[petsc-users] Tao iterations
Justin Chang jchang27 at uh.edu
Wed Apr 29 17:53:27 CDT 2015
Okay that's what I figured, thanks you very much
On Wed, Apr 29, 2015 at 10:39 AM, Jason Sarich <jason.sarich at gmail.com>
wrote:
> Hi Justin,
> This expected behavior due to the accumulation of numerical round-offs. If
> this is a problem or if you just want to confirm that this is the cause,
> you can try configuring PETSc for quad precision
> (--with-precision=__float128, works with GNU compilers) and the results
> should match better.
> Jason
> On Tue, Apr 28, 2015 at 10:19 PM, Justin Chang <jchang27 at uh.edu> wrote:
>>   Jason (or anyone),
>>  I am noticing that the iteration numbers reported by
>> TaoGetSolutionStatus() for blmvm differ whenever I change the number of
>> processes. The solution seems to remain the same though. Is there a reason
>> why this could be happening?
>>  Thanks,
>> On Tue, Apr 21, 2015 at 10:40 AM, Jason Sarich <jason.sarich at gmail.com>
>> wrote:
>>> Justin,
>>>  1) The big difference between TRON and BLMVM is that TRON requires
>>> hessian information, BLMVM only uses gradient information. Thus TRON will
>>> usually converge faster, but requires more information, memory, and a KSP
>>> solver. GPCG (gradient projected conjugate gradient) is another
>>> gradient-only option, but usually performs worse than BLMVM.
>>>  2) TaoGetLinearSolveIterations() will get the total number of KSP
>>> iterations per solve
>>>  Jason
>>> On Tue, Apr 21, 2015 at 10:33 AM, Justin Chang <jychang48 at gmail.com>
>>> wrote:
>>>>    Jason,
>>>>  Tightening the tolerances did the trick. Thanks. Though I do have a
>>>> couple more related questions:
>>>>  1) Is there a general guideline for choosing tron over blmvm or vice
>>>> versa? Also is there another tao type that is also suitable given only
>>>> bounded constraints?
>>>>  2) Is it possible to obtain the total number of KSP and/or PG
>>>> iterations from tron?
>>>>  Thanks,
>>>>  Justin
>>>> On Tue, Apr 21, 2015 at 9:52 AM, Jason Sarich <jason.sarich at gmail.com>
>>>> wrote:
>>>>>  Hi Justin,
>>>>>  blmvm believes that it is already sufficiently close to a minimum, so
>>>>> it doesn't do anything. You may need to tighten some of the tolerance to
>>>>> force an iteration.
>>>>>  Jason
>>>>>  On Tue, Apr 21, 2015 at 9:48 AM, Justin Chang <jychang48 at gmail.com>
>>>>> wrote:
>>>>>>    Time step 1:
>>>>>> Tao Object: 1 MPI processes
>>>>>>   type: blmvm
>>>>>>       Gradient steps: 0
>>>>>>   TaoLineSearch Object:   1 MPI processes
>>>>>>     type: more-thuente
>>>>>>   Active Set subset type: subvec
>>>>>>   convergence tolerances: fatol=0.0001,   frtol=0.0001
>>>>>>   convergence tolerances: gatol=0,   steptol=0,   gttol=0
>>>>>>   Residual in Function/Gradient:=0.0663148
>>>>>>   Objective value=-55.5945
>>>>>>   total number of iterations=35,                          (max: 2000)
>>>>>>   total number of function/gradient evaluations=37,      (max: 4000)
>>>>>>   Solution converged:   estimated |f(x)-f(X*)|/|f(X*)| <= frtol
>>>>>>  Time step 2:
>>>>>>   type: blmvm
>>>>>>       Gradient steps: 0
>>>>>>     type: more-thuente
>>>>>>   Residual in Function/Gradient:=0.0682307
>>>>>>   Objective value=-66.9675
>>>>>>   total number of iterations=23,                          (max: 2000)
>>>>>>   total number of function/gradient evaluations=25,      (max: 4000)
>>>>>> Time step 3:
>>>>>>   type: blmvm
>>>>>>       Gradient steps: 0
>>>>>>     type: more-thuente
>>>>>>   Residual in Function/Gradient:=0.0680522
>>>>>>   Objective value=-71.8211
>>>>>>   total number of iterations=19,                          (max: 2000)
>>>>>>   total number of function/gradient evaluations=22,      (max: 4000)
>>>>>> Time step 4:
>>>>>>   type: blmvm
>>>>>>       Gradient steps: 0
>>>>>>     type: more-thuente
>>>>>>   Residual in Function/Gradient:=0.0551556
>>>>>>   Objective value=-75.1252
>>>>>>   total number of iterations=18,                          (max: 2000)
>>>>>>   total number of function/gradient evaluations=20,      (max: 4000)
>>>>>> Time step 5:
>>>>>>   type: blmvm
>>>>>>       Gradient steps: 0
>>>>>>     type: more-thuente
>>>>>>   Residual in Function/Gradient:=0.0675667
>>>>>>   Objective value=-77.4414
>>>>>>   total number of iterations=6,                          (max: 2000)
>>>>>>   total number of function/gradient evaluations=8,      (max: 4000)
>>>>>> Time step 6:
>>>>>>   type: blmvm
>>>>>>       Gradient steps: 0
>>>>>>     type: more-thuente
>>>>>>   Residual in Function/Gradient:=0.059143
>>>>>>   Objective value=-79.5007
>>>>>>   total number of iterations=3,                          (max: 2000)
>>>>>>   total number of function/gradient evaluations=5,      (max: 4000)
>>>>>> Time step 7:
>>>>>>   type: blmvm
>>>>>>       Gradient steps: 0
>>>>>>     type: more-thuente
>>>>>>   Residual in Function/Gradient:=0.0433683
>>>>>>   Objective value=-81.3546
>>>>>>   total number of iterations=5,                          (max: 2000)
>>>>>> Time step 8:
>>>>>>   type: blmvm
>>>>>>       Gradient steps: 0
>>>>>>     type: more-thuente
>>>>>>   Residual in Function/Gradient:=0.0840676
>>>>>>   Objective value=-82.9382
>>>>>>   total number of iterations=0,                          (max: 2000)
>>>>>>   total number of function/gradient evaluations=1,      (max: 4000)
>>>>>> Time step 9:
>>>>>>   type: blmvm
>>>>>>       Gradient steps: 0
>>>>>>     type: more-thuente
>>>>>> Time step 10:
>>>>>>   type: blmvm
>>>>>>       Gradient steps: 0
>>>>>>     type: more-thuente
>>>>>> On Tue, Apr 21, 2015 at 9:28 AM, Jason Sarich <jason.sarich at gmail.com
>>>>>> > wrote:
>>>>>>> Hi Justin,
>>>>>>>  what reason is blmvm giving for stopping the solve? (you can use
>>>>>>> -tao_view or -tao_converged_reason to get this)
>>>>>>>  Jason
>>>>>>> On Mon, Apr 20, 2015 at 6:32 PM, Justin Chang <jychang48 at gmail.com>
>>>>>>> wrote:
>>>>>>>>   Jason,
>>>>>>>>  I am using TaoGetSolutionStatus(tao,&its, ...) and it gives me
>>>>>>>> exactly what I want. However, I seem to be having an issue with blmvm
>>>>>>>>  I wrote my own backward euler code for a transient linear
>>>>>>>> diffusion problem with lower bounds >= 0 and upper bounds <= 1. For the
>>>>>>>> first several time steps I am getting its > 0, and it decreases over time
>>>>>>>> due to the nature of the discrete maximum principles. However, at some
>>>>>>>> point my its become 0 and the solution does not "update", which seems to me
>>>>>>>> that TaoSolve is not doing anything after that. This doesn't happen if I
>>>>>>>> were to use tron (my KSP and PC are cg and jacobi respectively).
>>>>>>>>  Do you know why this behavior may occur?
>>>>>>>>  Thanks,
>>>>>>>> On Tue, Apr 14, 2015 at 9:35 AM, Jason Sarich <
>>>>>>>> jason.sarich at gmail.com> wrote:
>>>>>>>>> Hi Justin,
>>>>>>>>>  I have pushed these changes to the "next" branch, your code
>>>>>>>>> snippet should work fine there.
>>>>>>>>>  Note that there is also available (since version 3.5.0) the
>>>>>>>>> routine TaoGetSolutionStatus(tao,&its,NULL,NULL,NULL,NULL,NULL) which will
>>>>>>>>> provide the
>>>>>>>>> same information
>>>>>>>>>  Jason
>>>>>>>>> On Fri, Apr 10, 2015 at 6:28 PM, Justin Chang <jychang48 at gmail.com
>>>>>>>>> > wrote:
>>>>>>>>>>   Whatever is convenient and/or follow the "PETSc" standards.
>>>>>>>>>> Something similar to SNESGetIterationNumber() or KSPGetIterationNumber()
>>>>>>>>>> would be nice. Ideally I want my code to look like this:
>>>>>>>>>>  ierr = TaoGetIterationNumber(tao,&its);CHKERRQ(ierr);
>>>>>>>>>>  ierr = PetscPrintf(PETSC_COMM_WORLD, "Number of Tao iterations =
>>>>>>>>>> %D\n", its);
>>>>>>>>>>  Thanks :)
>>>>>>>>>> On Fri, Apr 10, 2015 at 5:53 PM, Jason Sarich <
>>>>>>>>>>> Hi Justin, I'll get this in. I assume that displaying the number
>>>>>>>>>>> of iterations with tao_converged_reason is what you are asking for in
>>>>>>>>>>> particular? Or did you have something else in mind?
>>>>>>>>>>> Jason
>>>>>>>>>>>  On Apr 10, 2015 16:42, "Smith, Barry F." <bsmith at mcs.anl.gov>
>>>>>>>>>>> wrote:
>>>>>>>>>>>>   Justin,
>>>>>>>>>>>>     Sorry TAO simply doesn't even collect this information
>>>>>>>>>>>> currently. But yes we should definitely make it available!
>>>>>>>>>>>>   Jason,
>>>>>>>>>>>>      Could you please add this; almost all the TaoSolve_xxx()
>>>>>>>>>>>> have a local variable iter; change that to tao->niter (I'm guess this is
>>>>>>>>>>>> suppose to capture this information) and add a TaoGetIterationNumber() and
>>>>>>>>>>>> the uses can access this. Also modify at the end of TaoSolve()
>>>>>>>>>>>> -tao_converged_reason to also print the iteration count. At the same time
>>>>>>>>>>>> since you add this you can add a tao->totalits which would accumulate all
>>>>>>>>>>>> iterations over all the solves for that Tao object and the routine
>>>>>>>>>>>> TaoGetTotalIterations() to access this.  Note that TaoSolve() would
>>>>>>>>>>>> initialize tao->niter = 0 at the top.
>>>>>>>>>>>>    Thanks
>>>>>>>>>>>>   Barry
>>>>>>>>>>>> > On Apr 10, 2015, at 4:16 PM, Justin Chang <jchang27 at uh.edu>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>  > Hi all,
>>>>>>>>>>>> > Is there a way to generically obtain the number of Tao
>>>>>>>>>>>> iterations? I am looking through the -help options for Tao and I don't see
>>>>>>>>>>>> any metric where you can output this quantity in the manner that you could
>>>>>>>>>>>> for SNES or KSP solves. I am currently using blmvm and tron, and the only
>>>>>>>>>>>> way I can see getting this metric is by outputting -tao_view and/or
>>>>>>>>>>>> -tao_monitor and manually finding this number. I find this cumbersome
>>>>>>>>>>>> especially for transient problems where I would like to simply have this
>>>>>>>>>>>> number printed for each step instead of ending up with unnecessary info.
>>>>>>>>>>>> > Thanks,
>>>>>>>>>>>> > Justin Chang
>>>>>>>>>>>> > PhD Candidate, Civil Engineering - Computational Sciences
>>>>>>>>>>>> > University of Houston, Department of Civil and Environmental
>>>>>>>>>>>> Engineering
>>>>>>>>>>>> > Houston, TX 77004
>>>>>>>>>>>> > (512) 963-3262
>>   Justin Chang
>>  University of Houston, Department of Civil and Environmental Engineering
>>  Houston, TX 77004
>> (512) 963-3262
Justin Chang
Houston, TX 77004
(512) 963-3262
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150429/3d81b75c/attachment-0001.html>
