[petsc-users] Turning off TSADAPT still adapts time step
Jed Brown jed at jedbrown.org
Tue Apr 28 13:31:00 CDT 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
>>>   Perhaps if every rejected line indicated why such as
>>> TSAdapt 'none': step  20 stage rejected (nonlinear solve failed due to xxxx)  t=800        + 4.000e+01 retrying with dt=1.000e+01
>>> or
>>> TSAdapt 'something': step  20 stage rejected (error control to large due to xxxx)  t=800        + 4.000e+01 retrying with dt=1.000e+01
*Stages* are not rejected due to local truncation error because the
error estimate only occurs at step completion.  Stages are rejected
because the solve fails or the user's checkstage function rejects it.
When a *step* is rejected due to an error estimate, the output currently
reads:
  TSAdapt 'basic': step  25 rejected t=0.00175892 + 5.270e-05 wlte= 4.92 family='arkimex' scheme=0:'4' dt=3.185e-05
You can see that wlte (weighted local truncation error) is greater than
1.
>> I'm concerned about these lines being too long and practically
>> unreadable.
>    It is silly to have something like it is now that is clearly
>    confusing to users when adding 3 or 4 words to the output would
>    remove that confusion.
What exactly would you want it to say?  You want it to dig into SNES and
KSP to do a postmortem analysis of why the solver failed, and print all
of that in a summary?  We don't do that in SNES; we just say
SNES_DIVERGED_LINEAR_SOLVE and the user can add -ksp_converged_reason to
find out why.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150428/a24c4e0c/attachment.pgp>
