[petsc-users] I am wondering if there is a way to implement SPMM
Patrick Sanan patrick.sanan at gmail.com
Tue Aug 4 03:45:48 CDT 2015
On Tue, Aug 04, 2015 at 03:42:14PM +0900, Cong Li wrote:
> Thanks for your reply.
> I have an other question.
> I want to do SPMM several times and combine result matrices into one bigger
> matrix.
> for example
> I firstly calculate AX1=B1, AX2=B2 ...
> then I want to combine B1, B2.. to get a C, where C=[B1,B2...]
> Could you please suggest a way of how to do this.
This is just linear algebra, nothing to do with PETSc specifically.
A * [X1, X2, ... ] = [AX1, AX2, ...]
> Thanks
> Cong Li
> On Tue, Aug 4, 2015 at 3:27 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Cong Li <solvercorleone at gmail.com> writes:
> > > Hello,
> > > I am a PhD student using PETsc for my research.
> > > I am wondering if there is a way to implement SPMM (Sparse matrix-matrix
> > > multiplication) by using PETSc.
> > http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatMatMult.html
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150804/9aa5ff42/attachment.pgp>
