[petsc-users] Reuse Matrix
Baron Law baronlaw at purdue.edu
Wed Apr 8 13:39:59 CDT 2015
I need to compute the solution of least square regression for many times (> 10^6) for large matrix A (>10^9x10^3). I use a hypercube basis, so each row of the matrix A has exactly one non-zero entry with value 1. On different runs, the positions of the 1 are different. I would like to reuse the sparse structure of A, what is the best way to do in this scenario?
I have heard of MatCreateMPIAIJWithSplitArrays, but it is kind of difficult to use. I try it a bit and seems like after creation if I need to change the column index, I need to skip the diagonal block. Also, I am not 100% sure, how to find which columns belong to the diagonal block for each process. But as mentioned, I need to run the regression million times, even it is difficult to use, I will try if it is fastest method.
Best,
Baron
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150408/a7d7752e/attachment.html>
