[petsc-users] Using OpenMP threads with PETSc
Jed Brown jed at jedbrown.org
Thu Apr 9 16:50:21 CDT 2015
Lucas Clemente Vella <lvella at gmail.com> writes:
> For the next attempt, I've added the option "-threadcomm_type openmp",
> as the page http://www.mcs.anl.gov/petsc/features/threads.html says...
Need to configure --with-openmpclasses with petsc-dev to use
-threadcomm_type openmp.
> Now the program runs, but the CPU usage is never higher than 133%,
> which is much lower than the expected (if I solve the same matrix with
> Hypre + OpenMP, CPU usage peaks 200% most of the time).
Before getting carried away, run with flat MPI (no threads ever) and
compare the time.  In many ways, this mode has fewer synchronizations
and thus should perform better.  That's what we see on most machines
with HPGMG and lots of other people have found similar behavior.
If it's slower, send -log_summary for both versions.  Not all operations
are currently threaded.
> So, what threading model gives best results in PETSc, OpenMP or
> pthreads? And what I need to do use OpenMP? All my attempts were
> single-threaded,
You mean single-process.
> but I will need to work with MPI, is it straightforward to spawn many
> MPI processes (i.e. just put mpirun before the command?)
Yes.
> Lastly, how to prevent PETSc to mess with CPU affinities, because I
> implement affinity control myself inside my program.
Affinity fighting is a recurring disaster for library interoperability
with threads.  I think what is currently done in PETSc is actively
harmful and should be taken out.  But I think not using threads is a
much better solution for almost everyone.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150409/e1be5f50/attachment.pgp>
