[petsc-users] cached values
Jed Brown jed at jedbrown.org
Sun Apr 26 18:54:39 CDT 2015
Justin Chang <jychang48 at gmail.com> writes:
> Hello everyone,
> Pardon me if this might be a PETSc 101 question, but what exactly is meant
> when routines like MatSetValues() "caches the values"? Specifically, what
> happens say, after I iterate through each element within the
> ComputeJacobian() routine, when I call MatAssemblyBegin/End(). If there's
> documentation or a paper somewhere that explains this that would be very
> helpful, because I can't seem to find anything in the PETSc manual
> describing this process in detail.
The exact protocol probably isn't interesting unless you're trying to
develop something similar, in which case you can read the source code.
The basic idea is that there is a rendezvous so that each process can
determine from which other processes it will need to receive values,
followed by actually sending/receiving those values.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150426/1609ead0/attachment.pgp>
