[petsc-users] Turning off TSADAPT still adapts time step
Jed Brown jed at jedbrown.org
Mon Apr 27 12:24:34 CDT 2015
Mark Lohry <mlohry at princeton.edu> writes:
> -snes_converged_reason:
> Nonlinear solve did not converge due to DIVERGED_LOCAL_MIN iterations 4
> (which is expected)
If you set -snes_stol $something_large then SNES will exit
SNES_CONVERGED_SNORM_RELATIVE instead of SNES_DIVERGED_LINE_SEARCH when
it stagnates.
>> Add -snes_converged_reason.  What do you want to do when the solver
>> fails?  Pretend like it succeeded and get the wrong answer?  Usually
>> people shorten the time step and retry, which is what you see happening
>> here.
> Well yes, actually - I expected it to fail for this test case but it
> stubbornly gets the right answer.
Sorry about that.  ;-)
> The explicit integrator has no problem keeping a fixed timestep and
> throwing the expected NaNs when it blows up.
> It's alarming to see the unexpected behavior of setting TSADAPTNONE and
> seeing it actually adapting (in a rudimentary fashion) the timestep, and
> keeping that reduced timestep even after the stiffness goes away.
We figured it's not very useful to just crash or get the wrong answer,
so the solver-based control is decoupled from error-based control.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150427/7056e74b/attachment.pgp>
