[petsc-users] ghost values
Gideon Simpson gideon.simpson at gmail.com
Tue Apr 14 18:15:06 CDT 2015
Other than zeroing things out, is there any substantive difference between DMCreateLocalVector and DMGetLocalVector?
-gideon
> On Apr 14, 2015, at 7:02 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  When PETSc vectors are created initially they always have 0 everywhere. So if you use DMCreateLocalVector() it will have zero in all those ghost places (as well as everywhere else).
>   But if you use DMGetLocalVector() it returns vectors that maybe dirty so you need to fill in any locations you want to have a known value with that known value. Or call VecSet() to clear the entire vector.
>  Barry
>> On Apr 14, 2015, at 5:52 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>> If i use the DM_BOUNDARY_GHOSTED flag in the creation of a DMDA array, are the ghosted values automatically set to zero, or should they be manually set to zero if that’s the desired ghost value?
>> -gideon
