[petsc-users] Unequal sparse matrix row distribution for MPI MatMult
Thu Apr 9 14:15:01 CDT 2015
On Thu, Apr 9, 2015 at 2:12 PM, Steena M <stm8086 at yahoo.com> wrote:
> Thanks, Barry! I patched the master, modified
> src/mat/examples/tests/ex190.c to suit my data, and the fix works.
> I need to execute MatMult and I am assigning  vectors on each rank using
> MatCreateVecs(A, &x, &y). However, I don't think multiplication is
> happening at all. (I inserted a few printf statements inside
> MatMult_MPIBAIJ and inside MatMult_SeqBAIJ1 to check).   VecSum(&ysum) is
> always zero. Maybe I'm assigning data incorrectly?
> Code snippet in ex190.c after partitioning the matrix unequally
>   ierr = MatLoad(A,fd);CHKERRQ(ierr);
>   ierr = MatCreateVecs(A, &x, &y);CHKERRQ(ierr);
>   ierr = VecSet(x,one);CHKERRQ(ierr); //PetscScalar one = 1.0;
>   ierr = VecSet(y,zero); CHKERRQ(ierr); //PetscScalar zero = 0.0;
MatView(A, 0) gives you the matrix, so you can see what Ax should be.
>   ierr = MatMult(A,x,y); CHKERRQ(ierr);
VecView(y, 0) gives you the output
  Matt
>   ierr =  VecSum(y,&ysum);CHKERRQ(ierr); //ysum is always zero.
> Data is a 20x20 matrix and block size is 1.
> Any thoughts?
> Thanks,
> Steena
>   On Friday, April 3, 2015 4:17 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>   Steena,
>   Sorry for all the delays. Our code was just totally wrong for a user
> provided decomposition for two reasons 1) the logic in MatLoad_MPIXAIJ()
> was too convoluted to work in all cases and 2) we didn't have a single test
> case.
>   I have attached a patch that fixes it for petsc-3.5.3
> .  The fix is also in the branch barry/fix-matload-uneven-rows
> and I'll put it into next then after testing it will got into maint and
> master and the next PETSc patch release.
>   Please let us know if the patch doesn't work for you
>   Thanks for your patience,
>   Barry
> > On Apr 1, 2015, at 3:10 PM, Steena M <stm8086 at yahoo.com> wrote:
> > Thanks Barry. Attached is the driver program, the binary mat file, and
> the corresponding mtx file.
> > Runtime command used:
> > sierra324 at monteiro:time srun -n 2 -ppdebug ./petsc-mpibaij-unequalrows
> -fin trefethen.dat -matload_block_size 1
> > On Wednesday, April 1, 2015 12:28 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> >  Send a data file you generated and your reader program and we'll debug
> it.
> >  Barry
> > > On Apr 1, 2015, at 2:18 PM, Steena M <stm8086 at yahoo.com> wrote:
> > > Thanks Barry. I removed the Preallocation calls. It is still
> complaining about the malloc and incorrect data in the matrix file. I
> generate binary matrix files using PETSc's pythonscript to loop through a
> set of UFL sparse matrices. For this use case:
> > > mtx_mat = scipy.io.mmread('trefethen.mtx')
> > > PetscBinaryIO.PetscBinaryIO().writeMatSciPy(open('trefnew.dat','w'),
> mtx_mat)
> > > On Tuesday, March 31, 2015 9:15 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > >  You should not need to call any preallocation routines when using
> MatLoad()
> > >  How did you generate the file? Are you sure it has the correct
> information for the matrix?
> > >  Barry
> > > > On Mar 31, 2015, at 11:05 PM, Steena M <stm8086 at yahoo.com> wrote:
> > > > Thanks Matt. I'm still getting the malloc error
> > > > [0]PETSC ERROR: Argument out of range!
> > > > [0]PETSC ERROR: New nonzero at (2,18) caused a malloc!
> > > > and
> > > > a new incorrect matrix file error:
> > > > [0]PETSC ERROR: Unexpected data in file!
> > > > [0]PETSC ERROR: not matrix object!
> > > > Maybe the order of calls is mixed up. This is the code snippet:
> > > >    if (rank ==0)
> > > >    PetscPrintf (PETSC_COMM_WORLD,"\n On rank %d ", rank);
> > > >        CHKERRQ(MatSetSizes(A, 15, PETSC_DETERMINE, 20, 20));
> > > >        CHKERRQ(MatSetType(A, MATMPIBAIJ));
> > > >        CHKERRQ( MatMPIBAIJSetPreallocation(A,1,1,NULL,1,NULL));
> > > >        CHKERRQ( MatLoad(A,fd));
> CHKERRQ(MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE));
> > > >    else
> > > >        CHKERRQ( MatSetSizes(A, 5, PETSC_DETERMINE, 20, 20) );
> > > >        CHKERRQ(MatLoad(A,fd));
> > > > Is there something I'm missing?
> > > > Thanks,
> > > > Steena
> > > > On Tuesday, March 31, 2015 6:10 PM, Matthew Knepley <
> knepley at gmail.com> wrote:
> > > > On Tue, Mar 31, 2015 at 6:51 PM, Steena M <stm8086 at yahoo.com> wrote:
> > > > Thanks Barry. I'm still getting the malloc error with NULL. Is there
> a way to distribute the matrix without explicit preallocation? Different
> matrices will be loaded during runtime and assigning preallocation
> parameters would mean an additional preprocessing step.
> > > > 1) MatSetOption(MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE)
> > > > 2) Note that this is never ever ever more efficient than making
> another pass and preallocating
> > > >  Thanks,
> > > >      Matt
> > > > On Sun, 3/29/15, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > >  Subject: Re: [petsc-users] Unequal sparse matrix row distribution
> for MPI MatMult
> > > >  To: "Steena M" <stm8086 at yahoo.com>
> > > >  Cc: "Matthew Knepley" <knepley at gmail.com>, petsc-users at mcs.anl.gov
> > > >  Date: Sunday, March 29, 2015, 9:26 PM
> > > >  > On
> > > >  Mar 29, 2015, at 11:05 PM, Steena M <stm8086 at yahoo.com>
> > > >  wrote:
> > > >  > Thanks
> > > >  Matt. I used PETSC_DETERMINE but I'm now getting an
> > > >  allocation-based error:
> > > >  > [0]PETSC ERROR: ---------------------
> > > >  Error Message ------------------------------------
> > > >  caused a malloc!
> > > >  > [0]PETSC ERROR:
> > > >  > I tried
> > > >  preallocating on each rank for the diagonal and off diagonal
> > > >  section of the matrix as the next step  My current
> > > >  approximations for preallocation
> > > >  > CHKERRQ(
> > > >  MatMPIBAIJSetPreallocation(A,1,5,PETSC_DEFAULT,5,PETSC_DEFAULT));
> > > >    These
> > > >  arguments where you pass PETSC_DEFAULT are expecting a
> > > >  pointer not an integer. You can pass NULL in those
> > > >  locations. Though it is better to provide the correct
> > > >  preallocation rather than some defaults.
> > > >    Barry
> > > >  > are throwing segmentation errors.
> > > >  > [0]PETSC ERROR:
> > > >  Caught signal number 11 SEGV: Segmentation Violation,
> > > >  probably memory access out of range
> > > >  > Any insights into what I'm doing
> > > >  wrong?
> > > >  > Thanks,
> > > >  > Steena
> > > >  > On Sun, 3/29/15, Matthew Knepley <knepley at gmail.com>
> > > >  wrote:
> > > >  > Subject:
> > > >  Re: [petsc-users] Unequal sparse matrix row distribution for
> > > >  MPI MatMult
> > > >  > To: "Steena M"
> > > >  > Cc: "Barry Smith" <bsmith at mcs.anl.gov>,
> > > >  > Date: Sunday, March 29, 2015, 10:02 PM
> > > >  > On Sun, Mar 29, 2015
> > > >  at
> > > >  > 9:56 PM, Steena M <stm8086 at yahoo.com>
> > > >  > wrote:
> > > >  > Hi
> > > >  > Barry,
> > > >  > I am trying to partition a 20 row and 20
> > > >  col sparse matrix
> > > >  > between two procs
> > > >  such that proc 0 has 15 rows and 20 cols
> > > >  > and proc 1 has 5 rows and 20 cols. The
> > > >  code snippet:
> > > >    CHKERRQ(MatCreate(PETSC_COMM_WORLD,&A));
> > > >  > at runtime: -matload_block_size 1
> > > >    if (rank ==0)
> > > >    CHKERRQ( MatSetSizes(A, 15, 20, 20,
> > > >  > 20) ); //rank 0 gets 75% of the rows
> > > >    CHKERRQ( MatSetType(A, MATMPIBAIJ)
> > > >  >                CHKERRQ(
> > > >  MatLoad(A,fd) );
> > > >  >        else
> > > >  20, 20,
> > > >  > 20) ); //rank 1 gets 25% of the
> > > >  rows
> > > >  >                CHKERRQ(
> > > >  MatLoad(A,fd) );
> > > >  > This throws the following error (probably
> > > >  from psplit.c):
> > > >  [1]PETSC ERROR: --------------------- Error Message
> > > >  > [1]PETSC ERROR:
> > > >  Nonconforming object sizes!
> > > >  > [1]PETSC ERROR: Sum of local lengths 40
> > > >  does not equal
> > > >  > global length 20, my
> > > >  local length 20
> > > >  >  likely a call to
> > > >  VecSetSizes() or MatSetSizes() is
> > > >  wrong.
> > > >  > See
> > > >  http://www.mcs.anl.gov/petsc/documentation/faq.html#split!
> > > >  > This error printout
> > > >  doesn't quite make sense to me.
> > > >  I'm trying to specify a total matrix size of 20x20...
> > > >  I
> > > >  > haven't yet figured out where the
> > > >  '40' comes
> > > >  > from in the error
> > > >  message.
> > > >  > Any thoughts on what
> > > >  might be going wrong?
> > > >  > Its the column specification. Just
> > > >  > use PETSC_DETERMINE for the local columns
> > > >  since all our
> > > >  > sparse matrixformats are
> > > >  row divisions
> > > >  > anyway.
> > > >  > Thanks,
> > > >  >  Matt
> > > >  > Thanks in advance,
> > > >  > Steena
> > > >  > On Sun, 3/22/15,
> > > >  sparse matrix row
> > > >  MatMult
> > > >  >  To:
> > > >  >  Cc: petsc-users at mcs.anl.gov
> > > >  >  Date: Sunday,
> > > >  March 22, 2015, 3:58 PM
> > > >  >  Steena,
> > > >  >    I am
> > > >  >  a little unsure of your question.
> > > >  >    1)
> > > >  you can create a MPIBAIJ
> > > >  >  matrix with any distribution of block
> > > >  rows per process
> > > >  > you
> > > >  >  want, just set the
> > > >  local row size for each process to
> > > >  be
> > > >  >  what you
> > > >  like.  Use MatCreateVecs() to get
> > > >  correspondingly
> > > >  laid out vectors.
> > > >    or 2) if you have a MPIBAIJ
> > > >  >  matrix with
> > > >  "equal" row layout and you want a
> > > >  > new
> > > >  >  one with uneven row layout you can
> > > >  simply use
> > > >  MatGetSubMatrix() to create that new matrix.
> > > >  >    Barry
> > > >  >  Unless you have
> > > >  another reason to have the
> > > >  >  matrix with an equal number row layout I
> > > >  would just
> > > >  > generate
> > > >  >  the matrix with
> > > >  the layout you want.
> > > >  >  > On Mar 22, 2015, at 5:50 PM, Steena
> > > >  M
> > > >  >  wrote:
> > > >  >  > Hello,
> > > >  >  > I need to
> > > >  distribute
> > > >  >  a
> > > >  sparse matrix such that each proc owns an unequal
> > > >  > number
> > > >  >  of blocked rows before I proceed with
> > > >  MPI MatMult. My
> > > >  initial thoughts on doing this:
> > > >  >  > 1) Use  MatGetSubMatrices() on the
> > > >  test
> > > >  >  MATMPIBAIJ
> > > >  matrix to produce a new matrix where each
> > > >  > proc
> > > >  >  has an unequal number of rows.
> > > >  >  > 2) Provide
> > > >  scatter context for vector X
> > > >  >  (for MatMult )using IS iscol from
> > > >  MatGetSubMatrices()
> > > >  > while
> > > >  >  creating the
> > > >  vector X.
> > > >  >  > 3)
> > > >  Call MatMult()
> > > >  >  > Will
> > > >  MatMult_MPIBAIJ continue to scatter
> > > >  >  this matrix and vector such that each
> > > >  proc will own an
> > > >  > equal
> > > >  >  number of matrix
> > > >  rows and corresponding diagonal vector
> > > >  >  elements? Should I write my own
> > > >  MPIMatMult function to
> > > >  >  retain my redistribution of the matrix
> > > >  and vector?
> > > >  Thanks in
> > > >  advance,
> > > >  Steena
> > > >  > What most
> > > >  experimenters
> > > >  > take for granted before
> > > >  they begin their experiments is
> > > >  infinitely more interesting than any results to which
> > > >  their
> > > >  > experiments lead.
> > > >  > -- Norbert
> > > >  > Wiener
> > > > What most experimenters take for granted before they begin their
> experiments lead.
> > > > -- Norbert Wiener
> > <trefethen.mtx><trefethen.dat><petsc-unequalrows-mpibaij.c>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150409/ddce2bb7/attachment-0001.html>
