[petsc-users] cached values
Jed Brown jed at jedbrown.org
Sun Apr 26 19:13:04 CDT 2015
Justin Chang <jychang48 at gmail.com> writes:
> Jed,
> Thank you for the response. But where exactly are the values from
> MatSetValues() stored or located? That is, are they in main memory, or are
> they occupying space in the L1/L2/L3 cache?
Caches are not programmable in that way.  PETSc incrementally allocates
a data structure that holds the "stashed" values.  It depends on the
details of your application and the hardware cache semantics whether a
particular access will trigger a cache miss or not.  You can find out
using hardware performance counters, but it's not likely to be worth
your time unless you just want to learn those tools.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150426/c95dcbcc/attachment.pgp>
