[petsc-users] mumps compile error
George Pau gpau at lbl.gov
Wed Aug 5 15:44:37 CDT 2015
Hi Barry,
Thanks.  That is indeed the reason.  Once I deleted the old directory,
everything is configured correctly.
George
On Wed, Aug 5, 2015 at 12:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    George,
>    Try running with a completely empty directory for the --prefix (perhaps
> it is picking up some incorrect/outdated stuff there).
>     Also send us the configure.log file from running without a prefix (so
> we can see what the differences are).
>    I ran a --prefix configure build with MUMPS just now and it was fine.
>   Barry
> > On Aug 5, 2015, at 1:35 PM, George Pau <gpau at lbl.gov> wrote:
> > Hi,
> > I am now having issues with mumps.  Similar to my  configure options in
> my previous email:
> > --with-debugging=1 --with-shared-libraries=0
> --prefix=/global/homes/g/gpau/clm-rom/install/t
> > pls --with-cxx-dialect=C++11 --download-elemental --download-mumps
> --download-scalapack --do
> > wnload-parmetis --download-metis --download-hdf5 --download-netcdf
> --with-x=0 --with-cc=/opt
> > /cray/craype/2.3.1/bin/cc --with-cxx=/opt/cray/craype/2.3.1/bin/CC
> --with-fc=/opt/cray/crayp
> > e/2.3.1/bin/ftn
> > I am having now having problem with mumps but I couldn't figure out what
> is wrong.  I have this problem on both NERSC/Edison (using Intel compiler)
> and on Ubuntu (using gcc compiler):
> > mumps_c.c(136): error: identifier "MUMPS_INT8" is undefined
> >              MUMPS_INT8     *keep8,
> > mumps_c.c(284): error: identifier "MUMPS_INT8" is undefined
> >       MUMPS_INT8 *keep8;
> > mumps_c.c(284): error: identifier "keep8" is undefined
> >       MUMPS_INT8 *keep8;
> > The error messages are longer and can be found in the attached log file.
> > However, if I leave out the --prefix  option, then everything is fine.
> MUMPS will configure correctly. It seems like a linking issue.
> > George Pau
> > Earth Sciences Division
> > Lawrence Berkeley National Laboratory
> > One Cyclotron, MS 74-120
> > Berkeley, CA 94720
> > (510) 486-7196
> > gpau at lbl.gov
> > http://esd.lbl.gov/about/staff/georgepau/
> > <configure.log>
George Pau
Berkeley, CA 94720
(510) 486-7196
gpau at lbl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150805/9b6756f4/attachment.html>
