[petsc-users] Tao iterations
Jason Sarich jason.sarich at gmail.com
Tue Apr 14 09:35:28 CDT 2015
Hi Justin,
I have pushed these changes to the "next" branch, your code snippet should
work fine there.
Note that there is also available (since version 3.5.0) the routine
TaoGetSolutionStatus(tao,&its,NULL,NULL,NULL,NULL,NULL) which will provide
the
same information
Jason
On Fri, Apr 10, 2015 at 6:28 PM, Justin Chang <jychang48 at gmail.com> wrote:
>   Whatever is convenient and/or follow the "PETSc" standards. Something
> similar to SNESGetIterationNumber() or KSPGetIterationNumber() would be
> nice. Ideally I want my code to look like this:
>  ierr = TaoGetIterationNumber(tao,&its);CHKERRQ(ierr);
>  ierr = PetscPrintf(PETSC_COMM_WORLD, "Number of Tao iterations = %D\n",
> its);
>  Thanks :)
> On Fri, Apr 10, 2015 at 5:53 PM, Jason Sarich <jason.sarich at gmail.com>
> wrote:
>> Hi Justin, I'll get this in. I assume that displaying the number of
>> iterations with tao_converged_reason is what you are asking for in
>> particular? Or did you have something else in mind?
>> Jason
>>  On Apr 10, 2015 16:42, "Smith, Barry F." <bsmith at mcs.anl.gov> wrote:
>>>   Justin,
>>>     Sorry TAO simply doesn't even collect this information currently.
>>> But yes we should definitely make it available!
>>>   Jason,
>>>      Could you please add this; almost all the TaoSolve_xxx() have a
>>> local variable iter; change that to tao->niter (I'm guess this is suppose
>>> to capture this information) and add a TaoGetIterationNumber() and the uses
>>> can access this. Also modify at the end of TaoSolve() -tao_converged_reason
>>> to also print the iteration count. At the same time since you add this you
>>> can add a tao->totalits which would accumulate all iterations over all the
>>> solves for that Tao object and the routine TaoGetTotalIterations() to
>>> access this.  Note that TaoSolve() would initialize tao->niter = 0 at the
>>> top.
>>>    Thanks
>>>   Barry
>>> > On Apr 10, 2015, at 4:16 PM, Justin Chang <jchang27 at uh.edu> wrote:
>>>  > Hi all,
>>> > Is there a way to generically obtain the number of Tao iterations? I
>>> am looking through the -help options for Tao and I don't see any metric
>>> where you can output this quantity in the manner that you could for SNES or
>>> KSP solves. I am currently using blmvm and tron, and the only way I can see
>>> getting this metric is by outputting -tao_view and/or -tao_monitor and
>>> manually finding this number. I find this cumbersome especially for
>>> transient problems where I would like to simply have this number printed
>>> for each step instead of ending up with unnecessary info.
>>> > Thanks,
>>> > Justin Chang
>>> > PhD Candidate, Civil Engineering - Computational Sciences
>>> > University of Houston, Department of Civil and Environmental
>>> Engineering
>>> > Houston, TX 77004
>>> > (512) 963-3262
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150414/315bb0f4/attachment.html>
