[petsc-users] problem with MatShellGetContext
Nicolas Pozin nicolas.pozin at inria.fr
Wed Aug 5 04:15:16 CDT 2015
Hello,
I'm trying to solve a system with a matrix free operator and through conjugate gradient method.
To make ideas clear, I set up the following simple example (I am using petsc-3.6) and I get this error message :
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Invalid argument!
[0]PETSC ERROR: Wrong type of object: Parameter # 1!
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./test on a ubuntu_release named pl-59080 by npozin Wed Aug 5 10:55:26 2015
[0]PETSC ERROR: Libraries linked from /home/npozin/Felisce_libraries/petsc_3.4.3/ubuntu_release/lib
[0]PETSC ERROR: Configure run at Wed Jul 22 16:18:36 2015
[0]PETSC ERROR: Configure options PETSC_ARCH=ubuntu_release --with-cxx=g++ --with-fc=gfortran --with-cc=gcc --with-x=0 --download-openmpi --download-f-blas-lapack --download-superlu --download-superlu_dist --with-superlu_dist=1 --download-metis --download-mumps --download-parmetis --with-superlu_dist=1 --download-boost --with-boost=1 --download-scalapack with-external-packages-dir=/home/npozin/Felisce_libraries/petsc_3.4.3/packages
[0]PETSC ERROR: MatShellGetContext() line 202 in /home/npozin/Felisce_libraries/petsc_3.4.3/src/mat/impls/shell/shell.c
End userMult
[0]PETSC ERROR: MatMult() line 2179 in /home/npozin/Felisce_libraries/petsc_3.4.3/src/mat/interface/matrix.c
[0]PETSC ERROR: KSP_MatMult() line 204 in /home/npozin/Felisce_libraries/petsc_3.4.3/include/petsc-private/kspimpl.h
[0]PETSC ERROR: KSPSolve_CG() line 219 in /home/npozin/Felisce_libraries/petsc_3.4.3/src/ksp/ksp/impls/cg/cg.c
[0]PETSC ERROR: KSPSolve() line 441 in /home/npozin/Felisce_libraries/petsc_3.4.3/src/ksp/ksp/interface/itfunc.c
I don't understand where the problem comes from with the matrix argument of MatShellGetContext.
Any idea on what I do wrong?
Thanks a lot,
Nicolas
#include <iostream>
#include <petscksp.h>
using namespace std;
typedef struct {
int val;
} MyCtx;
class ShellClass {
Mat matShell;
KSP ksp;
PC pc;
Vec x;
Vec b;
public:
void userMult(Mat Amat, Vec x, Vec y) {
cout << "Inside userMult" << endl;
MyCtx *ctx;
MatShellGetContext(Amat, (void *) ctx);
cout << "End userMult" << endl;
void solveShell() {
// context
MyCtx *ctx = new MyCtx;
ctx->val = 42;
// pc
PCCreate(PETSC_COMM_WORLD, &pc);
PCSetType(pc, PCNONE);
// ksp
KSPCreate(PETSC_COMM_WORLD, &ksp);
KSPSetType(ksp, KSPCG);
KSPSetPC(ksp, pc);
KSPSetFromOptions(ksp);
// matshell
int m = 10;
int n = 10;
MatCreateShell(PETSC_COMM_WORLD, m, n, PETSC_DETERMINE, PETSC_DETERMINE, ctx, &matShell);
MatShellSetOperation(matShell, MATOP_MULT, (void(*)(void))&ShellClass::userMult);
// create vectors
MatCreateVecs(matShell, &x, 0);
VecDuplicate(x, &b);
VecSet(b, 1.);
// set operators
KSPSetOperators(ksp, matShell, matShell);
// solve (call to userMult)
KSPSolve(ksp, b, x);
int main(int argc, char** argv) {
PetscInitialize(&argc, &argv, NULL, NULL);
ShellClass foo;
foo.solveShell();
PetscFinalize();
return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150805/11680491/attachment.html>
Type: text/x-makefile
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150805/11680491/attachment.bin>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150805/11680491/attachment.cpp>
