[petsc-users] Turning off TSADAPT still adapts time step
Jed Brown jed at jedbrown.org
Mon Apr 27 10:58:35 CDT 2015
Mark Lohry <mlohry at princeton.edu> writes:
> The TSAdaptSetType is being called. Looking at TSStep_Theta, is it
> possible that here:
> /* Register only the current method as a candidate because we're not
> supporting multiple candidates yet. */
>      ierr = TSGetAdapt(ts,&adapt);CHKERRQ(ierr);
>      ierr = TSAdaptCandidatesClear(adapt);CHKERRQ(ierr);
>      ierr =
> TSAdaptCandidateAdd(adapt,NULL,th->order,1,th->ccfl,1.0,PETSC_TRUE);CHKERRQ(ierr);
>      ierr =
> TSAdaptChoose(adapt,ts,ts->time_step,&next_scheme,&next_time_step,&accept);CHKERRQ(ierr);
> TSAdaptCandidatesClear is unsetting whatever method I'm setting?
No.  It does not affect the implementation, it just clears the candidate
list that the implementation may choose from.
PetscErrorCode TSAdaptCandidatesClear(TSAdapt adapt)
  PetscErrorCode ierr;
  PetscFunctionBegin;
  PetscValidHeaderSpecific(adapt,TSADAPT_CLASSID,1);
  ierr = PetscMemzero(&adapt->candidates,sizeof(adapt->candidates));CHKERRQ(ierr);
  PetscFunctionReturn(0);
When you set -ts_adapt_type none, the function below should be called.
Verify that in a debugger.  Also, always run with -ts_adapt_monitor when
trying to debug something like this.
static PetscErrorCode TSAdaptChoose_None(TSAdapt adapt,TS ts,PetscReal h,PetscInt *next_sc,PetscReal *next_h,PetscBool *accept,PetscReal *wlte)
  PetscFunctionBegin;
  *accept  = PETSC_TRUE;
  *next_sc = 0;                 /* Reuse the same order scheme */
  *next_h  = h;                 /* Reuse the old step */
  *wlte    = -1;                /* Weighted local truncation error was not evaluated */
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150427/10cc8f3d/attachment.pgp>
