[petsc-users] DMPlexProjectField not including BC constraints?
Fri Apr 24 08:09:08 CDT 2015
On Thu, Apr 23, 2015 at 10:20 PM, Justin Chang <jchang27 at uh.edu> wrote:
> Matt,
> I have attempted this but I am getting an error when trying to output the
> vector into HDF5. This is my implementation:
> /* Initialize */
> PetscDS prob;
> Vec vlocal, ulocal, vglobal;
> void (*vX[1])(....) = {velx};
> /* Create DM for velocity */
> ierr = DMClone(dm,&user.dmVel);CHKERRQ(ierr);
> ierr = DMPlexCopyCoordinates(dm, user.dmVel);CHKERRQ(ierr);
> ierr = PetscFECreateDefault(dm, spatialDim, 1, PETSC_TRUE, "solution_",
> -1, &user.feVel);CHKERRQ(ierr);
> ierr = DMGetDS(user.dmVel, &prob);CHKERRQ(ierr);
> ierr = PetscDSSetDiscretization(prob, 0, (PetscObject)
> ierr = DMCreateGlobalVector(user.dmVel,&vglobal);CHKERRQ(ierr);
> ierr = PetscObjectSetName((PetscObject) vglobal, "velocity");CHKERRQ(ierr);
> /* Obtain velocity */
> ierr = DMGetLocalVector(dm,&ulocal);CHKERRQ(ierr);
> ierr = VecDuplicate(ulocal,&vlocal);CHKERRQ(ierr);
> ierr =
> DMGlobalToLocalBegin(dm,user.u,INSERT_ALL_VALUES,ulocal);CHKERRQ(ierr);
> ierr =
> DMGlobalToLocalEnd(dm,user.u,INSERT_ALL_VALUES,ulocal);CHKERRQ(ierr);
> ierr =
> DMPlexProjectFieldLocal(dm,ulocal,vX,INSERT_ALL_VALUES,vlocal);CHKERRQ(ierr);
> ierr =
> DMLocalToGlobalBegin(dm,vlocal,INSERT_ALL_VALUES,vglobal);CHKERRQ(ierr);
> ierr =
> DMLocalToGlobalEnd(dm,vlocal,INSERT_ALL_VALUES,vglobal);CHKERRQ(ierr);
1) Shouldn't that be user.dmVel above, not dm?
2) Are you changing from vector to scalar here? I think so, and so you
would need an extra step
     since that projection assumes that the layout is the same as the input.
I do not currently have anything that maps between different layouts like
you want. It will have to
be written. THEN we can use the above code.
    Matt
> ierr = VecViewFromOptions(vglobal,NULL,"-vec_view_x");CHKERRQ(ierr);
> And as soon as I get to the last line, it gives me this error:
> [0]PETSC ERROR: PetscMallocValidate: error detected at
> PetscViewerFileSetName_HDF5() line 251 in
> /home/justin/petsc-dev/src/sys/classes/viewer/impls/hdf5/hdf5v.c
> [0]PETSC ERROR: Memory at address 0x3077ac0 is corrupted
> [0]PETSC ERROR: Probably write past beginning or end of array
> [0]PETSC ERROR: Last intact block allocated in VecCreate_Seq() line 38 in
> /home/justin/petsc-dev/src/vec/vec/impls/seq/bvec3.c
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Memory corruption:
> http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
> [0]PETSC ERROR:
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2766-g0d12e5d  GIT
> Date: 2015-04-21 21:32:23 -0500
> [0]PETSC ERROR: ./main on a arch-linux2-c-debug named pacotaco by justin
> Thu Apr 23 22:14:21 2015
> [0]PETSC ERROR: Configure options --download-chaco --download-exodusii
> --download-fblaslapack --download-hdf5 --download-metis --download-mpich
> --download-mumps --download-netcdf --download-parmetis --download-scalapack
> --download-tetgen --download-triangle --with-cc=gcc --with-clanguage=cxx
> --with-cmake=cmake --with-ctetgen --with-cxx=g++ --with-debugging=1
> --with-fc=gfortran --with-valgrind=1 PETSC_ARCH=arch-linux2-c-debug
> [0]PETSC ERROR: #1 PetscMallocValidate() line 135 in
> /home/justin/petsc-dev/src/sys/memory/mtr.c
> [0]PETSC ERROR: #2 PetscViewerFileSetName_HDF5() line 251 in
> [0]PETSC ERROR: #3 PetscViewerFileSetName() line 623 in
> /home/justin/petsc-dev/src/sys/classes/viewer/impls/ascii/filev.c
> [0]PETSC ERROR: #4 PetscOptionsGetViewer() line 130 in
> /home/justin/petsc-dev/src/sys/classes/viewer/interface/viewreg.c
> [0]PETSC ERROR: #5 PetscObjectViewFromOptions() line 2622 in
> /home/justin/petsc-dev/src/sys/objects/options.c
> [0]PETSC ERROR: #6 main() line 1237 in
> /home/justin/Dropbox/dmplex-nonneg/main.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -al 100
> [0]PETSC ERROR: -at 0.01
> [0]PETSC ERROR: -bcloc
> 496000,496000,536000,542000,0,100,503000,503000,536000,542000,0,100,496000,503000,536000,536000,0,100,496000,503000,542000,542000,0,100
> [0]PETSC ERROR: -bcnum 4
> [0]PETSC ERROR: -bcval 1,1,1,1
> [0]PETSC ERROR: -dim 3
> [0]PETSC ERROR: -dm_refine 0
> [0]PETSC ERROR: -dt 0.01
> [0]PETSC ERROR: -edges 3,3,3
> [0]PETSC ERROR: -floc 499550,499600,538950,539000,0,100
> [0]PETSC ERROR: -flow datafiles/chrom_flow.dat
> [0]PETSC ERROR: -fnum 1
> [0]PETSC ERROR: -ftime 0,99
> [0]PETSC ERROR: -fval -0.1
> [0]PETSC ERROR: -ksp_rtol 1.0e-9
> [0]PETSC ERROR: -ksp_type cg
> [0]PETSC ERROR: -lower 0,0,0
> [0]PETSC ERROR: -mat_petscspace_order 0
> [0]PETSC ERROR: -mesh datafiles/chrom_mesh.dat
> [0]PETSC ERROR: -mu 3.95e-5
> [0]PETSC ERROR: -nonneg 0
> [0]PETSC ERROR: -numsteps 0
> [0]PETSC ERROR: -options_left 0
> [0]PETSC ERROR: -pc_type jacobi
> [0]PETSC ERROR: -progress 1
> [0]PETSC ERROR: -solution_petscspace_order 1
> [0]PETSC ERROR: -tao_type tron
> [0]PETSC ERROR: -upper 1,1,1
> [0]PETSC ERROR: -vec_view_x hdf5:solx.h5
> [0]PETSC ERROR: -vec_view_y hdf5:soly.h5
> [0]PETSC ERROR: -vec_view_z hdf5:solz.h5
> [0]PETSC ERROR: -vtuname pressure
> [0]PETSC ERROR: -vtuprintat 1,20,80,160,320,640,999
> [0]PETSC ERROR: -vtusteps 7
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> Any idea what's going on here? Also, if I replace the last line with
> VecView(vglobal,PETSC_VIEWER_STDOUT_WORLD) I get a completely wacko error:
> Vec Object:@�� ��r?������b? � jүr?�.
> ~E�b?�\2p}^r?���"�.b?'xDs��q?�|n��a?`K� Lwq?�n��a?�Ψ���p?�g◻u`?!�
> p?;� :2_?��� �5n?�6/w $]?��I!}�k?! c /�Z?�s# li?�=Y�� X?I%
> �[�f?^�u=��T?�Sx��Yc?�F �u�Q?6
>                                        e��_?;6��a3L? z_�R X?��
> �l�D?X�(�(�P?= �/k�9?;z� I B?
> R�ٕp$?� j�-� ?��7��- ��H>�h�:�� ��6 5�{��2@�L��]P�I#B�<U��U�O�fV`oI�7trdj�\��\��w0P��)e���a�Kf�s�uS�K���z
> e���� �V� ΏY�g� �3�2WY��Xëj�)�&M�[�s�!Q&+m��*�l�V^�Ӈй�uo�� ڄD`�z 1 MPI
> processes
>   type: seq
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> PetscSignalHandlerDefault() line 149 in
> /home/justin/petsc-dev/src/sys/error/signal.c
> [0]PETSC ERROR: Memory at address 0x2575ac0 is corrupted
> [0]PETSC ERROR:
> Thu Apr 23 22:17:26 2015
> [0]PETSC ERROR: #2 PetscSignalHandlerDefault() line 149 in
> However, if I run the program with debugging off (i.e.,
> --with-debugging=0), VecView gives me an answer that seems relatively
> correct.
> Thanks,
> On Thu, Apr 23, 2015 at 4:00 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Apr 22, 2015 at 9:57 PM, Justin Chang <jchang27 at uh.edu> wrote:
>>> Hello,
>>> I am using DMPlexProjectField(...) to postprocess my final solution u
>>> into another vector sol. I have the following pointwise functions:
>>> /* x-component of gradient */
>>> void velx(const PetscScalar u[], const PetscScalar u_t[], const
>>> PetscScalar u_x[], const PetscScalar a[], const PetscScalar a_t[], const
>>> PetscScalar a_x[], const PetscReal x[], PetscScalar v[])
>>>   v[0] = -a[0]*mu*u_x[0];
>>> /* y-component of gradient */
>>> void vely(const PetscScalar u[], const PetscScalar u_t[], const
>>>   v[0] = -a[0]*mu*u_x[1];
>>> /* z-component of gradient */
>>> void velz(const PetscScalar u[], const PetscScalar u_t[], const
>>>   v[0] = -a[0]*mu*u_x[2];
>>> Where a[0] is the cell-wise permeability and mu is the (inverse of)
>>> viscosity. I am solving the diffusion equation (P1 elements). At the end of
>>> my simulation I have these lines:
>>> ierr = VecDuplicate(user.u,&user.sol);CHKERRQ(ierr);
>>> ierr = PetscObjectSetName((PetscObject) user.sol,
>>> void (*vX[1])(const PetscScalar *, const PetscScalar *, const
>>> PetscScalar *, const PetscScalar *, const PetscScalar *, const PetscScalar
>>> *, const PetscReal *, PetscScalar *) = {velx};
>>> ierr =
>>> DMPlexProjectField(dm,user.u,vX,INSERT_ALL_VALUES,user.sol);CHKERRQ(ierr);
>>> ierr = VecViewFromOptions(user.sol,NULL,"-vec_view_x");CHKERRQ(ierr);
>>> void (*vY[1])(const PetscScalar *, const PetscScalar *, const
>>> *, const PetscReal *, PetscScalar *) = {vely};
>>> ierr =
>>> DMPlexProjectField(dm,user.u,vY,INSERT_ALL_VALUES,user.sol);CHKERRQ(ierr);
>>> ierr = VecViewFromOptions(user.sol,NULL,"-vec_view_y");CHKERRQ(ierr);
>>> if (spatialDim == 3) {
>>>   void (*vZ[1])(const PetscScalar *, const PetscScalar *, const
>>> *, const PetscReal *, PetscScalar *) = {velz};
>>>   ierr =
>>> DMPlexProjectField(dm,user.u,vZ,INSERT_ALL_VALUES,user.sol);CHKERRQ(ierr);
>>>   ierr = VecViewFromOptions(user.sol,NULL,"-vec_view_z");CHKERRQ(ierr);
>>> ierr = VecDestroy(&user.sol);CHKERRQ(ierr);
>>> But when i look at the results, the dirichlet constrained values of u
>>> were projected into the respective locations in sol. I thought putting
>>> INSERT_ALL_VALUES would insert the pointwise functions into all locations
>>> including the constrained ones. How can I project the above pointwise
>>> functions into the constrained fields? Or what am I potentially missing
>>> here?
>> There are no Dirichlet constrained values in the global vector user.sol.
>> When you call VecView() it gets projected to
>> an enlarged vector including the BC and output. What you want is to
>> project that vector into a space with no constraints,
>> so you really need another DM/Section combination.
>> I think this will work:
>>   1) Get a local vector from dm
>>   2) Use DMPlexProjectFieldLocal(INSERT_ALL_VALUES) to fill it up
>>   3) DMClone(dm) and give it a Section with no constraints
>>   4) Use DMLocalToGlobal() into the new DM
>>   5) VecView() that new global vector
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Justin Chang
>>> PhD Candidate, Civil Engineering - Computational Sciences
>>> University of Houston, Department of Civil and Environmental Engineering
>>> Houston, TX 77004
>>> (512) 963-3262
>> experiments lead.
>> -- Norbert Wiener
> Justin Chang
> Houston, TX 77004
> (512) 963-3262
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150424/dc68ccc9/attachment-0001.html>
