[petsc-users] monitoring the convergence of fieldsplit 0 and 1
Fri Apr 10 12:58:52 CDT 2015
On Fri, Apr 10, 2015 at 12:57 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Apr 10, 2015, at 8:07 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> > Barry,
> > Sure, I can call PCFieldSplitGetSubKSP() to get the fieldsplit_0
> > ksp and then KSPGetIterationNumber, but what does this number
> > mean?
> > It appears to be the number of iterations of the last time that
> > the subsystem was solved, right? If so, this corresponds to the
> > last iteration of the coupled system, how about all the previous
> > iterations?
>    If I added a KSPGetTotalIterations() would that help?
Its hard to see how to define this consistently. I think this is better
handled by custom monitors.
We could provide a default monitor for FieldSplit which does this.
  Matt
> Barry
> > Chris
> > ________________________________________
> > From: Barry Smith <bsmith at mcs.anl.gov>
> > Sent: Friday, April 10, 2015 2:48 PM
> > To: Klaij, Christiaan
> > Cc: petsc-users at mcs.anl.gov
> > Subject: Re: [petsc-users] monitoring the convergence of fieldsplit 0
> and 1
> >   Chris,
> >     It appears you should call PCFieldSplitGetSubKSP() and then get the
> information you want out of the individual KSPs. If this doesn't work
> please let us know.
> >   Barry
> >> On Apr 10, 2015, at 6:48 AM, Klaij, Christiaan <C.Klaij at marin.nl>
> wrote:
> >> A question when using PCFieldSplit: for each linear iteration of
> >> the system, how many iterations for fielsplit 0 and 1?
> >> One way to find out is to run with -ksp_monitor,
> >> -fieldsplit_0_ksp_monitor and -fieldsplit_0_ksp_monitor. This
> >> gives the complete convergence history.
> >> Another way, suggested by Matt, is to use -ksp_monitor,
> >> -fieldsplit_0_ksp_converged_reason and
> >> -fieldsplit_1_ksp_converged_reason. This gives only the totals
> >> for fieldsplit 0 and 1 (but without saying for which one).
> >> Both ways require to somehow process the output, which is a bit
> >> inconvenient. Could KSPGetResidualHistory perhaps return (some)
> >> information on the subsystems' convergence for processing inside
> >> the code?
> >> Chris
> >> dr. ir. Christiaan Klaij
> >> CFD Researcher
> >> Research & Development
> >> E mailto:C.Klaij at marin.nl
> >> T +31 317 49 33 44
> >> MARIN
> >> 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> >> T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150410/7715fe10/attachment.html>
