[petsc-users] Remove Jacobian matrix values less than tolerance
Thu Aug 6 16:22:36 CDT 2015
On Thu, Aug 6, 2015 at 4:16 PM, Juris Vencels <juris.vencels at gmail.com>
wrote:
> Hi Users,
> When I construct analytical Jacobian matrix it has many small values of
> order 1E-16.
> How can I remove these values that are less than a given tolerance, let's
> say 1E-10?
> I tried to use MatChop together with MatCopy and MatDuplicate, but none of
> these functions ignores zeros.
Do you mean that you want to change the sparsity pattern? We do not have a
function which does this. It would
require a copy to regain the lost memory, and its not normally worth the
trouble.
Do you have some data or a model that tells you its worth it in your case?
This is a question I
always ask myself before programming.
     Matt
> Thanks!
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150806/e56a81e6/attachment.html>
