[petsc-users] C++ wrapper for petsc vector
Tue Aug 4 12:24:14 CDT 2015
On Tue, Aug 4, 2015 at 12:15 PM, Martin Vymazal <martin.vymazal at vki.ac.be>
wrote:
> Hello,
>  I'm trying to create a small C++ class to wrap the 'Vec' object. This
> class
> has an internal pointer to a member variable of type Vec, and in its
> destructor, it calls VecDestroy. Unfortunately, my test program segfaults
> and
> this seems to be due to the fact that the destructor of the wrapper class
> is
> called after main() calls PetscFinalize(). Apparently VecDestroy performs
> some
> collective communication, so calling it after PetscFinalize() is too late.
> How
> can I fix this?
1) Declare your C++ in a scope, so that it goes out of scope before
PetscFinalize()
2) Is there any utility to this wrapper since everything can be called
directly from C++?
     Matt
> Thank you,
>  Martin Vymazal
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150804/463bad30/attachment.html>
