[petsc-users] install petsc with valgrind
Sun Apr 19 10:15:53 CDT 2015
On Sun, Apr 19, 2015 at 9:56 AM, Sun, Hui <hus003 at ucsd.edu> wrote:
> I try to run
> -@${PETSC_DIR}/bin/petscmpiexec -valgrind -n 2 ./test -mx 32 -my 32 -mz 32
> It seems to be working, except that it gives me an error message:
> --21019-- run: /usr/bin/dsymutil
> "/Users/hus003/Documents/software/petsc-valgrind/petsc-valgrind-debug/lib/libpetsc.3.05.3.dylib"
> --21020-- run: /usr/bin/dsymutil
> error: No such file or directory - old dSYM file cannot be overwritten:
>      old:
> '/Users/hus003/Documents/software/petsc-valgrind/petsc-valgrind-debug/lib/libpetsc.3.05.3.dylib.dSYM/Contents/Resources/DWARF/libpetsc.3.05.3.dylib'
It sounds like you created this as root or something.
  Matt
> new:'/Users/hus003/Documents/software/petsc-valgrind/petsc-valgrind-debug/lib/libpetsc.3.05.3.dylib.dSYM/Contents/Resources/DWARF/libpetsc.3.05.3.dylib.x86_64'.
> Why do I get this message? Do I need to get rid of it?
> Best,
> Hui
> From: Sun, Hui
> Sent: Friday, April 17, 2015 3:37 PM
> To: petsc-users
> Cc: Matthew Knepley
> Subject: RE: [petsc-users] install petsc with valgrind
> Thank you Satish! It works perfect.
> Hui
> From: Satish Balay [balay at mcs.anl.gov]
> Sent: Friday, April 17, 2015 3:29 PM
> To: Sun, Hui
> Cc: Matthew Knepley; petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] install petsc with valgrind
> Well - its best if the .o files are not deleted..  [then you don't
> have to run dsymutil]. One way to do it [if using PETSc makefiles] is:
> make test RM=/bin/true
> To run dsymutil - I think you need the .o files anyway - and run it as
> instructed below.
> > --66450-- run: /usr/bin/dsymutil "./test"
> Satish
> On Fri, 17 Apr 2015, Sun, Hui wrote:
> > How do I run dsymutil so as to get the line numbers?
> > From: Matthew Knepley [knepley at gmail.com]
> > Sent: Friday, April 17, 2015 3:10 PM
> > To: Sun, Hui
> > Cc: Barry Smith; petsc-users at mcs.anl.gov
> > On Fri, Apr 17, 2015 at 5:09 PM, Sun, Hui <hus003 at ucsd.edu<mailto:
> hus003 at ucsd.edu>> wrote:
> > I'm not sure if I'm doing the right thing. But I have just
> > export PATH=$PATH:dir_to_valgind_bin
> > And I rerun the command:
> > -@${PETSC_DIR}/bin/petscmpiexec -valgrind -n ${NP} ./test -mx ${ND} -my
> ${ND} -mz ${ND} -ksp_monitor_short -ksp_type fgmres -pc_type asm
> > Then it seems to output something, for example:
> > ==66450== Invalid write of size 8
> > ==66450==    at 0x100055225: Schur_SetMatrix (in ./test)
> > ==66450==    by 0x10004F218: StokesSetup (in ./test)
> > ==66450==    by 0x1000DC582: main (in ./test)
> > ==66450==  Address 0x7fff5f93fb28 is on thread 1's stack
> > ==66450==  in frame #0, created by Schur_SetMatrix (???)
> > ==66450==
> > Yes, this worked, and it shows you have a memory overwrite in your code.
> You have no line
> > numbers because you deleted the *.o files without running dsymutil.
> > And before those output, it has the following lines:
> > warning: (x86_64) /Users/hus003/projects/LS_BDRY/test/test.o unable to
> open object file
> > warning: no debug symbols in executable (-arch x86_64)
> "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libmpicxx.12.dylib"
> "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libmpifort.12.dylib"
> "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libmpi.12.dylib"
> "/Users/hus003/Documents/software/petsc-valgrind-install/lib/libpmpi.12.dylib"
> > Does it mean that it's working? But what does these two warnings mean?
> > These warnings mean that symbols are missing from those libraries, which
> is no surprise.
> >    matt
> > Best,
> > Hui
> > From: Barry Smith [bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov>]
> > Sent: Friday, April 17, 2015 2:57 PM
> > To: Matthew Knepley
> > Cc: Sun, Hui; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
> >   Or make sure valgrind is in your path
> > > On Apr 17, 2015, at 4:56 PM, Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
> > > As I said, it cannot find valgrind in your path. Remove it or install
> valgrind.
> > >    Matt
> > > On Fri, Apr 17, 2015 at 4:55 PM, Sun, Hui <hus003 at ucsd.edu<mailto:
> > > Thank you, Matt and Barry. I was trying to run the following:
> -my ${ND} -mz ${ND} -ksp_monitor_short -ksp_type fgmres -pc_type asm
> > > where NP=2, ND=32
> > > And in the makefile I have specified the following:
> > > include ${PETSC_DIR}/lib/petsc/conf/variables
> > > include ${PETSC_DIR}/lib/petsc/conf/rules
> > > include ${PETSC_DIR}/lib/petsc/conf/test
> > > Best,
> > > Hui
> > > Sent: Friday, April 17, 2015 2:50 PM
> > > To: Sun, Hui
> > > Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
> > >   Please please please always show WHAT YOU RAN with the error
> message. Otherwise we just must guess
> > > > On Apr 17, 2015, at 3:58 PM, Sun, Hui <hus003 at ucsd.edu<mailto:
> > > > Thank you Barry. I just have it installed. And I was running a code,
> and got the following error message:
> > > > HYDU_create_process (utils/launch/launch.c:75): execvp error on file
> valgrind: (No such file or directory)
> > > > =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> > > > =   PID 66059 RUNNING AT math178.ucsd.edu<http://math178.ucsd.edu>
> > > > =   EXIT CODE: 255
> > > > =   CLEANING UP REMAINING PROCESSES
> > > > =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> > > > What does this mean?
> > > > Best,
> > > > Hui
> > > > Sent: Friday, April 17, 2015 1:08 PM
> > > > To: Sun, Hui
> > > >   The development copy of PETSc allows using --prefix with MPICH
> http://www.mcs.anl.gov/petsc/developers/index.html
> > > >> On Apr 17, 2015, at 2:38 PM, Sun, Hui <hus003 at ucsd.edu<mailto:
> > > >> Hello,
> > > >> I want to install petsc with valgrind. And I read some
> documentations, which suggests me to do
> > > >> ./configure --download-mpich --with-valgind-dir=…
> > > >> However, I also want to specify --prefix, but petsc doesn't allow
> me, because --download-mpich option does not work with --prefix install.
> > > >> Is there anyway that I can have petsc --prefix, together with
> valgrind?
> > > >> Best,
> > > >> Hui
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150419/02bdd259/attachment-0001.html>
