[petsc-users] Exploiting symmetry with direct solvers
David Knezevic david.knezevic at akselos.com
Wed Apr 8 22:08:15 CDT 2015
On Wed, Apr 8, 2015 at 11:06 PM, Hong <hzhang at mcs.anl.gov> wrote:
> David:
>>>> Mumps supports Cholesky factorization for symmetric, and symmetric+spd
>>> matrices.  You may consult mumps user manual.
>> OK, thanks. But I was also wondering about the PETSc interface to MUMPS.
>> I consulted the MUMPS manual, but it just says that you need to specify
>> "SYM=1" in order to get an LDL^T factorization. I gather that if we set
>> MatSetOption(A,MAT_SPD,PETSC_TRUE); in PETSc then that will tell MUMPS to
>> use SYM=1, right?
> When user requests Cholesky factorization, PETSc sets  "SYM=2" as default;
> If user sets flag of spd, then the interface uses "SYM=1" in order to get
> an LDL^T factorization. See MatGetFactor_xxx_mumps() in
> petsc/src/mat/impls/aij/mpi/mumps/mumps.c:
>  B->factortype = MAT_FACTOR_CHOLESKY;
>   if (A->spd_set && A->spd) mumps->sym = 1;
>   else                      mumps->sym = 2;
OK, got it, thanks!
David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150408/01abe15e/attachment.html>
