[petsc-users] monitoring the convergence of fieldsplit 0 and 1
Klaij, Christiaan C.Klaij at marin.nl
Fri Apr 10 06:48:33 CDT 2015
A question when using PCFieldSplit: for each linear iteration of
the system, how many iterations for fielsplit 0 and 1?
One way to find out is to run with -ksp_monitor,
-fieldsplit_0_ksp_monitor and -fieldsplit_0_ksp_monitor. This
gives the complete convergence history.
Another way, suggested by Matt, is to use -ksp_monitor,
-fieldsplit_0_ksp_converged_reason and
-fieldsplit_1_ksp_converged_reason. This gives only the totals
for fieldsplit 0 and 1 (but without saying for which one).
Both ways require to somehow process the output, which is a bit
inconvenient. Could KSPGetResidualHistory perhaps return (some)
information on the subsystems' convergence for processing inside
the code?
Chris
dr. ir. Christiaan Klaij
CFD Researcher
Research & Development
E mailto:C.Klaij at marin.nl
T +31 317 49 33 44
MARIN
2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
T +31 317 49 39 11, F +31 317 49 32 45, I www.marin.nl
