[petsc-users] Uninitialized values within mesh generation
Justin Chang jchang27 at uh.edu
Sun Apr 19 17:20:23 CDT 2015
Hi all,
I have the following lines for mesh generation:
      DM boundary;
      ierr = DMCreate(comm,&boundary);CHKERRQ(ierr);
      ierr = DMSetType(boundary, DMPLEX);CHKERRQ(ierr);
      ierr = DMSetDimension(boundary, spatialDim-1);CHKERRQ(ierr);
      switch (spatialDim) {
        case 2:
          ierr =
DMPlexCreateSquareBoundary(boundary,lower,upper,edges);CHKERRQ(ierr);
          break;
        case 3:
          ierr =
DMPlexCreateCubeBoundary(boundary,lower,upper,edges);CHKERRQ(ierr);
          break;
        default:
          SETERRQ1(comm,PETSC_ERR_SUP,"Dimension not supported:
%d",spatialDim);
      ierr = DMPlexGenerate(boundary,NULL,PETSC_TRUE,dm);CHKERRQ(ierr);
      ierr = DMDestroy(&boundary);CHKERRQ(ierr);
where lower and upper are global PetscScalars * and edges is a global
PetscInt *. These values are PetscCalloc'ed and initialized via commandline
options (PetscOptionsGetScalar/IntArray). When I run my code with valgrind,
I get the following messages:
==12706== Conditional jump or move depends on uninitialised value(s)
==12706==    at 0x65E778C: TetGenMeshPointTraverse(TetGenMesh*, double**)
(ctetgen.c:4107)
==12706==    by 0x661C8F8: TetGenMeshDelaunizeVertices(TetGenMesh*)
(ctetgen.c:12091)
==12706==    by 0x6661A8E: TetGenTetrahedralize(TetGenOpts*, PLC*, PLC*)
(ctetgen.c:21483)
==12706==    by 0x5B655EB: DMPlexGenerate_CTetgen(_p_DM*, PetscBool,
_p_DM**) (plexgenerate.c:834)
==12706==    by 0x5B685F4: DMPlexGenerate (plexgenerate.c:1080)
==12706==    by 0x409B6D: CreateMesh(int, AppCtx*, _p_DM**) (main.c:657)
==12706==    by 0x40DBA8: main (main.c:1005)
==12706==
==12706==    at 0x661BF6C: TetGenMeshDelaunayIncrFlip(TetGenMesh*,
triface*, double**, long, PetscBool, PetscBool, double, Queue*)
(ctetgen.c:12011)
==12706==    by 0x661CD0B: TetGenMeshDelaunizeVertices(TetGenMesh*)
(ctetgen.c:12113)
(ctetgen.c:21483)
==12706==
==12706==    at 0x661BFB6: TetGenMeshDelaunayIncrFlip(TetGenMesh*,
(ctetgen.c:12014)
(ctetgen.c:12113)
(ctetgen.c:21483)
==12706==
==12706==    at 0x661C004: TetGenMeshDelaunayIncrFlip(TetGenMesh*,
(ctetgen.c:12017)
(ctetgen.c:12113)
(ctetgen.c:21483)
==12706==
==12706==    at 0x661C048: TetGenMeshDelaunayIncrFlip(TetGenMesh*,
(ctetgen.c:12020)
(ctetgen.c:12113)
(ctetgen.c:21483)
==12706==
==12706==    at 0x661B232: TetGenMeshInsertVertexBW(TetGenMesh*, double*,
triface*, PetscBool, PetscBool, PetscBool, PetscBool, locateresult*)
(ctetgen.c:11905)
==12706==    by 0x661C2AF: TetGenMeshDelaunayIncrFlip(TetGenMesh*,
(ctetgen.c:12046)
(ctetgen.c:12113)
(ctetgen.c:21483)
==12706==
What does this mean? Is there something wrong/missing with the current
implementation of the mesh generation?
Justin
Justin Chang
PhD Candidate, Civil Engineering - Computational Sciences
University of Houston, Department of Civil and Environmental Engineering
Houston, TX 77004
(512) 963-3262
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150419/7643a4cc/attachment.html>
