[petsc-users] Uninterpolating DMLabels?
Thu Apr 9 20:20:45 CDT 2015
On Thu, Apr 9, 2015 at 8:14 PM, Justin Chang <jchang27 at uh.edu> wrote:
> Matt, thank you for the clarification. One more question somewhat on a
> related note.
> I have auxiliary data corresponding to the permeability of a reservoir
> (for instance, the SPE10 benchmark problem). The data is cell-wise and read
> from a binary file. I want to refine both the DM and this data. Is there a
> way to obtain the mapping from the coarse mesh to the fine mesh? What I
> mean is, given a coarse cell, can I somehow get the transitive closure of
> the fine cells it created during the refinement process? This would allow
> me to copy the value of the coarse cell data onto it's children.
If you are doing regular refinement, there is a simple formula:
  c_f \in [ C c_c, C (c_c +1) )
where C is the number of cells created from each cell. You can get C from
  CellRefinerGetAffineTransforms_Internal()
which I could promote to a real interface function.
     Matt
> Thanks,
> On Thu, Apr 9, 2015 at 7:52 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Apr 9, 2015 at 7:21 PM, Justin Chang <jchang27 at uh.edu> wrote:
>>> 1) I did what you had suggested and it works very well thanks.
>> Cool.
>>> 2) In my case, calling uninterpolate does make a difference, just not
>>> necessarily in the solver step (I am using Tao's BLMVM). I attached two
>>> output files, one containing the timings and summaries with uninterpolating
>>> and one without uninterpolating. And the source code if you wanted to
>>> verify the "correctness" of my implementation. Namely, the biggest
>>> difference I see is in setting up the PetscSection. When uninterpolating
>>> the data this steps takes 8.64039 seconds but when I do not uninterpolate
>>> the data it takes 61.2977 seconds. Is this "significant" enough, or is it
>>> unimportant given the fact that this step occurs only once during any
>>> simulation?
>> That is significant. Most of that time is in the operator preallocation
>> routine. It was cleaner to first gather the point
>> adjacency information, and then push the dof information on top. If I
>> aggressively merged the dof data, I could have
>> pruned a bunch of the work here and gotten much closer to the first time,
>> at the expense of more complicated code.
>> I guess this is the right pattern if you know that you will only have
>> unknowns on cells and vertices.
>>> 3) Also, about DMPlexDistribute(...). Right now it still seems extremely
>>> slow, hence why I am distributing a coarse mesh and having each processor
>>> refine its local portion of the mesh. In my current implementation, I have
>>> rank 0 distribute the mesh via ParMETIS. Will there eventually be a
>>> methodology to do parallel I/O then redistribution for load balancing or
>>> does it already exist?
>> Redistribution for load balancing already exists. The stumbling block
>> right now is parallel mesh import. However,
>> the group at ICL (Michael Lange and Gerard Gorman) is working on this,
>> and we expect to have it working by
>> the end of summer. Until then, I recommend exactly what you are doing.
>>   Thanks,
>>      Matt
>>> Thanks,
>>> On Tue, Apr 7, 2015 at 8:37 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Apr 7, 2015 at 7:18 PM, Justin Chang <jchang27 at uh.edu> wrote:
>>>>> Hi all,
>>>>> So I am interpolating/uninterpolating my DMPlex mesh. This is the mesh
>>>>> information for a cell-vertex mesh only:
>>>>> DM Object: 1 MPI processes
>>>>>   type: plex
>>>>> DM_0x84000000_0 in 3 dimensions:
>>>>>   0-cells: 159
>>>>>   3-cells: 592
>>>>> Labels:
>>>>>   marker: 1 strata of sizes (100)
>>>>>   depth: 2 strata of sizes (159, 592)
>>>>> I am interpolating the mesh with the following lines:
>>>>>   ierr = DMPlexInterpolate(*dm, &idm);CHKERRQ(ierr);
>>>>>   ierr = DMPlexCopyCoordinates(*dm, idm);CHKERRQ(ierr);
>>>>>   ierr = DMPlexCopyLabels(*dm, idm);CHKERRQ(ierr);
>>>>>   ierr = DMPlexGetLabel(idm, "marker", &label);CHKERRQ(ierr);
>>>>>   ierr = DMPlexMarkBoundaryFaces(idm,label);CHKERRQ(ierr);
>>>>>   ierr = DMDestroy(dm);CHKERRQ(ierr);
>>>>>   *dm = idm;
>>>>> And the resulting mesh:
>>>>>   type: plex
>>>>> DM_0x84000000_1 in 3 dimensions:
>>>>>   0-cells: 159
>>>>>   1-cells: 845
>>>>>   2-cells: 1280
>>>>>   3-cells: 592
>>>>> Labels:
>>>>>   marker: 1 strata of sizes (292)
>>>>>   depth: 4 strata of sizes (159, 845, 1280, 592)
>>>>> The reason I did this is so that incase I decide to refine the mesh
>>>>> with "-dm_refine <number>" the DM will be sure to include the "marker"
>>>>> points in the refinement process. Now, if I decide to uninterpolate the
>>>>>   ierr = DMPlexUninterpolate(*dm, &idm);CHKERRQ(ierr);
>>>>>   *dm = idm;
>>>>> I end up with this mesh:
>>>>>   type: plex
>>>>> DM_0x84000000_2 in 3 dimensions:
>>>>>   0-cells: 159
>>>>>   3-cells: 592
>>>>> Labels:
>>>>> The problem is that although the cells and vertices have gone back to
>>>>> the original number, the "marker" label still includes face/edge points.
>>>>> This gives me an error once I invoke DMCreateGobalVector(...).
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>> [0]PETSC ERROR: Argument out of range
>>>>> [0]PETSC ERROR: Section point 755 should be in [0, 751)
>>>>> [0]PETSC ERROR: See
>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>> shooting.
>>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2528-gbee642f
>>>>> GIT Date: 2015-03-29 20:36:38 -0500
>>>>> [0]PETSC ERROR: ./cube_with_hole on a arch-linux2-c-debug named
>>>>> pacotaco by justin Tue Apr  7 19:09:12 2015
>>>>> [0]PETSC ERROR: Configure options --download-chaco --download-exodusii
>>>>> --download-fblaslapack --download-hdf5 --download-metis --download-mpich
>>>>> --download-mumps --download-netcdf --download-parmetis --download-scalapack
>>>>> --download-triangle --with-cc=gcc --with-cmake=cmake --with-cxx=g++
>>>>> --with-debugging=1 --with-fc=gfortran --with-valgrind=1
>>>>> PETSC_ARCH=arch-linux2-c-debug
>>>>> [0]PETSC ERROR: #1 PetscSectionGetDof() line 499 in
>>>>> /home/justin/petsc-dev/src/vec/is/utils/vsectionis.c
>>>>> [0]PETSC ERROR: #2 DMPlexGetConeSize() line 841 in
>>>>> /home/justin/petsc-dev/src/dm/impls/plex/plex.c
>>>>> [0]PETSC ERROR: #3 DMPlexGetTransitiveClosure() line 1342 in
>>>>> [0]PETSC ERROR: #4 DMPlexLabelComplete() line 88 in
>>>>> /home/justin/petsc-dev/src/dm/impls/plex/plexsubmesh.c
>>>>> [0]PETSC ERROR: #5 DMCreateDefaultSection_Plex() line 5605 in
>>>>> [0]PETSC ERROR: #6 DMGetDefaultSection() line 3035 in
>>>>> /home/justin/petsc-dev/src/dm/interface/dm.c
>>>>> [0]PETSC ERROR: #7 DMGetDefaultGlobalSection() line 3266 in
>>>>> [0]PETSC ERROR: #8 DMCreateGlobalVector_Section_Private() line 13 in
>>>>> /home/justin/petsc-dev/src/dm/interface/dmi.c
>>>>> [0]PETSC ERROR: #9 DMCreateGlobalVector_Plex() line 1170 in
>>>>> /home/justin/petsc-dev/src/dm/impls/plex/plexcreate.c
>>>>> [0]PETSC ERROR: #10 DMCreateGlobalVector() line 698 in
>>>>> [0]PETSC ERROR: #11 main() line 363 in
>>>>> /home/justin/Dropbox/Research_Topics/Code_PETSc/Nonneg/cube_with_hole.c
>>>>> From this error, it seems it's trying to access sieve points that non
>>>>> longer exist. And I think it has to do with the label "marker" still
>>>>> contains data from the interpolated mesh. Is there a way to "uninterpolate"
>>>>> or remove such points? Or is there a better way of approaching this whole
>>>>> thing?
>>>> 1) It would be easy to write a small function to throw out the points
>>>> in the label that do not exist in the DM. You
>>>>     would just extract each stratumIS and then Clear each invalid point.
>>>> 2) However, I do not understand the rationale for this above. You could
>>>> just call MarkBoundaryFaces on the final mesh.
>>>>     If you are really trying to preserve a label across regular
>>>> refinement AND you really do not want an interpolated mesh,
>>>>     then code up 1). I have yet to see a case where the extra memory
>>>> for edges and faces makes a difference, but it may exist.
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks,
>>>>> Justin Chang
>>>>> PhD Candidate, Civil Engineering - Computational Sciences
>>>>> University of Houston, Department of Civil and Environmental
>>>>> Engineering
>>>>> Houston, TX 77004
>>>>> (512) 963-3262
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Justin Chang
>>> University of Houston, Department of Civil and Environmental Engineering
>>> Houston, TX 77004
>>> (512) 963-3262
>> experiments lead.
>> -- Norbert Wiener
> Justin Chang
> Houston, TX 77004
> (512) 963-3262
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150409/8524930c/attachment.html>
