[petsc-users] How to use PETSc in debug?
Thu Apr 16 13:55:42 CDT 2015
On Thu, Apr 16, 2015 at 1:35 PM, Song Gao <song.gao2 at mail.mcgill.ca> wrote:
> Dear PETSc users,
> I'm debugging my code but cannot see those line informations in gdb
> I compiled PETSc with
> --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack
> --download-mpich --with-debugging=yes
> I modified my code from KSP ex1f.F and use that makefile.
> Then compiled code
> make PETSC_DIR=/home/cfd/sgao/bin/petsc-3.5.3 PETSC_ARCH=FEM_project_DEBUG
> ex1f
> The log is attached, I see the -g flag there. But when I run code with
> gdb, I didn't see line information there.
> $gdb ./ex1f
> (gdb) b main
> Breakpoint 1 at 0x4080e0: file ../../../gcc-4.3.0/libgfortran/fmain.c,
> line 11.
main() is not the Fortran entry point. You might be better off working in C.
However, if you really want Fortran, try breaking at a line number in your
file. Also
make sure you did not delete the *.o file
   Matt
> (gdb) r
> Starting program: /home/cfd/sgao/FEM_in_CFD/code/ex1f
> [Thread debugging using libthread_db enabled]
> Breakpoint 1, main (argc=1, argv=0x7fffffffcc58) at
> ../../../gcc-4.3.0/libgfortran/fmain.c:11
> 11 ../../../gcc-4.3.0/libgfortran/fmain.c: No such file or directory.
> in ../../../gcc-4.3.0/libgfortran/fmain.c
> (gdb) l
> 6 in ../../../gcc-4.3.0/libgfortran/fmain.c
> (gdb)
> What did I miss here? Thank you in advance.
> Song
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150416/d2051c11/attachment.html>
