[petsc-users] Uninterpolating DMLabels?
Justin Chang jchang27 at uh.edu
Thu Apr 9 19:21:28 CDT 2015
1) I did what you had suggested and it works very well thanks.
2) In my case, calling uninterpolate does make a difference, just not
necessarily in the solver step (I am using Tao's BLMVM). I attached two
output files, one containing the timings and summaries with uninterpolating
and one without uninterpolating. And the source code if you wanted to
verify the "correctness" of my implementation. Namely, the biggest
difference I see is in setting up the PetscSection. When uninterpolating
the data this steps takes 8.64039 seconds but when I do not uninterpolate
the data it takes 61.2977 seconds. Is this "significant" enough, or is it
unimportant given the fact that this step occurs only once during any
simulation?
3) Also, about DMPlexDistribute(...). Right now it still seems extremely
slow, hence why I am distributing a coarse mesh and having each processor
refine its local portion of the mesh. In my current implementation, I have
rank 0 distribute the mesh via ParMETIS. Will there eventually be a
methodology to do parallel I/O then redistribution for load balancing or
does it already exist?
On Tue, Apr 7, 2015 at 8:37 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Apr 7, 2015 at 7:18 PM, Justin Chang <jchang27 at uh.edu> wrote:
>> Hi all,
>> So I am interpolating/uninterpolating my DMPlex mesh. This is the mesh
>> information for a cell-vertex mesh only:
>> DM Object: 1 MPI processes
>>   type: plex
>> DM_0x84000000_0 in 3 dimensions:
>>   0-cells: 159
>>   3-cells: 592
>> Labels:
>>   marker: 1 strata of sizes (100)
>>   depth: 2 strata of sizes (159, 592)
>> I am interpolating the mesh with the following lines:
>>   ierr = DMPlexInterpolate(*dm, &idm);CHKERRQ(ierr);
>>   ierr = DMPlexCopyCoordinates(*dm, idm);CHKERRQ(ierr);
>>   ierr = DMPlexCopyLabels(*dm, idm);CHKERRQ(ierr);
>>   ierr = DMPlexGetLabel(idm, "marker", &label);CHKERRQ(ierr);
>>   ierr = DMPlexMarkBoundaryFaces(idm,label);CHKERRQ(ierr);
>>   ierr = DMDestroy(dm);CHKERRQ(ierr);
>>   *dm = idm;
>> And the resulting mesh:
>>   type: plex
>> DM_0x84000000_1 in 3 dimensions:
>>   0-cells: 159
>>   1-cells: 845
>>   2-cells: 1280
>>   3-cells: 592
>> Labels:
>>   marker: 1 strata of sizes (292)
>>   depth: 4 strata of sizes (159, 845, 1280, 592)
>> The reason I did this is so that incase I decide to refine the mesh with
>> "-dm_refine <number>" the DM will be sure to include the "marker" points in
>> the refinement process. Now, if I decide to uninterpolate the mesh with the
>> following lines:
>>   ierr = DMPlexUninterpolate(*dm, &idm);CHKERRQ(ierr);
>>   *dm = idm;
>> I end up with this mesh:
>>   type: plex
>> DM_0x84000000_2 in 3 dimensions:
>>   0-cells: 159
>>   3-cells: 592
>> Labels:
>> The problem is that although the cells and vertices have gone back to the
>> original number, the "marker" label still includes face/edge points. This
>> gives me an error once I invoke DMCreateGobalVector(...).
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Argument out of range
>> [0]PETSC ERROR: Section point 755 should be in [0, 751)
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.3-2528-gbee642f  GIT
>> Date: 2015-03-29 20:36:38 -0500
>> [0]PETSC ERROR: ./cube_with_hole on a arch-linux2-c-debug named pacotaco
>> by justin Tue Apr  7 19:09:12 2015
>> [0]PETSC ERROR: Configure options --download-chaco --download-exodusii
>> --download-fblaslapack --download-hdf5 --download-metis --download-mpich
>> --download-mumps --download-netcdf --download-parmetis --download-scalapack
>> --download-triangle --with-cc=gcc --with-cmake=cmake --with-cxx=g++
>> --with-debugging=1 --with-fc=gfortran --with-valgrind=1
>> PETSC_ARCH=arch-linux2-c-debug
>> [0]PETSC ERROR: #1 PetscSectionGetDof() line 499 in
>> /home/justin/petsc-dev/src/vec/is/utils/vsectionis.c
>> [0]PETSC ERROR: #2 DMPlexGetConeSize() line 841 in
>> /home/justin/petsc-dev/src/dm/impls/plex/plex.c
>> [0]PETSC ERROR: #3 DMPlexGetTransitiveClosure() line 1342 in
>> [0]PETSC ERROR: #4 DMPlexLabelComplete() line 88 in
>> /home/justin/petsc-dev/src/dm/impls/plex/plexsubmesh.c
>> [0]PETSC ERROR: #5 DMCreateDefaultSection_Plex() line 5605 in
>> [0]PETSC ERROR: #6 DMGetDefaultSection() line 3035 in
>> /home/justin/petsc-dev/src/dm/interface/dm.c
>> [0]PETSC ERROR: #7 DMGetDefaultGlobalSection() line 3266 in
>> [0]PETSC ERROR: #8 DMCreateGlobalVector_Section_Private() line 13 in
>> /home/justin/petsc-dev/src/dm/interface/dmi.c
>> [0]PETSC ERROR: #9 DMCreateGlobalVector_Plex() line 1170 in
>> /home/justin/petsc-dev/src/dm/impls/plex/plexcreate.c
>> [0]PETSC ERROR: #10 DMCreateGlobalVector() line 698 in
>> [0]PETSC ERROR: #11 main() line 363 in
>> /home/justin/Dropbox/Research_Topics/Code_PETSc/Nonneg/cube_with_hole.c
>> From this error, it seems it's trying to access sieve points that non
>> longer exist. And I think it has to do with the label "marker" still
>> contains data from the interpolated mesh. Is there a way to "uninterpolate"
>> or remove such points? Or is there a better way of approaching this whole
>> thing?
> 1) It would be easy to write a small function to throw out the points in
> the label that do not exist in the DM. You
>     would just extract each stratumIS and then Clear each invalid point.
> 2) However, I do not understand the rationale for this above. You could
> just call MarkBoundaryFaces on the final mesh.
>     If you are really trying to preserve a label across regular refinement
> AND you really do not want an interpolated mesh,
>     then code up 1). I have yet to see a case where the extra memory for
> edges and faces makes a difference, but it may exist.
>   Thanks,
>      Matt
>> Thanks,
>> Justin Chang
>> PhD Candidate, Civil Engineering - Computational Sciences
>> University of Houston, Department of Civil and Environmental Engineering
>> Houston, TX 77004
>> (512) 963-3262
> experiments lead.
> -- Norbert Wiener
Justin Chang
Houston, TX 77004
(512) 963-3262
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150409/ea331c22/attachment-0001.html>
  1 processors:
Creating DMPlex... done
DM before interpolating:
  type: plex
DM_0x7fa87381c0a0_0 in 3 dimensions:
  0-cells: 159
  3-cells: 592
Labels:
DM after interpolation:
  type: plex
DM_0x7fa87381c0a0_1 in 3 dimensions:
  0-cells: 159
  1-cells: 845
  2-cells: 1280
  3-cells: 592
Labels:
  marker: 1 strata of sizes (580)
Distributing mesh... done
Refining mesh... done
DM Object:DM_0x7fa87381c0a0_1 1 MPI processes
  type: plex
  0-cells: 416594
  1-cells: 2866000
  2-cells: 4874240
  3-cells: 2424832
Labels:
  marker: 1 strata of sizes (147460)
  depth: 4 strata of sizes (416594, 2866000, 4874240, 2424832)
DM after uninterpolation:
  type: plex
DM_0x7fa87381c0a0_2 in 3 dimensions:
  0-cells: 416594
  3-cells: 2424832
Labels:
  marker: 1 strata of sizes (24580)
  depth: 2 strata of sizes (416594, 2424832)
Setting up and initializing problem... done
  Solving non-negative...
Tao converged with reason 2
  Time summary:
Create DMPlex: 0.00444102s
Distribute and refine DMPlex: 8.95675s
Set up problem: 8.64039s
Solver: 30.9317s
Postprocess into VTU: 0.662271s
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./cube_with_hole on a arch-darwin-c-debug named CAML-03.CIVE.UH.EDU with 1 processor, by jychang48 Thu Apr  9 18:22:03 2015
Using Petsc Development GIT revision: v3.5.3-2528-gbee642f  GIT Date: 2015-03-29 20:36:38 -0500
                         Max       Max/Min        Avg      Total
Time (sec):           4.934e+01      1.00000   4.934e+01
Objects:              2.950e+02      1.00000   2.950e+02
Flops:                2.389e+10      1.00000   2.389e+10  2.389e+10
Flops/sec:            4.841e+08      1.00000   4.841e+08  4.841e+08
MPI Messages:         5.500e+00      1.00000   5.500e+00  5.500e+00
MPI Message Lengths:  1.411e+07      1.00000   2.566e+06  1.411e+07
MPI Reductions:       2.100e+01      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 4.9336e+01 100.0%  2.3886e+10 100.0%  5.500e+00 100.0%  2.566e+06      100.0%  2.100e+01 100.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
ThreadCommRunKer     494 1.0 5.0792e+00 1.0 6.67e+09 1.0 0.0e+00 0.0e+00 0.0e+00 10 28  0  0  0  10 28  0  0  0  1314
CreateMesh             1 1.0 8.9612e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+01 18  0  0  0 95  18  0  0  0 95     0
VecView                1 1.0 2.3220e-02 1.0 6.47e+05 1.0 1.0e+00 3.1e+06 0.0e+00  0  0 18 22  0   0  0 18 22  0    28
VecDot             10740 1.0 4.3375e+00 1.0 8.42e+09 1.0 0.0e+00 0.0e+00 0.0e+00  9 35  0  0  0   9 35  0  0  0  1941
VecNorm              490 1.0 1.7819e-01 1.0 3.84e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  2156
VecScale            1955 1.0 5.8523e-01 1.0 7.66e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0  1310
VecCopy             6356 1.0 2.6006e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
VecSet                47 1.0 2.1615e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             8287 1.0 3.3792e+00 1.0 6.69e+09 1.0 0.0e+00 0.0e+00 0.0e+00  7 28  0  0  0   7 28  0  0  0  1979
VecAYPX              976 1.0 4.0512e-01 1.0 3.83e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0   944
VecWAXPY               1 1.0 5.2404e-04 1.0 3.92e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   748
VecPointwiseMult    2929 1.0 1.6945e+00 1.0 1.15e+09 1.0 0.0e+00 0.0e+00 0.0e+00  3  5  0  0  0   3  5  0  0  0   678
MatMult              495 1.0 4.4913e+00 1.0 5.52e+09 1.0 0.0e+00 0.0e+00 0.0e+00  9 23  0  0  0   9 23  0  0  0  1229
MatAssemblyBegin       2 1.0 2.1458e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         2 1.0 1.4330e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         1 1.0 4.7700e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           2 1.0 3.0179e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexStratify        11 1.0 2.0543e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
DMPlexPrealloc         1 1.0 3.2820e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  7  0  0  0  0   7  0  0  0  0     0
DMPlexResidualFE       1 1.0 1.7055e+00 1.0 1.63e+08 1.0 0.0e+00 0.0e+00 0.0e+00  3  1  0  0  0   3  1  0  0  0    96
DMPlexJacobianFE       1 1.0 4.0298e+00 1.0 6.47e+05 1.0 0.0e+00 0.0e+00 0.0e+00  8  0  0  0  0   8  0  0  0  0     0
SFSetGraph             1 1.0 7.3969e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin           3 1.0 8.4453e-03 1.0 0.00e+00 0.0 4.5e+00 2.4e+06 0.0e+00  0  0 82 78  0   0  0 82 78  0     0
SFBcastEnd             3 1.0 3.5551e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFReduceBegin          1 1.0 1.4312e-03 1.0 0.00e+00 0.0 1.0e+00 3.1e+06 0.0e+00  0  0 18 22  0   0  0 18 22  0     0
SFReduceEnd            1 1.0 1.3900e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SNESFunctionEval       1 1.0 1.7262e+00 1.0 1.63e+08 1.0 3.5e+00 2.2e+06 0.0e+00  3  1 64 56  0   3  1 64 56  0    94
SNESJacobianEval       1 1.0 4.0329e+00 1.0 6.47e+05 1.0 1.0e+00 3.1e+06 0.0e+00  8  0 18 22  0   8  0 18 22  0     0
TaoSolve               1 1.0 2.5136e+01 1.0 2.35e+10 1.0 0.0e+00 0.0e+00 0.0e+00 51 98  0  0  0  51 98  0  0  0   935
TaoLineSearchApply     489 1.0 9.2746e+00 1.0 8.59e+09 1.0 0.0e+00 0.0e+00 0.0e+00 19 36  0  0  0  19 36  0  0  0   926
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Viewer     4              3         2312     0
              Object     5              5         2980     0
           Container    11             11         6380     0
              Vector    42             42    626666400     0
              Matrix     2              2     75555348     0
    Distributed Mesh    23             23       107520     0
    GraphPartitioner    11             11         6820     0
Star Forest Bipartite Graph    48             48        39336     0
     Discrete System    23             23        19136     0
           Index Set    59             59     50389936     0
   IS L to G Mapping     1              1      1666972     0
             Section    56             56        37856     0
                SNES     1              1         1340     0
      SNESLineSearch     1              1          880     0
              DMSNES     1              1          680     0
       Krylov Solver     1              1         1232     0
      Preconditioner     1              1          864     0
        Linear Space     1              1          656     0
          Dual Space     1              1          672     0
            FE Space     1              1          764     0
                 Tao     1              1         1720     0
       TaoLineSearch     1              1          896     0
Average time to get PetscTime(): 9.53674e-08
#PETSc Option Table entries:
-concentration 1,0
-dm_refine 4
-f_al 1e3
-f_at 1
-f_boundary cube_with_hole_test_bd.dat
-f_mesh cube_with_hole_test_mesh.dat
-f_out 1
-f_outname 3D_cube_orig.vtu
-ksp_rtol 1.0e-9
-ksp_type cg
-log_summary
-nonnegative 1
-pc_type jacobi
-petscpartitioner_type parmetis
-petscspace_order 1
-snes_atol 1.0e-6
-tao_type blmvm
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --download-chaco --download-exodusii --download-fblaslapack --download-hdf5 --download-metis --download-mumps --download-netcdf --download-openmpi --download-parmetis --download-scalapack --download-triangle --with-cc=gcc --with-cmake=cmake --with-cxx=g++ --with-debugging=0 --with-fc=gfortran --with-valgrind=1
Libraries compiled on Mon Apr  6 20:58:57 2015 on CAML-03.CIVE.UH.EDU
Machine characteristics: Darwin-14.1.0-x86_64-i386-64bit
Using PETSc directory: /Users/jychang48/Software/petsc-dev
Using PETSc arch: arch-darwin-c-debug
Using C compiler: /Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/bin/mpicc  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/bin/mpif90  -fPIC  -Wall -Wno-unused-variable -ffree-line-length-0 -Wno-unused-dummy-argument -O  ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/include -I/Users/jychang48/Software/petsc-dev/include -I/Users/jychang48/Software/petsc-dev/include -I/Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/include -I/opt/local/include -I/opt/X11/include
Using C linker: /Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/bin/mpicc
Using Fortran linker: /Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/bin/mpif90
Using libraries: -Wl,-rpath,/Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/lib -L/Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/lib -lpetsc -Wl,-rpath,/Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/lib -L/Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lexoIIv2for -lexodus -lflapack -lfblas -lparmetis -lnetcdf -ltriangle -lmetis -lssl -lcrypto -Wl,-rpath,/opt/local/lib -L/opt/local/lib -lhwloc -lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lchaco -Wl,-rpath,/opt/X11/lib -L/opt/X11/lib -lX11 -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/6.0/lib/darwin -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lgfortran -Wl,-rpath,/usr/local/Cellar/gcc/4.9.2/lib/gcc/x86_64-apple-darwin14.0.0/4.9.2 -L/usr/local/Cellar/gcc/4.9.2/lib/gcc/x86_64-apple-darwin14.0.0/4.9.2 -Wl,-rpath,/usr/local/Cellar/gcc/4.9.2/lib -L/usr/local/Cellar/gcc/4.9.2/lib -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lclang_rt.osx -lmpi_cxx -lc++ -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -Wl,-rpath,/Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/lib -L/Users/jychang48/Software/petsc-dev/arch-darwin-c-debug/lib -ldl -lmpi -lSystem -Wl,-rpath,/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -L/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.0/lib/darwin -lclang_rt.osx -ldl
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150409/ea331c22/attachment-0001.c>
  1 processors:
  type: plex
DM_0x7fe27ae3d3b0_0 in 3 dimensions:
  0-cells: 159
  3-cells: 592
Labels:
  type: plex
DM_0x7fe27ae3d3b0_1 in 3 dimensions:
  0-cells: 159
  1-cells: 845
  2-cells: 1280
  3-cells: 592
Labels:
  Time summary:
Create DMPlex: 0.00416207s
Distribute and refine DMPlex: 4.0888s
Set up problem: 61.2977s
Solver: 42.2464s
Postprocess into VTU: 3.73179s
./cube_with_hole on a arch-darwin-c-debug named CAML-03.CIVE.UH.EDU with 1 processor, by jychang48 Thu Apr  9 18:26:21 2015
Time (sec):           1.116e+02      1.00000   1.116e+02
Objects:              2.760e+02      1.00000   2.760e+02
Flops/sec:            2.142e+08      1.00000   2.142e+08  2.142e+08
MPI Reductions:       1.100e+01      1.00000
 0:      Main Stage: 1.1157e+02 100.0%  2.3895e+10 100.0%  5.500e+00 100.0%  2.566e+06      100.0%  1.100e+01 100.0%
Phase summary info:
ThreadCommRunKer     494 1.0 5.0596e+00 1.0 6.67e+09 1.0 0.0e+00 0.0e+00 0.0e+00  5 28  0  0  0   5 28  0  0  0  1319
CreateMesh             1 1.0 4.0930e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  4  0  0  0 91   4  0  0  0 91     0
VecView                1 1.0 3.2374e-01 1.0 3.47e+06 1.0 1.0e+00 3.1e+06 0.0e+00  0  0 18 22  0   0  0 18 22  0    11
VecDot             10740 1.0 4.3332e+00 1.0 8.42e+09 1.0 0.0e+00 0.0e+00 0.0e+00  4 35  0  0  0   4 35  0  0  0  1943
VecNorm              490 1.0 1.7682e-01 1.0 3.84e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  2173
VecScale            1955 1.0 5.8404e-01 1.0 7.66e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0  1312
VecCopy             6356 1.0 2.5955e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
VecSet                46 1.0 2.1418e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             8287 1.0 3.3791e+00 1.0 6.69e+09 1.0 0.0e+00 0.0e+00 0.0e+00  3 28  0  0  0   3 28  0  0  0  1979
VecAYPX              976 1.0 4.0522e-01 1.0 3.83e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0   944
VecWAXPY               1 1.0 5.5599e-04 1.0 3.92e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   705
VecPointwiseMult    2929 1.0 1.6930e+00 1.0 1.15e+09 1.0 0.0e+00 0.0e+00 0.0e+00  2  5  0  0  0   2  5  0  0  0   678
MatMult              495 1.0 4.4760e+00 1.0 5.52e+09 1.0 0.0e+00 0.0e+00 0.0e+00  4 23  0  0  0   4 23  0  0  0  1234
MatAssemblyEnd         2 1.0 1.4720e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries         1 1.0 4.8032e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexInterp           2 1.0 2.8389e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexStratify        10 1.0 1.8760e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
DMPlexPrealloc         1 1.0 4.1800e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 37  0  0  0  0  37  0  0  0  0     0
DMPlexResidualFE       1 1.0 8.6615e+00 1.0 1.66e+08 1.0 0.0e+00 0.0e+00 0.0e+00  8  1  0  0  0   8  1  0  0  0    19
DMPlexJacobianFE       1 1.0 8.3987e+00 1.0 3.47e+06 1.0 0.0e+00 0.0e+00 0.0e+00  8  0  0  0  0   8  0  0  0  0     0
SFSetGraph             1 1.0 6.8889e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFBcastBegin           3 1.0 8.0659e-03 1.0 0.00e+00 0.0 4.5e+00 2.4e+06 0.0e+00  0  0 82 78  0   0  0 82 78  0     0
SFBcastEnd             3 1.0 3.3667e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFReduceBegin          1 1.0 1.4300e-03 1.0 0.00e+00 0.0 1.0e+00 3.1e+06 0.0e+00  0  0 18 22  0   0  0 18 22  0     0
SFReduceEnd            1 1.0 1.2019e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SNESFunctionEval       1 1.0 8.7082e+00 1.0 1.66e+08 1.0 3.5e+00 2.2e+06 0.0e+00  8  1 64 56  0   8  1 64 56  0    19
SNESJacobianEval       1 1.0 8.4015e+00 1.0 3.47e+06 1.0 1.0e+00 3.1e+06 0.0e+00  8  0 18 22  0   8  0 18 22  0     0
TaoSolve               1 1.0 2.5100e+01 1.0 2.35e+10 1.0 0.0e+00 0.0e+00 0.0e+00 22 98  0  0  0  22 98  0  0  0   936
TaoLineSearchApply     489 1.0 9.2474e+00 1.0 8.59e+09 1.0 0.0e+00 0.0e+00 0.0e+00  8 36  0  0  0   8 36  0  0  0   928
              Viewer     4              3         2312     0
              Object     5              5         2980     0
              Vector    41             41    616666600     0
    Distributed Mesh    21             21        98176     0
    GraphPartitioner    10             10         6200     0
Star Forest Bipartite Graph    44             44        36016     0
     Discrete System    21             21        17472     0
           Index Set    54             54     55120896     0
             Section    52             52        35152     0
                SNES     1              1         1340     0
              DMSNES     1              1          680     0
            FE Space     1              1          764     0
                 Tao     1              1         1720     0
Average time to get PetscTime(): 0
-concentration 1,0
-dm_refine 4
-f_al 1e3
-f_at 1
-f_out 1
-ksp_rtol 1.0e-9
-ksp_type cg
-log_summary
-nonnegative 1
-pc_type jacobi
-petscspace_order 1
-snes_atol 1.0e-6
-tao_type blmvm
