT_INITIAL_MATRIX,PETSC_DEFAULT_INTEGER,Km(stepIdx), ierr)
>>>>> > everything is fine.
>>>>> > could you please suggest some way to solve this?
>>>>> > Thanks
>>>>> > Cong Li
>>>>> > On Wed, Aug 5, 2015 at 10:53 AM, Cong Li <solvercorleone at gmail.com>
>>>>> wrote:
>>>>> > Thank you very much for your help and suggestions.
>>>>> > With your help, finally I could continue my project.
>>>>> > Regards
>>>>> > Cong Li
>>>>> > On Wed, Aug 5, 2015 at 3:09 AM, Barry Smith <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>> >   From the manual page:  Unless scall is MAT_REUSE_MATRIX C will be
>>>>> created.
>>>>> >   Since you want to use the C that is passed in you should use
>>>>> MAT_REUSE_MATRIX.
>>>>> >   Note that since your B and C matrices are dense the issue of
>>>>> sparsity pattern of C is not relevant.
>>>>> >   Barry
>>>>> > > On Aug 4, 2015, at 11:59 AM, Cong Li <solvercorleone at gmail.com>
>>>>> wrote:
>>>>> > > Thanks very much. This answer is very helpful.
>>>>> > > And I have a following question.
>>>>> > > If I create B1, B2, .. by the way you suggested and then use
>>>>> MatMatMult to do SPMM.
>>>>> > > PetscErrorCode  MatMatMult(Mat A,Mat B,MatReuse scall,PetscReal
>>>>> fill,Mat *C)
>>>>> > > should I use  MAT_REUSE_MATRIX for MatReuse part of the arguement.
>>>>> > > Thanks
>>>>> > > Cong Li
>>>>> > > On Wed, Aug 5, 2015 at 1:27 AM, Barry Smith <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>> > > > On Aug 4, 2015, at 4:09 AM, Cong Li <solvercorleone at gmail.com>
>>>>> wrote:
>>>>> > > > I am sorry that I should have explained it more clearly.
>>>>> > > > Actually I want to compute a recurrence.
>>>>> > > > Like, I want to firstly compute A*X1=B1, and then calculate
>>>>> A*B1=B2, A*B2=B3 and so on.
>>>>> > > > Finally I want to combine all these results into a bigger matrix
>>>>> C=[B1,B2 ...]
>>>>> > >    First create C with MatCreateDense(,&C). Then call
>>>>> MatDenseGetArray(C,&array); then create B1 with
>>>>> MatCreateDense(....,array,&B1); then create
>>>>> > > B2 with MatCreateDense(...,array+shift,&B2) etc where shift equals
>>>>> the number of __local__ rows in B1 times the number of columns in B1, then
>>>>> create B3 with a larger shift etc.
>>>>> > >    Note that you are "sharing" the array space of C with B1, B2,
>>>>> B3, ..., each Bi contains its columns of the C matrix.
>>>>> > >   Barry
>>>>> > > > Is there any way to do this efficiently.
>>>>> > > > On Tue, Aug 4, 2015 at 5:45 PM, Patrick Sanan <
>>>>> patrick.sanan at gmail.com> wrote:
>>>>> > > > On Tue, Aug 04, 2015 at 03:42:14PM +0900, Cong Li wrote:
>>>>> > > > > Thanks for your reply.
>>>>> > > > > I have an other question.
>>>>> > > > > I want to do SPMM several times and combine result matrices
>>>>> into one bigger
>>>>> > > > > matrix.
>>>>> > > > > for example
>>>>> > > > > I firstly calculate AX1=B1, AX2=B2 ...
>>>>> > > > > then I want to combine B1, B2.. to get a C, where C=[B1,B2...]
>>>>> > > > > Could you please suggest a way of how to do this.
>>>>> > > > This is just linear algebra, nothing to do with PETSc
>>>>> specifically.
>>>>> > > > A * [X1, X2, ... ] = [AX1, AX2, ...]
>>>>> > > > > Thanks
>>>>> > > > > Cong Li
>>>>> > > > > On Tue, Aug 4, 2015 at 3:27 PM, Jed Brown <jed at jedbrown.org>
>>>>> wrote:
>>>>> > > > > > Cong Li <solvercorleone at gmail.com> writes:
>>>>> > > > > > > Hello,
>>>>> > > > > > > I am a PhD student using PETsc for my research.
>>>>> > > > > > > I am wondering if there is a way to implement SPMM (Sparse
>>>>> matrix-matrix
>>>>> > > > > > > multiplication) by using PETSc.
>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatMatMult.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150807/525db1f1/attachment-0001.html>
