[petsc-users] For users of PETSc repository only
Sun Apr 12 12:26:58 CDT 2015
   If you use PETSc 3.5.3 or earlier releases you can ignore this message. It only affects those using the pre-release PETSc repository code.
   I have changed some of the directory structure of PETSc which will your makefiles and Fortran source code.
   The locations of the PETSc include makefiles has changed from  lib/petsc-conf/  to lib/petsc/conf  This means items such as
include ${PETSC_DIR}/lib/petsc-conf/variables
include ${PETSC_DIR}/lib/petsc-conf/rules
   need to be changed in your makefiles to
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
   The locations of the PETSc fortran include files has changed from petsc-finclude to petsc/finclude This means items such as
#include <petsc-finclude/petscsys.h>
#include <petsc-finclude/petscvec.h>
   in your Fortran source needs to be changed to
#include <petsc/finclude/petscsys.h>
#include <petsc/finclude/petscvec.h>
  The reason for the change is to match Linux packaging standards for locations of files and directories. I hope this will be the last change for this for a long while, thanks for your patience
  Barry
