[petsc-users] failed to compile HDF5 on vesta
Fande Kong fdkong.jd at gmail.com
Sat Aug 1 19:55:08 CDT 2015
HI barry,
Thanks a lot. I could compile hdf5, but failed to compile fblaslapack. Log
file is attached.
Fande Kong,
On Sat, Aug 1, 2015 at 3:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Try with  --with-shared-libraries=0  The HDF5 build is having some issue
> with shared libraries
>   Barry
> > On Aug 1, 2015, at 4:01 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> > Hi all,
> > I want to install petsc on vesta (an IBM Blue Gene at Argonne). Failed
> to compile HDF5. The configure log file is attached. Any suggestions would
> be greatly appreciated.
> > Thanks,
> > Fande Kong,
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150801/0e6b7560/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150801/0e6b7560/attachment-0001.obj>
